Stalling, ESC and TC lights - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 01-15-2013, 08:03 AM   #1
Reallove
2009 Malibu LS
tan
Default Stalling, ESC and TC lights
Hello I am an owner of a 2009 Malibu and I am having the worst time with stalling, shutting off and the esc and tc light coming on. It really stalls when its really cold outside and it acts like it wants to stop while driving. When I first noticed it I was turning and now it happens while I am driving. The ESC and TC lights came on so I took it to the dealer, they scanned it and the traction switch was bad. Because it was an intermittent problem they couldn't tell me anything else. I replaced the switch. Two weeks later doing same thing and now engine check light is on. Took to dealer traction switch code was gone. Scanned again and now map sensor code was coming up. Long story short I replaced the map sensor. The problem still exist and I am starting to hate my 2009 Chevy Malibu! Know one can tell me what the problem is and I am spending money on parts and its not fixing the problem. Please help... Frustrated Malibu owner.
Reallove is offline   Reply With Quote
Old 01-15-2013, 02:33 PM   #2
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
Default Re: New member
Moved from New Member Intro area ...
... since you're not really introducing yourself, your seeking input on a problem ...
Look up the issue using Search and see if unplugging and re-plugging the BCM will do the trick. (Read it first!)
Muffler mod on '09
Old 01-15-2013, 03:05 PM   #3
greenman
ASE Certified Technician
Drive to autozone, have them read the current codes for free, write them down & report back here with the exact code numbers-not an interpretation of them by an autozone store clerk.
There is no traction control switch trouble code per se. There are three MAP sensor trouble codes.
Also, if you know the other codes that it has popped lately, give me those.
greenman is offline   Reply With Quote
Old 01-16-2013, 12:26 PM   #4
Reallove
2009 Malibu LS
tan
Default Re: Stalling, ESC and TC lights
Thank you. My check engine light came on again and I went to autozone the code it is reading now is P0106. Prior to that it was P0107 and C0561. When the dealer got the code of C0561 they told me it was the code to change the traction switch. I did that it did not fix the problem. Then the code P0107 next and the dealer said it was the MAP sensor. Still having same issue. Now the code from autozone is P0106. I am confused and feel misled by the dealer because from what I was told there is not code for the traction switch.
Old 01-16-2013, 12:28 PM   #5
Reallove
2009 Malibu LS
tan
Thank you and I apologize.
Old 01-16-2013, 01:47 PM   #6
greenman
Firstly, these are likely unrelated issues.
C0561:
I know exactly why they reached the conclusion to change the traction control switch based on that C0561. There's a bulletin out that would lead you to that conclusion unfortunately that fix won't always be the right fix. Now, one problem you have is the car may still be reporting a C0561 code but you won't know it because the code readers they use at autozone can't read any codes that aren't OBD2 codes. But let's assume for now that was the right fix & that issue was corrected.
P0106 & P0107:
Since you've already swapped out the MAP sensor & are still getting a MAP sensor code your problem is with the wiring to the MAP sensor. A visual inspection may reveal the problem (usually easier said than done) or that circuit will need to be tested for a fault. That is generally not something most people can do themselves.
Old 01-17-2013, 05:33 AM   #7
Reallove
2009 Malibu LS
tan
C0561:
P0106 & P0107:
Ok I see... So now that we now know that may be the problem should I take it to a mechanic to get it visually inspected or should they scan it again? It sounds like an easy fix so what do you suggest I do at this moment because I want to sleep again not worrying about this issue. Thank you so much for your help. This has helped me a lot because I wasn't getting anywhere with my local dealer and they have been giving me the run around.
Old 01-17-2013, 11:35 AM   #8
greenman
Finding a problem in a wire loom can be pretty time (read: money) intensive. Hopefully the problem is with the MAP sensor connector or close to it. If not, a dealer mechanic will probably want to swap out the harness which is not an inexpensive thing to do. A non-dealer shop will usually end up costing less but not always. Don't know what else to tell you.
Old 01-17-2013, 06:53 PM   #9
repairman54
CMF Junior Member
2009 Malibu LS 2.4
Carbon Mist Met.
repairman54's Avatar
Garage
Reseat the connectors.
If he had advanced scanning capabilites I'd bet on a communication error code coming up. That's what tipped me off on reseating my connectors to cure my ESC and TC warnings along with my brake lights coming on by themselves.
This CAN stuff is sensitive.
John
"some suffer from insanity, I choose to enjoy it"
09 Malibu LS
07 Mustang GT 3 pedals
99 Yukon
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
repairman54 is offline   Reply With Quote
Old 01-21-2013, 01:04 PM   #10
Reallove
2009 Malibu LS
tan
OK thank you. I will try again and see what happens.
You may not post new threads
You may not post replies
Intermittent Stalling After Start Mark C Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 12-26-2011 03:33 PM
stalling out newfieprincess Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 11-11-2010 03:39 PM
car stalling djlheat General Discussion (Generation 7) 5 12-10-2009 10:31 AM
car keeps stalling jj71787 General Discussion (Generation 7) 6 09-13-2009 09:36 AM
Engine stalling all of a sudden. elie2wins Do It Yourself Maintenance (Generation 7) 6 03-23-2009 09:09 PM
