ECOTEC 2.4L Oil Filter-Canister Replacement Procedure: - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 03-01-2010, 05:10 PM   #1
SAINT2
Default ECOTEC 2.4L Oil Filter-Canister Replacement Procedure:
Does anyone have the service manual procedure-instructions for replacing the drop-in oil filter-canister on the 2.4L ECOTEC motor? Is the filter-canister and threaded plastic cover installed as a unit, or does one simply drop the canister-filter into the housing and then install the threaded cover?
Does the plastic cover require replacement with each filter change? In addition, are there any other requirements associated with replacement of the oil filter-canister, i.e. replacement of o-rings? Thanks in advance.
SAINT2 is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 05:31 PM   #2
elcompaLalo
CMF Veteran Member
2008 2LT
elcompaLalo's Avatar
Gallery: 5
Default Re: ECOTEC 2.4L Oil Filter-Canister Replacement Procedure:
I replace the O-ring at every oil change, and as for the new filter it just snaps on to the lid/cover which is threaded by the way. For easy removal of the cover you use a Lisle 14700 Oil Filter Socket (costs anywhere from $9-$14 depending where you get it). Thats it, pretty simple.
elcompaLalo is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 07:15 PM   #3
bballr4567
CMF Veteran Member
No need to replace the o-ring unless its damaged. There is no literature that says to do so.
Also, while the oil drain plug is out of the pan remove the oil filter cap. By doing so itll allow for the oil to drain out better.
2010 Terrain SLE2, FWD, 4cyl, Merlot Jewel, Jet Black int.
bballr4567 is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 08:15 PM   #4
Sly Bob
CMF Senior Member
I ordered the socket from these guys and it came to my home in Canada in about a week. For $10 shipped you can't go wrong.
http://cgi.ebay.com/ebaymotors/Lisle...item5d2378ceb4
Sly Bob is offline   Reply With Quote Quick reply to this message
Old 03-25-2010, 06:19 AM   #5
nuclearxp
CMF Junior Member
I'm curious about pre-soaking the filter. I always pre-filled my previous oil filters so they were primed and wouldn't starve the engine for oil on the first startup.
How are people doing this now with the drop-ins? Insert the filter and then pour ~1/4ish quart in to allow it to soak?
nuclearxp is offline   Reply With Quote Quick reply to this message
Old 03-25-2010, 07:30 AM   #6
elcompaLalo
CMF Veteran Member
2008 2LT
Gallery: 5
After dropping in the filter I just filled the engine with all the oil. I don't see why you can't fill the void where the filter is dropped in with some oil prior to inserting the filter.
Old 07-03-2013, 04:25 PM   #7
john1050
2010 Malibu LS
White
Not from the GM service manual, but from changing oil myself a number of
times with this model Chevrolet:
The threaded plastic cover is re-used, permanent.
The filter-canister and threaded plastic cover is installed as a unit. Take the new filter in one hand, the cover in the other. Twist a little and the new filter snaps firmly or locks into the cover/cap. They will then be mated together snugly with no wobble.
Now, drop the new filter and cover together into the housing so that the
pointy filter end with the small O-ring points down and seats into the center point at the bottom of the housing.
Then, turn the cover clock-wise and tighten to about 25NM as I believe is printed on the cap, around the 32MM hex.
If you first drop just the filter into the housing and then apply the cover, the
proper filter-top-to-cover seating may not occur and you will bind down on and distort or compress slightly the filter element, thus reducing its effectiveness. You will not know this happened until you remove the filter at the next oil change. Crunched cartridge!
jaa.
john1050 is offline   Reply With Quote Quick reply to this message
Old 07-04-2013, 09:11 AM   #8
Malibu00
CMF Senior Member
2012 Malibu LS
Black Granite
the ebay add says that the socket is for the GM 2.2 ecotec engine and were dealing with the 2.4 ecotec here does it matter thks
Malibu00 is offline   Reply With Quote Quick reply to this message
Old 07-04-2013, 05:11 PM   #9
XXDuanXX
CMF Junior Member
2008 Malibu 2LT
Silver
Garage
It doesn't mater. I purchased mine that says 2.2 but its the correct fitting for the 2.4 as well.
XXDuanXX is offline   Reply With Quote Quick reply to this message
Old 07-04-2013, 07:41 PM   #10
Malibu00
CMF Senior Member
2012 Malibu LS
Black Granite
thanks, good to know
Oil and Filter Change 2.4L LT1Malibu Do It Yourself Maintenance (Generation 7) 27 05-21-2013 10:07 AM
Socket for oil filter on 2.4 ssman15320 Do It Yourself Maintenance (Generation 7) 5 10-05-2009 06:53 PM
Where is the oil filter?? BuVille09 General Discussion (Generation 7) 2 09-23-2009 10:26 AM
oil filter and oil change madmongodog Off-Topic Discussion 2 08-20-2009 07:47 PM
Oil Filter Differences. ElantraMax General Discussion (Generation 7) 1 10-12-2008 04:57 PM
