Power tap option - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 01-19-2013, 10:00 AM   #1
geeti
CMF Junior Member
2012 Malibu 1lt
grey
Default Power tap option
Hi there,
I need a 12V power for my electronics. At first, I wanted to get the power from the fuse box. But it appeared that it is a constant power, which may cause the battery drained and I don't want that...
So, guys, where did you get the power for your in-car stuff? Which starts up as key turning on, shuts down as you left the car?
geeti is offline   Reply With Quote
Old 01-19-2013, 10:12 AM   #2
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
Default Re: Power tap option
Front center console, right side. Pull cover to reveal fuses. Cover has what is what molded into it. Find the circuit you want and use an Add-A-Circuit to add a fused tap without having to splice into wires. Cheap, easy, removable!
Muffler mod on '09
Old 01-19-2013, 09:06 PM   #3
geeti
CMF Junior Member
2012 Malibu 1lt
grey
Are you saying to tap from fuse box?
Old 01-20-2013, 03:54 AM   #4
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
Yes, exactly. Use one of these:
dBay Link to Add-A-Circuit page
It has the contacts to slide in where the stock fuse goes which is then plugged into the lower set of holes. The upper set is where you tap into the circuit.
Note: To properly install it have the prospective donor circuit powered (such as heater, AC, etc), then pull the stock fuse. Using a light tester find which of the two pins is powered. The side of the device without the wire coming off of it is the side that will plug into that powered pin. That makes sure that the original circuit is protected by its fuse and the new circuit is protected by the new fuse without having to go through the stock fuse.
Muffler mod on '09
Old 01-20-2013, 08:42 AM   #5
geeti
CMF Junior Member
2012 Malibu 1lt
grey
Yes. This is exactly what I did. It's easy and safe, but the biggest problem is the power is constant. I only need the power when driving, pretty much the same as windows or radio.
Old 01-20-2013, 08:53 AM   #6
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Geeti - Pick another fuse then. Or if there's not a switched fuse in that block, pick another block with a switched fuse and then extend the wire back to control the relay.
RwP
Old 01-20-2013, 09:07 AM   #7
itsbmw
CMF Junior Member
2011 Malibu LTZ
Black
Sunroof fuse is almost always switched on GM cars. One of my cars that didn't have a sunroof still had the fuse there in the block and it was switched 12v.
itsbmw is offline   Reply With Quote
Old 01-20-2013, 11:46 AM   #8
geeti
CMF Junior Member
2012 Malibu 1lt
grey
Which fuse is a switched one?
RwP
Old 01-20-2013, 03:00 PM   #9
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
Lightbulb Re: Power tap option
If you are unable to figure that much out by yourself then maybe you should reconsider doing any electrical modifications to your car.
After all, it is filled with wires that are for the LAN and splicing into them can do irreparable harm to the BCM. Not cheap!
Muffler mod on '09
Old 01-20-2013, 05:16 PM   #10
geeti
CMF Junior Member
2012 Malibu 1lt
grey
I am an electrical engineer, and those stuff wouldn't be a problem.
I read the electrical circuit graph of malibu, and it appears all fuses are directly connected to battery. Aren't they?
You may not post new threads
You may not post replies
iPod Option 04-05 bu invwheelie Modifications (Generations 5 & 6) 4 09-15-2011 08:18 AM
No option but Malibu g8rh8r12 New Member Introduction 4 02-28-2009 06:34 PM
New engine option beach General Discussion (Generation 7) 12 12-06-2008 05:45 AM
New 2LT V6 wheel option, just released beach General Discussion (Generation 7) 7 11-10-2008 12:13 PM
Why is red paint an option? Malibooboo General Discussion (Generation 7) 14 07-02-2008 08:36 AM
