TPMS question (again I know) - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 02-05-2013, 01:30 PM   #1
morando6784
2010 Malibu 2LT
white
Default TPMS question (again I know)
Whats up guys new owner here, picked up a 10 LT loaded very happy, my first post. Sorry im sure this is brought up lots of times on here, i looked around a bit and kinda think i know the anwser to my question but then a couple things confused me in other threads. Ive never delt with TPMS before so trying to figure it out.
My question is i want to put after market rims on my car. Do the sensors just swop over? One thread sounded like the factory rims are threaded at the vavle stem hole on wheel and they will not work on aftermarket. Is there after market sensors that work on aftermarket wheels? Can someone straighten me out please.
morando6784 is offline   Reply With Quote
Old 02-05-2013, 08:47 PM   #2
TSquare
CMF Junior Member
2011 Malibu LS
Gold Mist
TSquare's Avatar
Gallery: 2
Default Re: TPMS question (again I know)
I believe the TPMS includes the valve stem. So, if you are comfortable moving valve stems from one rim to another, go for it. I'm not sure what the chances of damaging the TPMS is when it is removed.
2011 Malibu LS
Gold Mist
TSquare is online now   Reply With Quote
Old 02-05-2013, 09:15 PM   #3
morando6784
2010 Malibu 2LT
white
So the valve hole on the rim is not threaded ? Is there a nut on on outside of wheel on stem and a seal on other side of stem that hold it in place and air tight?
Old 02-06-2013, 01:08 AM   #4
Speed_Freak5150
1999 Forester
Gallery: 2
You will move the sensors over to the new wheels, but the stem part should be changed out. When I had my tires replaced that is what they did.
01 Malibu ls
99 Subaru Forester
10 Malibu 1LT
Speed_Freak5150 is online now   Reply With Quote
Old 02-06-2013, 07:39 AM   #5
morando6784
2010 Malibu 2LT
white
So are the stems the same as any other stem or they diffrent for the sensors. So i guess what im getting at do sensors mount to any wheel, nothing special about the wheel itself?
Old 02-06-2013, 06:33 PM   #6
Dilatory
CMF Senior Member
2011 Malibu LS
Gold Metallic
The valve stems are generic AFAIK however it's the valve core that is specific to the sensor.
Dilatory is offline   Reply With Quote
Old 02-07-2013, 06:12 PM   #7
Answer069
CMF Senior Member
2005 Malibu LS
Galaxy Silver Met.
Answer069's Avatar
Garage
As someone who had worked at a Chevy dealership I can tell you that the valve stems are NOT generic. The sensors screw onto the bottom of the valve stems on the newer vehicles. so yes you can swap the sensors but you will need to buy new valve stems because you will most likely damage the valve stem trying to remove them.
Patrick
2005 Chevy Malibu LS "Galaxy Silver Metallic"
Debadged!!!!!!
http://www.mpgtune.com/user-profile.php?userId=3564
Born: 3/15/2005 Fairfax, KS
Died: 12/272012 RIP
Answer069 is offline   Reply With Quote
Old 02-08-2013, 05:38 AM   #8
morando6784
2010 Malibu 2LT
white
Thank you that exactly what i was trying to find out ^^^^^^^
Old 02-10-2013, 12:46 PM   #9
BillD64
CMF Senior Member
BillD64's Avatar
You should also know that not all aftermarket wheels are compatible with tire pressure sensors. The wheel's construction may not allow enough room to mount the sensor at the valve stem hole. Too solve that problem people use straps to mount them to the barrel of the wheel. Depending on the wheel spokes and where the sensors are fastened it could make the sensors harder to program if you can't get the tool close to them when the wheel is mounted on the car.
BillD64 is online now   Reply With Quote
Old 02-11-2013, 06:03 AM   #10
morando6784
2010 Malibu 2LT
white
what happens if you don run the senors? Is there just a pressure light on? Im getting a set of 20s and there already mounted and ready, so would it be ok if i just waited till i got around to pulling my sensors off my stocks and mount them later, it will just have that light on till i get them put on correct. Theres not some crazy setup to were it wont let me drive it is there, you never with these new vehicals.
You may not post new threads
You may not post replies
TPMS, Center Caps and Tire question Dilatory Wheels, Tires & Suspension (Generation 7) 6 01-19-2013 08:42 AM
TPMS Question gmitch2LT Problems/Service Issues/Troubleshooting (Generation 7) 17 10-15-2012 08:40 AM
TPMS question twiztedtrav Wheels, Tires & Suspension (Generation 7) 8 08-02-2010 08:26 AM
Question for folks who have done a reset of the TPMS Speedster Do It Yourself Maintenance (Generation 7) 7 08-06-2009 12:30 AM
Question about winter tires with TPMS Yury General Discussion (Generation 7) 12 12-03-2008 06:45 PM
