How-To: Reset TPMS Sensor - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 01-24-2009, 09:03 AM   #1
08LTZ
CMF Senior Member
Default How-To: Reset TPMS Sensor
The TPMS matching process is outlined below:
Set the parking brake.
Turn the ignition switch to ON/RUN with the engine off.
Press and hold the Remote Keyless Entry (RKE) transmitter's LOCK and UNLOCK buttons, at the same time, for about five seconds to start the TPMS learn mode. The horn sounds twice indicating the TPMS receiver is ready and in learn mode.
Start with the driver side front tire. The driver side front turn signal also comes on to indicate that corner's sensor is ready to be learned.
Remove the valve cap from the tire's valve stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for about eight seconds. The horn chirp, can take up to 30 seconds to sound. It chirps one time and then all the turn signals flash one time to confirm the sensor identification code has been matched to the tire/wheel position.
The passenger side front turn signal comes on to indicate that corner sensor is ready to be learned. Proceed to the passenger side front tire and repeat the procedure in Step 5.
The passenger side rear turn signal comes on to indicate that corner sensor is ready to be learned. Proceed to the passenger side rear tire and repeat the procedure in Step 5.
The driver side rear turn signal comes on to indicate that corner sensor is ready to be learned. Proceed to the driver side rear tire, and repeat the procedure in Step 5.
After hearing the single horn chirp for the driver side rear tire, two additional horn chirps sound to indicate the tire learning process is done. Turn the ignition switch to LOCK/OFF.
If no tires are learned after entering the TPMS learn mode, or if communication with the receiver stops, or if the time limit has expired, turn the ignition switch to LOCK/OFF and start over beginning with Step 2.
Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
Put the valve caps back on the valve stems.
The Offical Chevymalibuforum.com 100th Member.
08LTZ is offline   Reply With Quote Quick reply to this message
Old 01-24-2009, 10:38 PM   #2
Joeyavhu
CMF Veteran Member
2013 Malibu LTZ
Black Granite
Joeyavhu's Avatar
Garage
Default Re: TPMS Reset Procedure
Holy Moly. Lol
When would you need to do this anyway?
Joeyavhu is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 03:56 AM   #3
beach
CMF Veteran Member
beach's Avatar
Originally Posted by Joeyavhu View Post
Holy Moly. Lol
Anytime you change a wheel/tire from its original position, such as when you rotate them.
'10 Camaro 2LT RS
Momma wanted some power...
'08 Malibu 2LT 4-cyl...TRADED
Dark Gray Metallic, Titanium UltraLux
___________________________________
'09 Pontiac G8 GT
The new ride...
'09 Malibu 2LT V6...TRADED
MPGTune.com Mileage History
beach is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 06:38 AM   #4
Joeyavhu
CMF Veteran Member
2013 Malibu LTZ
Black Granite
Joeyavhu's Avatar
Garage
Ohh... Okay, I did not think of that.
Old 02-03-2009, 12:41 PM   #5
Speedster
CMF Senior Member
Is this in the owner's manual? How are we supposed to know this? Better yet, how would any mechanic know to do this after rotating the tires??
2009 Chevrolet Malibu LS
Summit White
Speedster is offline   Reply With Quote Quick reply to this message
Old 02-03-2009, 05:25 PM   #6
chief791
CMF Junior Member
chief791's Avatar
wow...i never thought it would take less time to rotate the tire then to reset the sensor.
chief791 is offline   Reply With Quote Quick reply to this message
Old 02-03-2009, 06:13 PM   #7
hoahai
CMF Senior Member
Yes, it is in the user manual, starting on page 5-56. Dealer Mechanics should know about it but don't expect others to know. You would not want other low-pay (such as Sam's club, etc..) mechanics to touch them any way. They likely will mess them up.
Even if you don't re-match them, it should not be a big deal. There are only 4 tires. If the alarm comes on, you can just check all of them.
08 2LT White/Titanium, 4cyl/4spd
Born 04/08 Lake Orion
hoahai is offline   Reply With Quote Quick reply to this message
Old 02-04-2009, 07:17 AM   #8
Yury
CMF Veteran Member
Yury's Avatar
Gallery: 18
You can follow these steps in 10 minutes easily. It sounds worse than it is
Dealer would do it even faster, they have a special device for matching.
1999 Honda Prelude base, 5 speed
2008 Toyota Yaris 4 door hatchback, auto
Yury is offline   Reply With Quote Quick reply to this message
Old 02-11-2009, 06:06 PM   #9
Pintoracer
Pintoracer's Avatar
Gallery: 3
I did my first rotation tonight! took about 45 min. using hand tools. No problems reseting the sensors. Easy as pie!!!!!!
Bryan
09 Malibu 1LT Silver Ice Metallic, 2.4L with 6-speed
07 Silverado 2LT Crewcab Classic, Garnet Red Metallic
Pintoracer is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 07:14 PM   #10
ElantraMax
CMF Veteran Member
Strange, I Rotated my tires at 6,000 Miles. Never did this. Now I have 10,400 Miles and no lights. And mine does read the actual pressure in each wheel.
Escapemax
Formerly EscapeMax
2013 Hyundai Elantra Coupe GS
2010 Yamaha Majesty (YP400)
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
TPMS sensor problems JeffreyRosskopf Wheels, Tires & Suspension (Generation 7) 2 04-12-2011 09:23 AM
HELP - How do I reset the remote? johnkris1 General Discussion (Generation 7) 5 03-06-2010 08:33 AM
Question for folks who have done a reset of the TPMS Speedster Do It Yourself Maintenance (Generation 7) 7 08-06-2009 12:30 AM
Oil Reset Question Mudlizard General Discussion (Generation 7) 8 04-28-2009 10:19 AM
