Remote Start? - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 06-10-2009, 11:24 AM   #1
SliverMossMan
Default Remote Start?
I wonder if anyone has had this problem or I just dont know how to work the remote start. Sometimes it works and sometimes it doesnt. I lock the doors and press the button and old it down. I know its only supposed to take 4-5 seconds but I get nothing. Then at other times it works ok.
2009 Chevy Malibu 2LT
Silver Moss Metallic
Ebony Interior
2.4L DOHC MFI
6-Speed Auto.
SliverMossMan is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 11:45 AM   #2
ISsecure
Default Re: Remote Start?
If you are close enough to the car, i.e. if doors lock themselves and you see the lights flashing once, then press and hold the remote start button immediately. If you wait a few seconds, it won't start.
>> Malibu 2008 1LT 4cyl 4speed own since 03/2008 <<
ISsecure is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 11:47 AM   #3
Yury
CMF Veteran Member
Yury's Avatar
Gallery: 18
I think it limits the number of times in a row you can use it. I.e if you use the fob and go start-stop, start-stop, eventually it will refuse as far as I remember. I was trying to fix my defroster and I remember at some point it just started flashing the lights and not starting.
It also will not work if the hood is open, or if you're trying to extend the remote start running time more than once.
1999 Honda Prelude base, 5 speed
2008 Toyota Yaris 4 door hatchback, auto
Yury is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 11:58 AM   #4
TMoneyR523
CMF Veteran Member
2008 Malibu 2LT
Black Granite
TMoneyR523's Avatar
Gallery: 14
Send a message via AIM to TMoneyR523 Send a message via Skype™ to TMoneyR523
Well this doesn't really answer your question but it follows up on Yuri's response.. the vehicle will only allow you to remote-start two times before you must put the key in the ignition.. I don't recall why this is (petrol saver?).. but yeahhhhhhhhhhhhhhh
2008 Chevrolet Malibu 2LT V6
Black Granite Metallic, Ebony UltraLux
HFV6 Engine Package, Premium Mats, Sunroof
Built: Fairfax Assembly Centre - Kansas City, Kansas.
TMoneyR523 is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 12:36 PM   #5
slhaas
CMF Senior Member
slhaas's Avatar
Gallery: 13
Yeah, hit lock twice.
Make sure you're close enough (if you lock it, you should be)
Be sure you hadn't recently started via remote start. You're only allowed 2x before resetting.
slhaas is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 01:10 PM   #6
Macleod52
CMF Senior Member
Macleod52's Avatar
Just throwing this out there since I don't know your procedure, but if you're coming out in the morning to start the car (example...) you have to press the lock button first (even though the car is already locked) then press the start button for 2-4 seconds. This is of course assuming you're within range and your key fob's battery isn't low.
'09 Malibu LTZ
Ecotec w/A6
Capitalization & punctuation is the difference between "I helped my uncle, Jack, off a horse." and "I helped my uncle jack off a horse."
Macleod52 is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 01:33 PM   #7
ISsecure
Also, when you get nothing, do headlights flash when you hold the remote start button? If yes, then do you have Check Engine light on?
I agree with Yuri, the remote starter feature caan only be used twice, after that you have to put the key in :-)
And, all these suggestions were made under an assumption that you don't use an aftermarket remote starter, you use the one that is installed by GM.
Old 06-10-2009, 03:04 PM   #8
SliverMossMan
Well the car has been sitting in the garage for a while and I went to try it again. I lock the doors and then hold down the remote start button ( yes Factory Installed) it works fine. I let it run about 30 seconds and then turn it off with the remote to see if it will do it a second time. I lock the doors then hit the remote start the marker lights flash and then nothing.
Sometimes it wont do it the first time at all. I tried it with both remotes also with the same results. I may run it by the dealer to see what they say. Thanks for the info.
Ebony Interior
2.4L DOHC MFI
6-Speed Auto.
HTML code is On
Remote Start cavalier2000 General Discussion (Generation 7) 3 05-06-2009 07:19 AM
Oil leak when using remote start Gerry Do It Yourself Maintenance (Generation 7) 4 03-13-2009 11:01 AM
installed remote start, engine dies after start tonynikki0181 Modifications (Generation 7) 0 03-12-2009 11:40 AM
Advanced remote start Lee General Discussion (Generation 7) 36 02-19-2009 04:27 PM
is the 2 way remote start available yet? jmz768 General Discussion (Generation 7) 4 10-28-2008 05:05 AM
