2010 cranks but won't start - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 01-21-2013, 08:58 AM   #1
89raggtopp
2010 Malibu 2lt
Default 2010 cranks but won't start
If car sits more than 6 hrs it will crank but not start. If the gas pedal it pushed to the floor it starts. If the car is warmed up it starts fine. Replaced purge valve and still same problem.
89raggtopp is offline   Reply With Quote
Old 01-21-2013, 04:27 PM   #2
Dilatory
CMF Senior Member
2011 Malibu LS
Gold Metallic
Default Re: 2010 cranks but won't start
I'm no Master tech but that almost sounds like a fuel pump issue.. and with GMs reputation with fuel pumps wouldn't be largely surprising..
Dilatory is offline   Reply With Quote
Old 01-21-2013, 04:49 PM   #3
Mongoose
CMF Senior Member
2013 Malibu 2LZ
White Diamond
Mongoose's Avatar
If you smell gas when this happens its flooded...may be a no spark issue also.
Mongoose is offline   Reply With Quote
Old 01-23-2013, 03:05 PM   #4
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
Thread moved from Gen8 to Gen7 section. Watch where you post.
Muffler mod on '09
Old 01-24-2013, 09:09 PM   #5
scott37300
CMF Junior Member
2009 Malibu 2LT
Black
When you push the pedal to the floor it goes into clear flood mood. So if it starts when you do this I would think that your car is flooding. Maybe bad FPR that is leaking when it sits, I know there was an issue like this with the impalas a few years back. You should be able to take the vacuum hose of the FPR while it's running and it might take a few minutes but if it is leaking you should smell or see fuel. But if it will start when you push the pedal to the floor I would be checking for things that would cause a flood situation.
scott37300 is offline   Reply With Quote
Old 01-24-2013, 11:58 PM   #6
greenman
ASE Certified Technician
Put a gauge on the fuel rail port to check pressure during a cold start. Range should be 50-60psi. A stuck-open purge valve usually pops a code & typically only causes flooding immediately after refueling.
No codes or other symptoms?
greenman is offline   Reply With Quote
Old 01-25-2013, 12:24 AM   #7
greenman
They don't use separate regulators anymore. They are built into the pump assy.
Old 01-25-2013, 04:52 AM   #8
scott37300
CMF Junior Member
2009 Malibu 2LT
Black
I didn't know that. What about a leaky injector?
Old 01-25-2013, 05:31 AM   #9
repairman54
CMF Junior Member
2009 Malibu LS 2.4
Carbon Mist Met.
repairman54's Avatar
Garage
Floored gas pedal to get it to start is a symptom of a leaky injector. Leak down test is the diagnosis for that. Fuel pressure gauge attached and seeing how long it holds pressure is the test. Don't know if there is a pressure port on your car though, someone more familiar will know that.
John
"some suffer from insanity, I choose to enjoy it"
09 Malibu LS
07 Mustang GT 3 pedals
99 Yukon
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
repairman54 is offline   Reply With Quote
Old 01-26-2013, 10:44 AM   #10
scott37300
CMF Junior Member
2009 Malibu 2LT
Black
I just looked in the service manual and the 2.4 and 3.6 should have a service port schrader valve.
What is normal for time for the fuel pressure leak down test? Minutes or hours and how much of a drop is normal?
Is a leaky injector something that can be fixed with a good fuel injector cleaner(like what the dealers use) or do you just replace the injector?
You may not post new threads
You may not post replies
Standard Remote Start for 2010 1LT TX Malibu General Discussion (Generation 7) 33 02-22-2012 02:25 PM
2003 Malibu LS cranks will not start when cold mike wiz Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 12-07-2011 10:37 AM
Cranks But Won't Start stnewton09 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 03-22-2011 06:53 AM
97 6cyl cranks but doesn't start stevegantt Problems/Service Issues/Troubleshooting (Generations 5 & 6) 0 03-16-2011 03:49 PM
2010 2LT Remote Start and Climate Control? savatage General Discussion (Generation 7) 5 10-01-2010 02:06 PM
