Stuck key/ sticky shifter release - solution! - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 09-03-2010, 09:08 AM   #1
sammyd173
2005 Malibu MAXX LS
Black
Default Stuck key/ sticky shifter release - solution!
2005 Malibu Maxx.
I would shift the car to park, key would not come out. Would have wiggle the key excessively until it would click over further counter clockwise and then release. WD 40 into the cylinder did not help at all.
Also the button you squeeze to pull the shifter out of park was very sticky.
I found a TSB on the issue which required pulling out the center console and adjusting the park lock cable mechanism, which is cable that goes into the side of the ignition cylinder. It looked like a lot of work. Also, that turned out not to be the issue.
Instead I pulled out the little coin (pen?) tray directly infront of the shifter. This reveals the cable in question. The raw cable is exposed before going into the outer cable.
I could see that the cable was getting hung up and not releasing smoothly.
Put a little WD 40 where the cable/ wire goes into the outer cable. Now the key releases perfectly, and the release for the gear shifter is much better. I could also swear that my MPG's and horsepower increased, j/k!
I hope this helps anyone else with this infuriating problem.
sammyd173 is offline   Reply With Quote Quick reply to this message
Old 09-03-2010, 09:52 AM   #2
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Default Re: Stuck key/ sticky shifter release - solution!
Now there's an unusual post! Problem AND solution in one!
Thanks for the input and hope you stick around.
Muffler mod on '09
Old 09-03-2010, 10:16 AM   #3
Starship
CMF Veteran Member
Really useful information. I'd like to point out that WD-40 is good for the water displament application but is a poor substitite for a lube (I should know, I use it to dry out wet skate bearings in a pinch).
Old 09-05-2010, 03:59 PM   #4
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
There used to be a Teflon(tm) spray that worked great for cables, but I don't know where to get any anymore (back in the 80's I used to buy it at the Black & Decker repair depot in town.)
Since I can't find that, I usually use a silicone spray (silicon? Not sure which variant). Latest purchase was a can from Liquid Wrench.
Don't like WD40 when used as a lubricant. Up until recently, they didn't even CLAIM it was a lubricant, but the cans now claim lubrication capabilities.
See, it's mostly the carrier that's lubricating - any long term is probably due to washing crud out of the way.
RwP
Old 06-23-2013, 12:14 PM   #5
alcantar06
2005 Malibu
BLUE
Thumbs up Re: Stuck key/ sticky shifter release - solution!
Thank you so much for your solution. This worked perfectly!!!
Regards.
alcantar06 is offline   Reply With Quote Quick reply to this message
Old 11-15-2014, 12:12 PM   #6
dpfeiff12
I have an '09 Malibu and I had a similar issue. My solution was a bit different though. I had to take off the plastic bit that goes around the shifter, the first piece of plastic he removes here:
https://www.youtube.com/watch?v=N8QIamwc4hI
Then if you look to the drivers right of the shifter there is a cable tension adjust knob. I had to release (turn clockwise) this knob a few times. This lets the pin that release the shift button all the way out rise all the way to the top. This pin can be seen from the passenger side if you take off the side panel to this center dash area. I also sprayed everything around these mechanisms with WD40 (I didn't have silicon spray) to make sure nothing is getting hung up. This seems to have fixed this really annoying problem and didn't take long even with me needing to figure out my own problem.
dpfeiff12 is offline   Reply With Quote Quick reply to this message
Old 02-26-2015, 03:16 PM   #7
kmartp
Similar issue, similar solution;
2005 Maxx LS; dealer did the Trans Recall repair, then the "key locked" issue occurred. Dealer (Momentum Chevrolet in San Jose) claimed "we didn't touch it, we won't fix it (unless you pay us)". So...
What happened is that when they repaired the transmission shift cable, they removed the wiring harness. When they replaced the wiring harness they did it under the shift cable but *over* the key interlock cable. removing the little cup in front of the shifter and adjusting the wiring harness fixed the problem.
Thanks for leading me to this solution!
kmartp is offline   Reply With Quote Quick reply to this message
Old 04-29-2015, 08:49 AM   #8
itfarmer
Sammy, Thanks so much for this info. My key was doing something similar where I could almost turn it off, but the key would not fully move to the off position.
for a 2010 Malibu, there is a small plastic panel on the passenger side that is removable without tools. Once off, you can see the cable running from the shifter to the key switch. The plastic piece which attaches to the shifter had been stuck out of proper position. Once I jiggled the wire and moved the plastic piece, my keys came right out.
Thanks So Much !
itfarmer is offline   Reply With Quote Quick reply to this message
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Ignition Gets Stuck On Accessory TonyD Problems/Service Issues/Troubleshooting (Generations 5 & 6) 8 06-15-2010 03:50 PM
Tach and Speedometer...stuck? malibu2008 Problems/Service Issues/Troubleshooting (Generation 7) 6 07-02-2009 11:13 AM
Cruise, ETS not working, brake lights stuck on! janfmiller Problems/Service Issues/Troubleshooting (Generation 7) 0 03-17-2009 06:37 AM
Sticky Residue Chev88 Washing, Waxing and Detailing 0 03-15-2009 06:44 AM
