Replacing my Bcm - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 07-11-2010, 05:36 PM   #1
01Malibu
CMF Junior Member
2001 Malibu LS
White
Default Replacing my Bcm
My bcm went out....
Should I:
A. Buy a used bcm and pcm from a same year Malibu as mines
or
B. Go to the dealer, buy a new bcm and have them program it to my malibu?
01Malibu is offline   Reply With Quote Quick reply to this message
Old 07-11-2010, 06:09 PM   #2
elcompaLalo
CMF Veteran Member
2008 2LT
elcompaLalo's Avatar
Gallery: 5
Default Re: Replacing my Bcm
Depends on your budget? Going used might just work, buying and getting it programmed at the dealer specifically to your Bu will be pricey but will definitely get the job done.
elcompaLalo is offline   Reply With Quote Quick reply to this message
Old 07-11-2010, 06:30 PM   #3
Starship
CMF Veteran Member
The BCM will need to be programmed with the VIN. I'd take it in to a dealership or independent shop and get it replaced/programmed with a remanufactured BCM.
Old 07-12-2010, 07:16 AM   #4
01Malibu
CMF Junior Member
2001 Malibu LS
White
yea, thats what I think Ima do.
So does that mean the ones i pulled from some other 2001 Malibus are useless?
And I really dont want a remanufactured one ill just get a brand new one and how am i pose to get my bu to the dealer, it wont crank
Old 07-12-2010, 09:55 AM   #5
Starship
CMF Veteran Member
Once programmed, a BCM cannot be reprogrammed. I'm kind of curious how you came to the diagnostic that the "bcm went out" on your vehicle. Care to share the symptoms?
Old 07-12-2010, 12:26 PM   #6
01Malibu
CMF Junior Member
2001 Malibu LS
White
Besides my interior accessories malfunctioning, I noticed this...
Old 07-12-2010, 03:19 PM   #7
Starship
CMF Veteran Member
Am I supposed to be looking at darkened areas near the connector pins? If so, the source of the problem may be beyond the BCM. There are current-limiting resistors that protect the circuits in case pins are shorted to the ground. The usual way for widesperead burnt spots is when a >= 12V source is shorted to a 5V circuit. I wouldn't feel comfortable just throwing a new BCM at it. You need to take it in to a shop that can diagnose it properly.
Old 07-12-2010, 04:23 PM   #8
01Malibu
CMF Junior Member
2001 Malibu LS
White
i believe my problem came from me letting my brother try to fix my trunk release, he put a wire on the positive battery, and started poking around in the driver side kick panel making the trunk pop,
But anyway I just recieved a used Bcm in the Mail with the exact id number as mines 12206819 and everything works now door locks trunk release mirror lights ect......the only thing not coming on is the fuel pump, I did the 10 min learn thing the theft light turns off when I attempt to crank the malibu what could be the isssue now?
Old 07-12-2010, 04:35 PM   #9
Starship
CMF Veteran Member
You can't expect to drop in a BCM that was VINed for another vehicle and expect it to be able to communicate with the ECM and TCM. If the seller led you to believe it'll work, he should've known better.
Old 07-12-2010, 04:53 PM   #10
01Malibu
CMF Junior Member
2001 Malibu LS
White
See im new to the Malibu game, I read sumwhere on United Malibus or this site really cant remember that as long as you get the same id number that they will work, well is there a way I can make my fuel pump come on til I save enough money for a new one then take it to the dealer?
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
help replacing passenger mirror slhaas General Discussion (Generation 7) 21 02-10-2015 08:06 AM
Replacing the headlights MAL I BOO Do It Yourself Maintenance (Generation 7) 53 02-03-2011 09:13 AM
Replacing A Headlight 1999 LS Lyketysplyt313 Do It Yourself Maintenance (Generations 5 & 6) 3 10-16-2009 11:35 PM
Replacing OEM tires with??????????? Red Ryder Wheels, Tires & Suspension (Generation 7) 13 09-26-2009 07:40 AM
Replacing inner tie rod... possible? ectar Do It Yourself Maintenance (Generation 7) 4 08-17-2009 07:58 PM
