questions - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 06-03-2009, 10:45 AM   #1
moreno24
Default questions
ok i have 2001 malibu with an 04 motor and my cooling fans wont turn on but if i unplug the thermostat sensor the fan kick on but i dont know what temp the is running at
help please...
in advance thanks
moreno24 is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 11:53 AM   #2
Macleod52
CMF Senior Member
Macleod52's Avatar
Default Re: questions
I believe the fans only kick on once your thermostat reaches a certain temperature. The fan is not supposed to run all the time. Also, if I'm not mistaken, it should turn on when you turn your A/C on.
'09 Malibu LTZ
Ecotec w/A6
Black Granite Metallic
Capitalization & punctuation is the difference between "I helped my uncle, Jack, off a horse." and "I helped my uncle jack off a horse."
Macleod52 is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 12:45 PM   #3
bf1942
CMF Junior Member
Cool Re: questions
MOreno,
I had a problem with my fan on my 83 J2000, and ended up soldering a switch in line.
Most of the time I ran it with the fan on and never had a problem.
After the engine had warmed up,
The fan was never able to lower the engine temp to much , and usually cooler is better.
bf1942 is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 01:05 PM   #4
OnDaGround
CMF Junior Member
OnDaGround's Avatar
The fan should only come on if the car is running too hot, the a/c is on or defroster is on.
The sensor you pulled is not called a t-stat sensor. Its an ECT. Engine Coolant Temperature sensor. It probably just needs to be replaced if there is an actual problem.
From what it sounds like, you are assuming the fans should be on all the time. Which would be incorrect.
"If your boyfriend says he's got beef.... tell him I'm a vegetarian and I ain't f___ing scared of him." - 3oh3
OnDaGround is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 01:34 PM   #5
OnDaGround
CMF Junior Member
OnDaGround's Avatar
In a sense yes. There is a reason it only kicks on sometimes. The engine runs at its best when it's at operating temp. Otherwise it will just run rich.
Old 06-03-2009, 02:34 PM   #6
TMoneyR523
CMF Veteran Member
2008 Malibu 2LT
Black Granite
TMoneyR523's Avatar
Gallery: 14
Send a message via AIM to TMoneyR523 Send a message via Skype™ to TMoneyR523
One time I drove to Cape Cod and when I stepped out of my car I did notice there was an engine fan that ran for about 3-5 minutes after I had shut the car down.. does that mean it was running too hot? That temperature gauge thing was showing normal "just under the half-way point".
2008 Chevrolet Malibu 2LT V6
Black Granite Metallic, Ebony UltraLux
HFV6 Engine Package, Premium Mats, Sunroof
Built: Fairfax Assembly Centre - Kansas City, Kansas.
TMoneyR523 is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 02:47 PM   #7
Macleod52
CMF Senior Member
Macleod52's Avatar
Normally when you're sitting a stop the fans will kick on since there isn't any air flow to cool the radiator off. I would assume the same thing when you shut the car off. It's normal.
'09 Malibu LTZ
Ecotec w/A6
Old 06-05-2009, 02:01 AM   #8
moreno24
i know the fans dont run all time but they never kick on unless i unplug the sensor which i already replaced i tried cutting on the a/c and they still dont kick on the needle gets close top so i believe the should kick on and the over flow tank is always dropping coolant
Old 06-05-2009, 10:17 AM   #9
cavalier2000
CMF Senior Member
cavalier2000's Avatar
teh fan comes on when you disconnect the coolant temp sensor. try replacing it
cavalier2000 is offline   Reply With Quote Quick reply to this message
Old 06-05-2009, 10:31 AM   #10
OnDaGround
CMF Junior Member
OnDaGround's Avatar
+1 That's what I recommend you do.
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
HTML code is On
Front Grill Questions?? Darren Modifications (Generation 7) 4 05-18-2009 05:22 AM
Two quick questions... 86lxjunker General Discussion (Generation 7) 10 04-14-2009 05:05 PM
A few questions about 09 Malibu Sparky General Discussion (Generation 7) 4 03-17-2009 05:44 PM
2009 LS - a bunch of questions MoJ General Discussion (Generation 7) 11 09-13-2008 06:16 AM
a few questions and or gripes... DieZel General Discussion (Generation 7) 4 08-24-2008 01:37 PM
