Front Suspension Noise - Page 3 - Chevy Malibu Forum: Chevrolet Malibu Forums
Closed Thread
Old 12-17-2009, 10:18 AM   #21
Macleod52
CMF Senior Member
Macleod52's Avatar
Default Re: Front Suspension Noise
I'm getting a rattling noise from my front end. Sounds like the typical strut mount issue that I've seen in numerous GM vehicles.
'09 Malibu LTZ
Ecotec w/A6
Black Granite Metallic
Capitalization & punctuation is the difference between "I helped my uncle, Jack, off a horse." and "I helped my uncle jack off a horse."
Macleod52 is offline   Quick reply to this message
Old 12-19-2009, 09:21 PM   #22
dandaco
CMF Junior Member
My 2008 Bu's front suspension was making clunking noises when driving over washboard type roads. Dealer replaced rack and pinion..... seems to have worked.
dandaco is offline   Quick reply to this message
Old 01-09-2010, 12:32 PM   #23
Threxx
I'm new here... I have an 09 Aura XR-4 and I've always thought the struts were kinda loud when going over bigger bumps at any temperature, but I figured maybe I was expecting too much... before this I was driving cars quite a bit more $$ so I figured maybe the refinement level dropped a bit with price tag.
But then a couple days ago the lows got below 10 here in the Memphis area and as I was driving through some not so smooth parking lots I noticed the struts sounded like they were loose or rattling, almost like what a strut sounds like at 100-150k miles when it has given up on life. The noise seemed to go away after only 5-10 minutes of driving... I guess they warmed up or something.
That's when I decided to search on google for Malibu and Aura strut noises and this thread was the first result.
What frustrates me is that so many people on here seem to have completely different things that fixed it for them which means the local Chevy dealer is probably going to have to hear it happen on my car and since for the time being this appears to be a fairly rare symptom (sub 20 degree temps, only when car has been sitting for a while and isn't warmed up) it will be pretty hard to demostrate it for them. If this was a known specific issue and fix I'd say they wouldn't even have to hear it, they'd just have to perform the known fix... which is why this post really interests me:
Originally Posted by Jewelsedge View Post
This is a top mount problem...it has been replicated at Milford Proving Grounds and the engineers at VEC are working on it without a proven fix yet. This is occurring on my 09 LTZ - apparently the only "solution" at this point is to have the top mounts swapped out. (the top mount is the large rubber circular piece at the top of the strut tower) Engineering knows of the problem - happens at low speed / cold temperatures.
Did this result in a TSB of any sort?
Threxx is offline   Quick reply to this message
Old 01-19-2010, 05:31 PM   #24
Jewelsedge
I brought my 09 LTZ in again for this problem just after xmas - dealer replaced drop links (stab bar to shock tower loose - or so they claimed). Still have the strut noise on low speed/cold temp. I don't even need to hit a bump, can just be uneven blacktop - every undulation in the pavement and the struts rattle. I am just going to keep bringing it in when I have time - it's crazy!. I will have to take the tech for a ride to demonstrate the issue I guess. I still am trying to get to the engineer again to see if they found a fix - haven't had a chance to get over to GM Tech center lately. Stay tuned........
Jewelsedge
Detroit 'Burbs
'09 LTZ
Summit White
Jewelsedge is offline   Quick reply to this message
Old 01-19-2010, 10:16 PM   #25
dennisk
CMF Junior Member
I've had my upper mount replaced. Still making the clunking noise, just like you over uneven blacktop or hitting a bump. Same year, 09 LTZ. Out of curiosity, where was yours built? You can tell whoever you talk to that there are other 09 LTZs with the same problem you're having, and would like an answer.
Out of curiosity, what is the GM tech center?
If you get an engineer to look at it, please keep us informed, I would like to go back to the dealer with some information, as they seem to be running out of ideas, and instead of them holding onto my car for 2 weeks changing misc. parts to hope to fix it, it would be nice if i can say look up a certain tsb or something.
By chance, do you also have an issue where the steering wheel doesn't return to center smoothly? Like you can feel a slight pulsation as you come out of a turn? I've had new tires, new steer gear, new steering rack, new axles put on and its still a problem. I swear i think its the tires, but the dealer refuses to believe so, since they put new ones on, but they said they'd look at it. Last time my car was there 2 weeks and it wasn't fixed, and I want to drive my $30k car and not a base model G6.
good luck!
dennisk is offline   Quick reply to this message
Old 01-20-2010, 10:41 AM   #26
nick125
I'm having the exact same problem with my '09 G6. It doesn't happen over every bump, but close enough. It's like a light knock.
I took it to the dealer, but they couldn't find the issue. They told me that if I came back with the issue again, they were planning on ripping out the dash, as they thought that's where the noise was coming from. They also said that it would likely make the noise even worse..yeah, I think they were just trying to get me to not come back. I'm tempted to try another dealer and see what they say.
nick125 is offline   Quick reply to this message
Old 01-20-2010, 02:15 PM   #27
Brossard
CMF Senior Member
2008 Malibu 2LT
Imperial Blue
Brossard's Avatar
I own a 2008 LT2 with 18K miles and have the same clunk coming from the front of the car. One month ago, my dealer changed my 2 front shocks and the clunk disappeared to reappeared 30 miles later! I clearly hear the clunk below 30 m/hr at every pavement imperfections which is really annoying in city driving. It seems more related to steering area as it is more audible from the driver seat than the passenger seat.
I will return to the dealer again and let you all know what parts they will change this time.
2008 Malibu 2LT 2.4L Imperial Blue, Rear Trunk Lip and Window Spoilers, Chrome Pillar Posts and Handles, Tinted Windows and Personal Audio Link (PAL) for Ipod.
Brossard is offline   Quick reply to this message
Old 01-20-2010, 05:43 PM   #28
Silver LTZ
CMF Honorary Member
Silver LTZ's Avatar
Gallery: 3
You guys sure it isn't steering related? I had a "clunk" and it turned out to be the steering rack. All fixed now....
Silver LTZ is offline   Quick reply to this message
Old 01-20-2010, 06:27 PM   #29
nick125
I know that on the G6, the steering clusterfsck was supposely fixed for the '09 models. With that said, I did hear a clunk once when I was turning from the left 'stop' to the right. I'm at a loss as to what to do.
I might take it back to the dealer, but it's probably unlikely to fix anything. I am so fed up with the dealer and their incompetency. It took them three weeks to order a set of replacement wiper blades, and they didn't bother to call when they finally arrived. I'm also having some really nasty tire wear, where it looks like the outside 'rim' of the tire is almost bald, while the inner "rim" of the tire looks fine. Took it to the dealer, they said it was fine. For a car with less than 4,500 miles, the tires shouldn't be looking this bad. The tires on my mother's '00 Malibu, which have ~15,000 miles on them, have less wear on them.
On a side note, honestly, I'm really sorry I bought this car. I really thought that GM had done something to improve their quality.
Sorry for the rant. If anyone has any ideas, I'll be happy to hear them.
Old 01-21-2010, 03:25 AM   #30
jeepgrady
CMF Senior Member
2010 Malibu LTZ
Mocha Steel
jeepgrady's Avatar
One idea is to insist on new tires. If they say it's fine and the wear is that bad at only 4500 miles, they should replace them.
2010 Malibu- LTZ, 4cyl./6 speed, Mocha Steel Metallic
jeepgrady is offline   Quick reply to this message
Closed Thread
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Acceleration Noise B-RAN Problems/Service Issues/Troubleshooting (Generation 7) 9 06-04-2009 10:23 AM
Vibration flex creak noise fjhoeft Problems/Service Issues/Troubleshooting (Generation 7) 12 01-31-2009 10:44 AM
Some questions (suspension, paddle shift) Yury General Discussion (Generation 7) 24 09-03-2008 06:44 AM
Looking for suspension kits for my 07 pantzarproperty Modifications (Generation 7) 6 05-15-2008 10:38 AM
