Charging system not charging. - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 01-25-2013, 05:03 PM   #1
petek157
Black Metallic
Default Charging system not charging.
I bought a lightly smashed 13 Eco. I've got everything fixed and now with my computer hooked up says the charging system isn't working. Any thoughts? I've spent 5 hours checking for disconnected wires and things of that sort. No joy. Looking for some suggestion before I spend another 5 hours looking.
Thanks in advance
Peter
petek157 is offline   Reply With Quote
Old 01-25-2013, 06:27 PM   #2
humblebeast07
CMF Junior Member
2013 Malibu 2LZ
Black/Black
humblebeast07's Avatar
Default Re: Charging system not charging.
I also have a question about the charging system. as you can see i have the 2.0t and if i sit and watch the volt meter on the display its slowly goes from 14 to 12.5 or so volts back up to 14 or so, its not effected by the lights stereo, or even rpms, is it designed to do that to extend the life of the battery?
2013 Malibu 2LZ Blk on Blk
5%Tint/Debadged
humblebeast07 is offline   Reply With Quote
Old 01-25-2013, 07:02 PM   #3
BruEmbry
2013 Malibu Eco 2SA
Champagne
Hi,
I have noticed this behavior on the 13 Malibu Eco. The 12 volt battery voltage will only be charge after it drops to a certain low voltage. I have-not been able to determine at what voltage level that the batter will be charged. This cycling of the battery should; 1) entend the iife, and 2 increase fual efficancy.
BruEmbry is offline   Reply With Quote
Old 01-26-2013, 03:55 AM   #4
nutcrunch
CMF Veteran Member
nutcrunch's Avatar
Garage
Everytime I check ours it is right on 14.25V, I've never seen it drop.
2013 Malibu ECO 1SA PCN pkg
White Diamond Tricoat
50/35 tint
nutcrunch is offline   Reply With Quote
Old 01-26-2013, 05:34 AM   #5
tradosaurus
CMF Junior Member
2013 Malibu Eco 1SA
Silver
If your car is still under warranty, which it should since it's less than a year old, then take it to the dealer with your concern.
tradosaurus is offline   Reply With Quote
Old 01-26-2013, 07:03 AM   #6
ElantraMax
CMF Senior Member
Belt Slipping?? Or the Voltage Regulator in the Alternator is going bad.
Escapemax, Aka: Elantramax
2013 Hyundai Elantra Coupe GS
ElantraMax is offline   Reply With Quote
Old 01-26-2013, 07:11 AM   #7
ElantraMax
CMF Senior Member
I just had a thought here. My Elantra has a Clutch on the pulley of the alternator. Its used to improve MPG. By reducing the load on the engine. The Clutch (Like on an AC compressor) is controlled by the PCM. I replaced an alternator on a Toyota. Because the Clutch wasnt engaing.
Old 01-26-2013, 08:37 AM   #8
nutcrunch
CMF Veteran Member
nutcrunch's Avatar
Garage
The Eco doesn't have an alternator.
50/35 tint
Old 01-26-2013, 08:52 AM   #9
petek157
Black Metallic
Still looking... As for the warranty, I live over an hour from my nearest dealer. Thats why Im trying to find it first, cause I dont think that it will hold a charge long enough to get me there. The only other option would be to tow it there, but I am not sure if towing is covered under the warranty and Im trying not to spend to much more getting the car on the road. So that being said still looking for suggestions.
Pete
Old 01-26-2013, 09:09 AM   #10
nutcrunch
CMF Veteran Member
nutcrunch's Avatar
Garage
If your car breaks down then they will tow it to the nearest dealer for you.
You say the car was "lightly smashed", did this wreck or whatever happened damage the parts that affect the charging? If so it will more than likely not be covered under warranty.
50/35 tint
You may not post new threads
You may not post replies
HTML code is On
DRL System bve32k General Discussion (Generations 5 & 6) 25 05-19-2013 06:13 AM
Electrical system upgrades for sound system??? kaydennicholson Modifications (Generation 7) 12 01-04-2013 07:20 AM
Re-charging AC the right way; with problems :( pnasty101 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 10 06-24-2012 01:42 PM
Need to flush my coolant system, power steering system, and transmission system. HELP kpointer25 Do It Yourself Maintenance (Generations 5 & 6) 4 12-13-2011 09:06 PM
Headrest DVD system maliWHO Modifications (Generation 7) 7 08-27-2009 02:38 AM
