2002 malibu transmission - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 02-28-2010, 05:43 PM   #1
matenzi
Default 2002 malibu transmission
im trying to add some transmission oil in my 2002. i dont want to add too much, so im trying to find the dipstick for it. where is that?
also, am i correct in thinking that the transmission oil cap is the red one on the drivers side, under some manifolds? that one seems to be the only logical choice, because the other ones seem to be labeled pretty well for other things.
thank you for any help
matenzi is offline   Reply With Quote Quick reply to this message
Old 02-28-2010, 07:13 PM   #2
Silver LTZ
CMF Honorary Member
Silver LTZ's Avatar
Gallery: 3
Default Re: 2002 malibu transmission
There is no place to fill it up top. There is a plug on the side of the transmission you can get to on a lift.
Silver LTZ is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 01:39 PM   #3
Answer069
CMF Senior Member
2005 Malibu LS
Galaxy Silver Met.
Answer069's Avatar
Garage
The red cap on the top of the tranny on the driver's side is indeed where you are supposed to add fluid to. (I used to work at Jiffy Lube) There is a plug on the underside that is facing the passenger's side of the vehicle that will take a 10mm wrench to check the level. To check the level make sure the car is in park with the engine running and remove the plug. If fluid comes out then it's full if not, add fluid until it comes out the hole and put the plug back in.
Patrick
2005 Chevy Malibu LS "Galaxy Silver Metallic"
Debadged!!!!!!
Born: 3/15/2005 Fairfax, KS
Died: 12/27/2012 Everett, WA RIP
Answer069 is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 04:43 PM   #4
Silver LTZ
CMF Honorary Member
Silver LTZ's Avatar
Gallery: 3
My bad, I had a mind fart. I haven't had that car for many years.
Old 03-03-2010, 09:55 AM   #5
matenzi
thanks!
so, the car HAS to be running in order to check the level? thats not dangerous?
should the car be on for a certain amount of time before we try to fill it? or can it be cold?
Old 03-03-2010, 10:30 PM   #6
green03malibu
CMF Senior Member
2003 Malibu LS
Drk Green Metallic
green03malibu's Avatar
There should be no reason to check the transmission fluid on our Malibus. The only reason why there would be less fluid is if you have a leak. There's no way we can check the fluid level because there is no dipstick ( the dumbest design on these cars). How many miles do you have on your car? Is it the original or has it been rebuilt and if it has, when did the new tranny be put it in. I had my fluid changed at 93,000 miles and that was with the original fluid too. Also, these don't have filters for the transmissions, they have screens which never get replaced. Hoped this helped.
2003 Chevy Malibu LS
3.1 SFI V6/A4
Dark Green Metallic/Gray Interior
Over 125,000 miles and still going strong
green03malibu is offline   Reply With Quote Quick reply to this message
Old 05-09-2010, 05:18 PM   #7
ken2400
CMF Junior Member
1999 Malibu
Brown
It has been 8 years. I would get the fluid and filter changed if you have not done so since you have owned the car.
http://www.gminsidenews.com/forums/f...-vi-6-a-64757/
Good luck
ken2400 is offline   Reply With Quote Quick reply to this message
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Idle Air Control Valve on a 2002 Malibu GalFriday Do It Yourself Maintenance (Generation 7) 12 03-01-2012 07:08 PM
Tires on 2002 Malibu nymatt109 Modifications (Generation 7) 0 12-10-2008 11:47 AM
Newbie from FL - 2002 Malibu ml02malibu New Member Introduction 2 11-03-2008 03:05 PM
Tein Coilovers on a 2002 Malibu foxracer186 Modifications (Generation 7) 2 09-11-2008 02:58 PM
