Changing the drive belt tensioner on 2000 3.1... - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 01-18-2009, 09:21 AM   #1
smokey80015
Default Changing the drive belt tensioner on 2000 3.1...
Does the belt need to be completely removed to change the tensioner? Removing the belt requires disconneting a motor mount and slightly lifting the engine.
I was hoping that it would be a simple matter of releasing the tension, unbolting the tensioner, replacing it, etc. etc.
Any help appreciated.
smokey80015 is offline   Reply With Quote Quick reply to this message
Old 01-31-2009, 11:21 AM   #2
nighthawk-24
CMF Senior Member
nighthawk-24's Avatar
Gallery: 1
Default Re: Changing the drive belt tensioner on 2000 3.1...
This forum does not really cover these issues because it is for the new Chevy Malibu, but I might be able to help. What motor is it? If it is a 3.1 liter then I believe you are stuck with the information you previously posted. That goes the same for a 3.4 liter. If it is a 3.3 liter then you have to remove the belt first, but there is no motor mount in the way. You might be able to disconnect the belt and hang it over the motor mount so its out of the way untill you are done with the tensioner.
2008 Chevy Malibu 2LT
Imperial Blue Metallic
3.6 VVT & 6 Speed Auto
05/08 Lake Orion
Colormatched Bowties
20% Tint
nighthawk-24 is offline   Reply With Quote Quick reply to this message
Old 02-01-2009, 07:26 AM   #3
Malibu Glow
CMF Senior Member
Malibu Glow's Avatar
To REPLACE the belt you have to disconnect the motor mount on the passenger side of the car and lift the engine with a jack and piece of wood placed carefully on the oil pan. Mine is a 2000 with the 3.1 and I've replaced the belt on mine having to do this just to remove the belt. This goes for all N-body cars with the 3.1 and 3.4 V6.
As far as replacing the tensioner you should just be able to take the tension off the belt and slip it off the pulleys so you can access getting to the tensioner to remove the bolts holding it. Then just reverse of removal for both parts
Malibu Glow is offline   Reply With Quote Quick reply to this message
Old 02-09-2009, 09:14 PM   #4
green03malibu
CMF Senior Member
2003 Malibu LS
Drk Green Metallic
green03malibu's Avatar
ugh i hated changing my belt. yes, as glow said, the passenger side mount has to be removed and jacked. its a pain, but good luck with everything.
green03malibu is offline   Reply With Quote Quick reply to this message
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
2000 Malibu Mods ryan71489 Modifications (Generations 5 & 6) 1 01-04-2010 06:21 PM
What did you drive before? FenwickHockey65 General Discussion (Generation 7) 77 12-17-2008 10:36 AM
2000 Chevy Malibu OnTheMarkTexas General Discussion (Generation 7) 7 11-29-2008 10:29 PM
LURGING/HESITATING - 2000 Malibu sinnedwahs General Discussion (Generation 7) 0 11-06-2008 05:56 PM
What is changing for 2009? barhoc11 Buying and Leasing (Generation 7) 19 09-20-2008 10:25 AM
