Changing oil in 1999 Malibu - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 01-09-2010, 02:29 PM   #1
matroe11
Default Changing oil in 1999 Malibu
Hey guys. I have tried to use the search but it keeps telling me that my search term is too short and will not search no matter how many words I put in.
I have a new girlfriend who never changes or maintains her '99 Malibu. I want to change her oil and I would like to know a few things about the car before I attempt it. Any help, instructions, pics, etc would be greatly appreciated.
- How many quarts does it take?
- Are there any recommended procedures, special steps I should know about, shortcuts to make changing easier?
- I can't find the oil filter, where is it located?
- Does chevy use crush washers? What do you think is the most number of times they could be reused?
- I don't have her car with me at the moment, doing research, so are there any differences between the 4 cyl and 6 cyl?
- anything else you think I should know about?
Thanks in adavance!!!
matroe11 is offline   Reply With Quote Quick reply to this message
Old 01-14-2010, 09:00 PM   #2
dpopeck
CMF Junior Member
2009 Malibu 1LT
Silverstone
Default Re: Changing oil in 1999 Malibu
- I can't find the oil filter, where is it located? - Does chevy use crush washers? What do you think is the most number of times they could be reused?
4 qts for the 4 cyl., and 4.5 for the 6 cyl.
Underneath the car in the front, there is a plastic cover you need to remove. There are two wingnuts in the front. Either turn those by hand or use pliers, and then lower the front of the cover down a inch and then you can pull the cover forward (towards the front of the car). The back of the cover just has tabs that fit into slots. The oil filter will then be readily visible and very easy to get at.
No crush washer. Just don't go crazy over tightening the drain bolt!
No special procedures, the 1999 and 2003 Bu's are one of the easiest cars I've ever had in terms of oil changes.
dpopeck is offline   Reply With Quote Quick reply to this message
Old 01-15-2010, 08:47 PM   #3
impactwrench
I use a Delco PF52 filter which is a bit bigger than a stock PF47 so I put 5 quarts of oil in my 02, 3.1L. Makes for easy oil changes, just dump in a whole 5 qt bottle.
2002 Malibu
impactwrench is offline   Reply With Quote Quick reply to this message
Old 01-18-2010, 04:05 PM   #4
green03malibu
CMF Senior Member
2003 Malibu LS
Drk Green Metallic
green03malibu's Avatar
The oil filters can be found anywhere. The V6 takes the pf47, but I don't know about the 4 cyl., it might need the pf46 if you are using the ACdelco oil filters.
2003 Chevy Malibu LS
3.1 SFI V6/A4
Dark Green Metallic/Gray Interior
Over 125,000 miles and still going strong
green03malibu is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 08:48 PM   #5
Opus
Gallery: 1
I don't even bother with the wing nuts, I just pull the tabs out of the slots and let the front of the cover hang from the front. Otherwise, it's as easy as everyone has said.
Current Fleet:
2009 Chevy Cobalt SS Sedan
2002 Dodge Dakota SXT Club Cab
1999 Chevy Malibu LS
1994 Ford Ranger XLT (RIP Dad)
Opus is offline   Reply With Quote Quick reply to this message
Old 02-07-2010, 06:20 PM   #6
ElantraMax
CMF Veteran Member
Best advice I can give. Get a Haynes Manual. It will Help with many repairs.
Formerly EscapeMax
2013 Hyundai Elantra Coupe GS
2010 Yamaha Majesty (YP400)
1999 Malibu LS V6 PART OUT ricerocket336 General Discussion (Generation 7) 0 01-02-2010 11:26 AM
Changing oil with the 2.4 bballr4567 Do It Yourself Maintenance (Generation 7) 22 12-15-2009 01:58 PM
Replace 1999 Malibu Right Headlamp Assy DKipes Do It Yourself Maintenance (Generations 5 & 6) 1 10-15-2009 01:49 PM
1999 Malibu #1 missfire caronm General Discussion (Generation 7) 0 10-08-2009 05:33 AM
Temperature Control Problems - 1999 Malibu dswmn Do It Yourself Maintenance (Generation 7) 2 09-03-2009 07:20 AM
