2003 Malibu Service Vehicle Soon & Theft System Light - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 01-03-2013, 01:36 PM   #1
AmandaB
Default 2003 Malibu Service Vehicle Soon & Theft System Light
I have a 2003 Malibu with just over 85,000 miles. I have loved this car from the first test drive and we have been together since her 7th mile.
Sadly,a couple of quirky problems have been popping up intermittently over the last year and are getting progressively more obnoxious. Here is what is happening:
1. The AC will sporadically cut off. Air is still blowing but it is no longer cold & the green light on the AC button blinks on and off as the AC kicks on and off. I used to think that jiggling the button would help it to kick back on, but now I think it has a mind of its own and comes back on when it chooses.
2. The blinkers sporadically stop working. The hazard lights still work and pressing the hazard light button seems to reset the signal indicator problem and all is temporarily well again.
3. The car horn spontaneously honks (a short blast) when the car is turned off and locked. (i.e. Me = walking into the house...Car = HONK)very "Christine"-like
4. The doors stopped automatically unlocking when the car was turned off
5. The "Anti Theft System" light came on briefly but did not stay on and has not appeared with any degree of consistency...like it goes off while I'm still driving.
This behavior has been going on for about a year...and has been inconsistent enough to be highly annoying while also too hard to pin down for service.
In mid December a couple of new developments arrived.
6. When started, the radio, gas gauge, lights, & AC all failed to come to life. After a short time, these things seemed to "awaken" and all is well.
7. Intermittently, the Service Vehicle Soon light comes on. This light has also been highly inconsistent.
Meanwhile...today...the door locks have mysteriously started working again!! Is my car possessed?
I have heard something of a Body Control Module being on the fritz as a possibility...could that have the Anti-Theft System on the blink as well?
Thanks for any advice!
AmandaB is offline   Reply With Quote
Old 01-04-2013, 04:14 AM   #2
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
Default Re: 2003 Malibu Service Vehicle Soon & Theft System Light
Common issues with your generation model:
Ignition switch (electrical part) fails - replace the tumbler at the same time if you replace the switch since you're already there.
Climate control head fails - check some other threads on here for a fix.
Hazard switch fails - turn signals are routed through it and when the contacts fail the turn signals fail.
Muffler mod on '09
DrivenDaily is online now   Reply With Quote
Old 01-04-2013, 09:33 AM   #3
AmandaB
Hmm...none of that appears particularly helpful.
My hazard lights work and my car doesn't have an issue starting...at least not yet.
Perhaps the AC tip is worth investigating, but I'm inclined to believe some of these things are connected via the larger BCM issue.
Old 01-04-2013, 10:37 AM   #4
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Actually, all of it is.
The hazard switch is also the flasher for the turn signals. When the contacts start to go bad, the FIRST symptom is that the turn signals quit flashing, whereas hazards still work fine. Different function, same unit, different wiring internally.
The A/C is just about 100% guaranteed to be the head going bad (said due to past history). See http://www.imcool.com/articles/airco...Repairable.pdf for info on it.
The dash cluster - I'd check the ignition switch FIRST. But also, instead of the BCM being bad, it could easily be fretting in the BCM. I'd disconnect the battery, then unplug/replug the BCM four or five times, then reconnect the battery and see if that helps some. Oxidation and fretting is a lot more common than failed BCMs, and easier to "fix". Swapping the BCM would also fix oxidation and/or fretting, but at a higher price.
Hmm ... hazard switch has about 10Kmiles, 3 months running on my Malibu. Maybe I ought to pull it and sell it here - I paid something like $40 when I bought it new at the dealership.
RwP
Old 01-05-2013, 01:35 AM   #5
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
Cool Re: 2003 Malibu Service Vehicle Soon & Theft System Light
snip
AmandaB,
Really? You ask for help and then just so blithely discount it? Hmmm, none of your comments appear particularly respectful!
RalphP,
As always, thank you for stepping up and helping the helpless, though this time the helpless also appear to be thankless or thoughtless.
Back to AmandaB,
If the direction you get here actually helps you it would be really nice if you'd stop back and let us know what happened. Remember, you asked for help and we stepped up. And if RalphP says he has this or that for sale and lets you know its condition I can vouch for his sincerity. He is truly a dignified and decent person. He'll tell you straight up when you ask a question and you'll know what you're getting if you buy something from him.
Muffler mod on '09
Old 01-06-2013, 09:02 AM   #6
AmandaB
Thank you Ralph!
Old 01-06-2013, 09:05 AM   #7
AmandaB
DrivenDaily, I meant no disrespect. I'm not a blogger or frequent forum user and didn't consider how my attempt at conversational tone could so easily sound fllippant. I apologize.
Old 01-07-2013, 03:56 AM   #8
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
Accepted. We're cool.
Have you tried any of the suggestions yet? If so, any success?
Muffler mod on '09
Old 01-07-2013, 02:56 PM   #9
AmandaB
I haven't tried yet, but I will update and let y'all know how things turn out when I do. Thanks!
You may not post new threads
You may not post replies
Theft system (1998 malibu) RANDYA57 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 04-27-2012 08:08 PM
Service Vehicle Soon light Jrad Problems/Service Issues/Troubleshooting (Generations 5 & 6) 6 08-24-2011 05:15 AM
Service Vehicle Soon Light - Frustrated! penguins1 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 10 08-17-2011 01:09 PM
Theft System 2005 Malibu pcBuffalo Problems/Service Issues/Troubleshooting (Generations 5 & 6) 1 01-10-2011 03:50 PM
2005 Malibu anti-theft system light JMCD6344 General Discussion (Generation 7) 2 01-21-2009 03:29 PM
