Service Manual - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 12-06-2012, 05:41 PM   #1
1997Malibu
1997 Malibu Base
Gold
Default Service Manual
Is there a free Service Manual for our car?
I need to find parts with partnumbers.
1997Malibu is offline   Reply With Quote Quick reply to this message
Old 12-06-2012, 09:01 PM   #2
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Default Re: Service Manual
Depends on your library, but if you check gmpartsgiant.com - you can usually find most of the part on the exploded diagrams, and get the partial part numbers off of that.
Where are you looking for parts where you need the numbers?
RwP
Old 12-07-2012, 02:49 AM   #3
1997Malibu
1997 Malibu Base
Gold
RwP
I might need a new steering house
and RR lower arm (some idiot jack lifted the car on this part and it got curved)
I rebuild this car which had been sitting over 5 years.
Just finished overhauling the engine.
Old 12-07-2012, 06:40 AM   #4
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Quite often the ACDelco parts are listed at RockAuto for those parts (I presume steering hose, not house, there ... )
I'd be checking there.
And don't buy a cheap part, either.
Oh! Do you mean the trailing arm (which so far I've only found at dealers)? If so, doesn't matter what part # you want, you'll have to order from a GM dealer.
Which motor does your 'Bu have? Have you done any improvements (like the Alero/Grand Am rear discs, the Grand Prix alignment arms in the back, etc.)?
RwP
Old 12-07-2012, 09:13 AM   #5
MrRichRod
CMF Veteran Member
2012 1LT w/ All-Star
Black Granite
MrRichRod's Avatar
I know it's not free, but it's pretty close for the type of work you're doing: Check out AllData DIY.com where you can get a three year subscription for $16.95.
I've personally asked for the 5 year subscription for Christmas which is $44.95. The Helm paper alternative is $200.
2012 1LT 2.4L/A6 (LE5) in Black Granite w/ All-Star Pkg.
2009 2LT 3.6L/A6 (LY7) in Black Granite
1995 MX-5 1.8L/M5 Miata
MrRichRod is offline   Reply With Quote Quick reply to this message
Old 12-07-2012, 09:59 AM   #6
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
AllDataDIY is good, don't misunderstand me!
But it doesn't touch the factory manuals on both my Cougar and when I was still wrenching on the Malibu (before it died - see signature).
OTOH, it's a lot cheaper than the factory manual was for the Malibu (which I have on DVD, and am keeping, so don't ask! *grins* )
RwP
Old 12-10-2012, 04:26 AM   #7
1997Malibu
1997 Malibu Base
Gold
RwP
I have a 97' Malibu Base 3.1L V6
My car is full stock, just GM replacement parts in the engine compartment.
Parts I am looking for:
-steering housing
-rear wheel aligment arms
Old 12-10-2012, 05:13 AM   #8
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
-steering housing
Check at GMPartsGiant.COM and find out what the parts you're looking for are called.
Steering housing - Would that be the steering column, the steering rack, or something else?
Rear wheel alignment arms - Referring to http://www.genmotorinfo.com/FullImag...020711MN07-004 , are you talking about part 11, or parts 15 and 19?
If 11, it's called a trailing arm, and RockAuto lists the Dormans at http://www.rockauto.com/catalog/rafr...&parttype=7504 .
If 15 and 19, they're called lateral links, and are listed at http://www.rockauto.com/catalog/rafr...parttype=10414 (rear front and rear rear are the front and rear links, on the rear of the car.)
For 15 and 19, a good substitute would be the Grand Prix arms, which almost fit (you would need to make washers for the spindle, since the hole is a bit larger than the Malibu unit was) and which would make the back end stay a bit more "planted" in hard cornering. OTOH, you may not need or want to do that ... which is find, the original GM design, whereas a bit sucky, at least works for what a family flivver would normally be driven as
RwP
Old 12-11-2012, 05:38 AM   #9
1997Malibu
1997 Malibu Base
Gold
RwP
Part 19 is correct; lateral links
I am not sure if steering column is correct, will take drawing to my mechanic to point out.
Steering housing is the part where the rod of steering wheel is connected to.
Thank you very much
Old 12-11-2012, 09:31 AM   #10
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Thank you very much
At the same site (GMPartsGiant.COM) I hit this picture:
Are you talking about call out 30? If so, that's the steering rack.
If not, is it on this drawing? And if not, can you locate the drawing at GMPartsGiant.COM and see what it's actually called?
RwP
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Service Manual FS dennisk Do It Yourself Maintenance (Generation 7) 1 07-08-2012 06:40 AM
2010 Service Manual Set on Helm Starship Do It Yourself Maintenance (Generation 7) 5 07-18-2011 02:11 PM
What is the best service manual to buy ski_rush General Discussion (Generations 5 & 6) 5 04-11-2011 07:25 PM
Service Manual Alfred Jaeger Trading Post (See rules before posting an item for sale!) 3 06-30-2010 04:25 PM
