Transmission oil check - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 03-21-2010, 02:29 PM   #1
realoldman
CMF Junior Member
Default Transmission oil check
On a 2010 2.4 engine with a 6 speed trany now do you check for the proper transmission fluid level. Mine has a cap on top of the transmission but does not have a dipstick. When I remove the cap and the engine is cold there is no visible oil to be seen. What is the procedure to chect the proper oil level.
realoldman is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 05:13 PM   #2
Starship
CMF Veteran Member
Default Re: Transmission oil check
It's supposed to be filled for life with DEXRON-VI fluid. Without a shop manual, I wouldn't know where to start on these transaxles. If I suspected a leak with my 2010, I would let a tech take a look at it.
Old 03-22-2010, 01:38 PM   #3
realoldman
CMF Junior Member
I called the dealer and was told that I could not check the transmission oil level. I don't believe most things dealers say and this is one of them. There is got to be a way to check it if they can. Someone out there must know how to do it so please let us know.
Old 03-22-2010, 04:27 PM   #4
Starship
CMF Veteran Member
I have a service manual set from when I had a Saturn Ion. If it's anything like before, you would have to raise the vehicle on a level lift and remove a plug. Then, you would need to perform different procedures, depending on the temperature of the fluid.
BTW, the service manual set for the 2010 Malibu is not yet available from www.helminc.com or I would be combing through it right now. It's only $150 and cheap enough insurance when you need things done right.
Old 03-23-2010, 07:27 AM   #5
ElantraMax
CMF Veteran Member
I checked in a Haynes for Malibu up to 2007. There is a Check Fill Plug on the side of the trans. Problem is you have to go underneath. The only way to check it is on a lift. It works like a Differential. You fill the Trans fluid until it just starts dripping out of the plug. 4T45E is supposed to hold (Haynes) 6.9 Qts.
Formerly EscapeMax
2013 Hyundai Elantra Coupe GS
2010 Yamaha Majesty (YP400)
okay so check this problem out RightDownUpLeft Problems/Service Issues/Troubleshooting (Generation 7) 18 02-15-2010 08:36 PM
Check Oil Light Question. ssj4mm General Discussion (Generation 7) 0 01-10-2010 04:42 PM
check the oil AGstone General Discussion (Generation 7) 16 12-24-2009 11:23 AM
Could someone check something for me? Yury Problems/Service Issues/Troubleshooting (Generation 7) 4 12-21-2009 07:35 AM
Check Engine Only on before Start? mithrill Problems/Service Issues/Troubleshooting (Generation 7) 4 04-02-2009 03:17 PM
