Changing the front brakes, have a question. - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 05-20-2010, 06:54 AM   #1
texasborn
2004 Malibu LS
Default Changing the front brakes, have a question.
I will be replacing the front rotors and pads on a 2004 LS. Questions are, are there and special tools needed to do the job? Does the rotor come off once you remove the caliper? Or is there a nut that hold the assembly together?
Thanks for your help
texasborn is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 05:51 PM   #2
chevyguy8893
2009 Malibu LTZ
Silver Ice
chevyguy8893's Avatar
Garage
Default Re: Changing the front brakes, have a question.
Remove one bolt holding the caliper in and flip the caliper up. The caliper can be removed by sliding it off with the other bolt still in. Pull the pads off the mounting bracket. Remove the 2 bolts holding the mounting bracket on. The rotor comes off after the bracket is removed. If the rotors are stuck hit them with a hammer till they come loose. You can hit them wherever since you are putting new rotors on. Once the rotor is off clean up the hub some with some sand paper, or if you have a small 90 degree angle grinder you can use that to clean the hub. Remember to clean and lubricate the caliper slides, clean off rust where the pad brackets go on the mounting bracket. Then, start to reassemble. When you go to compress the caliper take the cap off the brake fluid reservoir and then compress the pistons with a C-clamp and one of the old pads.
Basically the tools needed are a C-clamp, metric socket/wrench set (whichever you prefer), sand paper or grinder, lubricant (can be bought at autozone or other), and have some brake fluid handy just in case. As long as you haven't had any brake fluid leaks you shouldn't need the brake fluid. Overall it is really easy to do brakes on these cars.
4 cyl w/6 speed auto
Silver Ice Metallic paint
-20% tint
Old 05-21-2010, 06:19 AM   #3
texasborn
2004 Malibu LS
Great write up!!!! Thank you.
Old 08-21-2010, 10:02 PM   #4
btexpress
2004 Malibu 1LT
Green
It is a big NO - NO to push the brake fluid back up stream. If any sludge or anything but "clean" fluid gets in the ABS motor (which is just down stream from the Master cylinder) you could be in debt for more than $1,000.00.
You should open the bleeder screw and let it out there, NEVER push it up. After pads are replaced, bleed them as per the book.
btexpress is offline   Reply With Quote Quick reply to this message
Old 08-21-2010, 10:14 PM   #5
chevyguy8893
2009 Malibu LTZ
Silver Ice
Garage
This makes no sense to me. No matter what the piston in the caliper has to be compressed back into the piston to fit the new pads. As long as there was no leaks in the system or brake fluid added the fluid level would just go up closer to the max fill line. As for sludge in the brake system, I understand brake fluid goes bad over time and gets dirty but there shouldn't be sludge in the system. If there is sludge I think there would be more issues. With pad replacement the brake should not need to be bled since the brake system is not opened up and there would be no way for air to get in the system.
-20% tint
Old 08-21-2010, 10:23 PM   #6
btexpress
2004 Malibu 1LT
Green
The sludge gets in all brake systems from the heat it is put under.
If you push it into the ABS motor, you will find out what will happen.
If in doubt, get a factory shop manual and look it up, or find someone that has an account with iATN and ask them to look it up.
Old 08-22-2010, 10:03 AM   #7
03MowiLS
2003 Malibu LS
Dark Green
03MowiLS's Avatar
This makes no sense,
You have to push up the caliber to insert the new pads... I always do this THEN bleed the system AFTER all the brake system is put back together.... I've done this since i've had my Malibu with no problems at all. As lon as you bleed the system after then you'll elimiate any possibility of sludge related problems.
How else would you fit the new pads BTW?
'03 Malibu LS
3100 SFI, Sunroof, Spoiler, factory prenium rims, Pioneer DEH-4200US Reciever WITH Axxess GM Chine retention interface, 65000 Miles and better than anything around it
03MowiLS is offline   Reply With Quote Quick reply to this message
Old 08-22-2010, 10:35 AM   #8
Sandhopper
CMF Senior Member
Sandhopper's Avatar
Gallery: 15
I think what btexpress is saying is open the bleed before you compress so if there is a little sludge in the piston it will come out the bleeder. IMHO not sure if it is necessary but it certainly won't hurt to open the bleeder while compressing the piston. I saw a pneumatically pressurized attachment that you fill with brake fluid, pump it up and then attach it to the brake fluid reservoir. This allows one person to bleed out old fluid and sludge starting with the furthest caliper. Seemed like a cool idea for flushing the whole system periodically.
2013 VW Passat TDI SEL Premium, Titanium Grey w/Black interior
2004 Lexus RX330 AWD, 3.3 V6 Metalic Blue
Sandhopper is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 08:46 AM   #9
tk6214
2007 Malibu LS
White
Send a message via AIM to tk6214 Send a message via Skype™ to tk6214
linky linky?
tk6214 is offline   Reply With Quote Quick reply to this message
Old 03-10-2011, 05:45 AM   #10
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Originally Posted by tk6214 View Post
linky linky?
Air pressure operated one-man brake bleeder
I'd also suggest paying the extra and using colored brake fluid if you're flushing - if you use, say, blue fluid, when the blue starts coming out the right shade, you're flushed to that point. And also, start at the furthest one (passenger rear). Here's an example, although I don't say you should buy from here: DOT 4 Blue Brake Fluid at about $21 per gallon
RwP
Replace rear brakes same time as front or not? RugerRedhawk Do It Yourself Maintenance (Generation 7) 10 05-02-2013 05:03 AM
changing rims, changing speedometer Ktrace35 Wheels, Tires & Suspension (Generation 7) 4 05-15-2010 06:54 PM
Question about brakes... TMoneyR523 Wheels, Tires & Suspension (Generation 7) 9 05-13-2010 04:42 PM
new R1 brakes up front real nice looks and stopping power PreachR Modifications (Generation 7) 11 03-21-2010 03:32 PM
Changing brakes cpetrice Do It Yourself Maintenance (Generation 7) 0 02-16-2010 09:05 AM
