Speaker Upgrade 2009 LTZ? - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 06-21-2009, 06:45 PM   #1
wxman13
CMF Junior Member
2009 Malibu LTZ V6
Summit White
Question Speaker Upgrade 2009 LTZ?
Just purchased a 2009 LTZ Malibu, wondering if anyone has upgraded the factory speakers? Crutchfield says I would have to put in a aftermarket radio if I upgrade the speakers?
wxman13 is offline   Reply With Quote
Old 07-03-2009, 04:59 PM   #2
wxman13
CMF Junior Member
2009 Malibu LTZ V6
Summit White
Cool Re: Speaker Upgrade 2009 LTZ?
Well, replaced the front speakers no problem, but the rears are a different story, they are wired seperately for the woofer and tweeter, anyone been successful in upgrading the rears in the premium radio LTZ?
I'll probably leave the factory ones in, I've got a annoying vibration in the rear deck, with even low bass tones, need to add some extra filler under the rear deck I suppose.
Old 07-06-2009, 10:56 AM   #3
beefenchilada
Default Re: Speaker Upgrade 2009 LTZ?
What kind of speakers did you use for the front?
I got the same rattle in the back too =(
beefenchilada is offline   Reply With Quote
Old 07-06-2009, 01:02 PM   #4
wxman13
CMF Junior Member
2009 Malibu LTZ V6
Summit White
I used Infinity Reference 6032si 6.5" 2-way Speakers in the front, I've decided for now to leave the rears alone. I am going to test a few things to try to fix the vibration in the rear deck.
Old 07-06-2009, 01:27 PM   #5
malibudragon
CMF Veteran Member
malibudragon's Avatar
Send a message via AIM to malibudragon
I took the rear panel off and placed B-Quiet Extreme (Dynamat type stuff) along the back deck lid and around the speakers along with the top of the trunk under the carpet and the back of the tag is coated with it as well.. Works decently enough
2009 Malibu LTZ V6 - Red Pearl : 5% Window Tint : 6 pc Chrome Pillars
malibudragon is offline   Reply With Quote
Old 07-07-2009, 04:06 PM   #6
nuclearxp
CMF Junior Member
Great stuff expanding foam will fill cracks and crevaces and deaden a ton of sound. Just make sure to tape off or cover areas you'd need to remove or access in the future.
nuclearxp is offline   Reply With Quote
Old 07-08-2009, 09:24 AM   #7
Nutz
How do you get to the speakers in the door and rear deck? I presume for the door you should pry off the panel somehow but does anyone have a good procedure?
For the rear deck, you can't get to the speakers from the trunk, and I can't figure out how to remove the deck.
Nutz is offline   Reply With Quote
Old 07-08-2009, 09:30 AM   #8
hockeyjay
How did you take the rear panel off?
hockeyjay is offline   Reply With Quote
Old 07-08-2009, 10:23 AM   #9
Macleod52
CMF Senior Member
Macleod52's Avatar
You have to be very careful when using the regualr great stuff, or the big gaps great stuff. It is strong enough to bow window and door frames, so just thing what it could do to sheet metal/plastic if done incorrectly.
'09 Malibu LTZ
Ecotec w/A6
Black Granite Metallic
Capitalization & punctuation is the difference between "I helped my uncle, Jack, off a horse." and "I helped my uncle jack off a horse."
Macleod52 is offline   Reply With Quote
Old 07-08-2009, 10:23 AM   #10
malibudragon
CMF Veteran Member
It sucks LOL,
Remove the 2 C Pillars first.. They snap off along with a teathered plastic cord you have to twist to pull out of the clip.. At the bottom they clip into the lower panels next to the seats,
Lay your seats down and remove the bolts along the back wall.. Then Behind the two outer most seat edges there are 2 large black plastic push in clips.. Get those out then just carefully lift and pull out the back panel.. Also dont forget to unhook the 3rd brake light before pulling it out
You may not post new threads
You may not post replies
stock stereo upgrade DonkRydah Modifications (Generation 7) 3 02-12-2010 05:36 AM
HD radio upgrade for Malibu. Anyone considered it? Speedster General Discussion (Generation 7) 1 05-20-2009 08:48 PM
Rear Speaker Access chiliNsuch Modifications (Generation 7) 0 01-08-2009 02:23 PM
Speaker and Subs Dunner General Discussion (Generation 7) 3 10-14-2008 08:16 AM
