Adding OEM fog lights - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 07-19-2013, 08:37 AM   #1
TenTwelve
2013 Malibu LS
Taupe Gray
Default Adding OEM fog lights
I've been able to easily find the parts to install some factory fogs on my LS. My question... Is there wiring at the bumper and in the dash for the different switch?
Thanks for any insight.
TenTwelve is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 09:52 AM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: Adding OEM fog lights
probably all the wiring will need to be run. It might be at the dash but everywhere else it will not be there.
Old 07-19-2013, 10:21 AM   #3
TenTwelve
2013 Malibu LS
Taupe Gray
How can I find out how much of the harness I'd need?
Old 07-19-2013, 10:39 AM   #4
Rodents
2011 Malibu 2LT
Start pulling it apart. Most of the time anymore, there are not too many instances where wiring is supplied from the factory for options the vehicle doesn't have. Assuming the underhood fuse block has the required terminals for the relay and the fuse for the fog lamps, you need to run wiring to the BCM, for relay control, you'd need a switch, part of the headlamp switch by the schematics, and then the wiring to the lamps themselves. Then you'd need to have the BCM reprogrammed for the fog lamps as well. That might be the hard part. Never tried it outside of installing a factory accessory kit. There's an authorization number that comes with the kit and we use that for getting the software changed. Now this would be what I've done in the past for a Cruze. Cruze no longer needs that programming so maybe the gen 8 Malibu BCM is ready to go, maybe not, I don't know that, never been down that road. The wiring you need to do is all fabrication, not factory harnesses.
Old 07-19-2013, 10:56 AM   #5
TenTwelve
2013 Malibu LS
Taupe Gray
Damn that sounds complicated. Ugggh...
Old 07-19-2013, 01:52 PM   #6
Rodents
2011 Malibu 2LT
Yeah, sorry, that's how it is anymore. Every year it seems to get more complicated. It's tough even in a dealership like I am. The info I have to work with isn't always accurate or complete, we're on a 'need to know basis and we don't need to know' some things evidently. Todays cars work on different levels depending on factory option content so adding something seemingly simple isn't as easy as it should be or used to be. For example adding a factory navigation radio to a non factory equipped car isn't done. I'm not saying adding the fog lights can't be done, it's not going to be easy or cheap to do it with factory parts. I can help you with terminals and wiring diagrams if you can get someone to cooperate and get the BCM setup done. I'm not actually sure what needs to be done with the BCM, if anything. I would need a donor vehicle to find out and I don't have a spare gen 8 hanging around right now.
Old 07-19-2013, 04:57 PM   #7
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
An alternate choice is to install the fog lamps, add a "regular" switch in the cabin that controls a "regular" relay under the hood that turns them on and off. Simple, inexpensive, and likely to last years and years without an issue!
Muffler mod on '09
Old 07-19-2013, 06:42 PM   #8
TenTwelve
2013 Malibu LS
Taupe Gray
Yeah, I was thinking of doing just that but, I was thinking I could still use a stock switch and just tap the harness for relay control. I'm fairly decent with wiring.
Oh, and Rodents thanks for the additional info. I may definitely hit you up for diagrams and pin-outs.
Old 07-20-2013, 02:16 AM   #9
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
The stock switch is momentary so you'll need to find or devise a circuit that'll flip flop on actuation, but that'll also keep the stock look.
Muffler mod on '09
Old 07-20-2013, 08:37 AM   #10
2013 LTZ
CMF Senior Member
2013 Malibu 2LTZ
Atlantis Blue
Use the stock switch and a "latching relay" you can buy one anywhere they sell car alarm stuff.
2013 LTZ is offline   Reply With Quote Quick reply to this message
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
how to wired oem fog lights using factory switch jjchannels Do It Yourself Maintenance (Generations 5 & 6) 3 03-15-2013 04:18 AM
Add OEM fog lights to LS jtblazeltw Modifications (Generation 7) 91 09-18-2012 05:00 AM
make it so your fog lights stay on when turn brite lights on kyleer Modifications (Generation 7) 5 06-05-2011 02:53 PM
Adding OEM Remote Start nhraman Modifications (Generation 7) 3 12-11-2010 01:23 PM
Adding Fog lights to 06 lt? Talamantez Modifications (Generations 5 & 6) 3 08-22-2010 08:53 PM
