Battery Group/Size on our Malibu's - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 08-03-2010, 08:16 AM   #1
ChicagoMalibu2009
CMF Veteran Member
2009 Malibu LS
Blue Met./Titanium
ChicagoMalibu2009's Avatar
Gallery: 17
Default Battery Group/Size on our Malibu's
Does anyone know offhand what Battery Group/Size we have? Or the dimensions? With either of those I can back into the other -- but any help would be appreciated.
It would be good to have up here also, as a search turned up nothing and we'll all be curious sooner or later. Thanks!
I'm investigating options for a higher duty replacement before some time up north this winter, along with the fact that i do use the map light, gps, etc... sometimes for a while once the car is off.
2.4L 4cyl. ECOTEC LE5
Ext: Transition Blue Met./Golden Pewter Met.
Int: Titanium, Weathertech Mats, Neoprene Covers
Stock Rims/Tires Uncovered (Summer = Borbet Type LS)
EBC Slotted Rotors w/ Redstuff Pads
Full Mud Guards - Clear Door Edging - 35% Sides
Hardwired Radar and GPS Charger - LED's - ScanGauge II
At Bat: PTM Chevy Emblems, Black Calipers
On Deck: Silverstar All Around w/ PIAA Fogs
In the Hole: Undercoating
Wearing: Collinite(incl. Wheels), ARO, Aquapel, Plexus
ChicagoMalibu2009 is offline   Reply With Quote Quick reply to this message
Old 08-03-2010, 01:12 PM   #2
Ktrace35
CMF Junior Member
2009 Malibu 2LT
Transition Blue
Ktrace35's Avatar
Default Re: Battery Group/Size on our Malibu's
i put an optima red top in my 09 and she's been running good. its been about a year with it hooked up to my car and amp.
2009 chevy malibu 2lt 3.6 v6
built 6/13/08 in Orion, MI
Ktrace35 is offline   Reply With Quote Quick reply to this message
Old 08-03-2010, 01:39 PM   #3
ChicagoMalibu2009
CMF Veteran Member
2009 Malibu LS
Blue Met./Titanium
Gallery: 17
Which model? What battery group or size did you reference when purchasing?
I'm not going to go deep cycle, heard too many horror stories.
Probably going to buy from Costco... (Edit: IF they have a premium CCA battery)
Old 08-04-2010, 07:14 AM   #4
ChicagoMalibu2009
CMF Veteran Member
2009 Malibu LS
Blue Met./Titanium
Gallery: 17
Well, thanks for reading guys... I guess we can just have this in our records, but I found that we have a group 90 battery. Listed at 590CCA OEM in the ref guide i used but mine is 560CCA :-(.
Anyhow, it's AC delco # 4838 and model 90-6YR
Costco fitment 12
9 11/16" X 6 7/8" X 6 7/8"
Old 08-05-2010, 03:50 PM   #5
elcompaLalo
CMF Veteran Member
2008 2LT
elcompaLalo's Avatar
Gallery: 5
Costco fitment 12
Good to know.
elcompaLalo is offline   Reply With Quote Quick reply to this message
Old 10-13-2013, 05:29 PM   #6
hoahai
CMF Senior Member
Wanted to report that I have successfully installed the Costco Kirkland battery for my Bu 2008 LT2. I used Fitment code 8 (BCI group size 58). I had to improvised it a little bit: (1) The terminals are on the passenger side instead of the driver side (2) removed both L-shape rubber bracket which were wrapped around the cables (so I could easily twist the cable as the terminals are now closer) (3) For the plastic battery holder, just inserted it back in the gap without the screw: the holder sits very tightly between the battery and the box wall but can not go all the way to the bottom
This kirkland battery exceeds the OEM CCA (610 versus 590), also carries a good warranty 3 year replacement/100 months prorated.... Its price is fairly cheap, under $70..These are the main reasons I go with this battery instead the expensive exact fit version from other brand... Took me around 30 minutes to do the installation...
08 2LT White/Titanium, 4cyl/4spd
Born 04/08 Lake Orion
hoahai is offline   Reply With Quote Quick reply to this message
Old 10-13-2013, 05:51 PM   #7
Speed_Freak5150
2010 Malibu 1LT
Imperial Blue
Gallery: 2
Do you have any pictures of the setup as it it now. I would be interested in seeing what you had to do.
10 Malibu 1LT
'14 Traverse 1LT
Speed_Freak5150 is offline   Reply With Quote Quick reply to this message
Old 10-14-2013, 06:43 PM   #8
hoahai
CMF Senior Member
Here they are. I later replaced the original plastic battery holder with a piece of wood. I used a wood stake that happens to have a perfect 1.5" width for the gap. I cut it to the length of the original holder, drill a hole in the center and screw the bolt back.
Note: the negative cable seems close to the piece of metal but when you put back to box cover, it will separate them. I was also able to put back the L-shape bracket on the positive cable to give some safety buffer between the 2 cables.
Click image for larger version
ID:	9754   Click image for larger version
Any one found a programmer for malibu's PreachR General Discussion (Generation 7) 12 01-14-2015 07:07 AM
Customizing our Malibu's Big Show Modifications (Generation 7) 7 02-12-2010 04:55 PM
Another one sails away...no more Malibu's in the house beach General Discussion (Generation 7) 18 12-18-2009 04:11 AM
New Malibu's zert800 General Discussion (Generation 7) 2 12-06-2008 09:43 AM
08 Malibu's On The Road 08MalibuLeaser General Discussion (Generation 7) 40 05-13-2008 04:32 PM
