Remote start not working - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 11-03-2010, 05:22 AM   #1
imrf
CMF Junior Member
Default Remote start not working
Hello all. I have a 2009 Malibu 2LT. For the past month the remote start and randomly not worked properly. I try to start it in the morning and it doesn't work, drive to work and go about my day. Walk out of work and start the car remotely. Go home, wake up the next morning and it doesn't start again. The hood isn't open, a code isn't thrown and so on. Anyone else seeing the same thing? Could it be a bum unit? I've sat in the car and tried to do a remote start and see the lights flash but there isn't even an attempt for the car to start. This is starting to suck because winter is almost here and the factory 36K warranty just ran out for me.
imrf is offline   Reply With Quote Quick reply to this message
Old 11-03-2010, 05:46 AM   #2
dc2009
CMF Senior Member
2009 Malibu LS
Imperial Blue
Default Re: Remote start not working
Has the battery even been replaced? If it's the original it may be due. Talking about the key fob battery.
dc2009 is online now   Reply With Quote Quick reply to this message
Old 11-03-2010, 05:52 AM   #3
imrf
CMF Junior Member
Factory battery. I also tried the other keyfob today which is never used and same thing. Both have factory batteries.
Just curious though, they work everything else that they should, is there a way that they aren't transmitting the full remote start signal or something? It just seems weird that the pre-start flash happens like it should.
I appreciate the reply and suggestion, I'll have to look into getting new batteries and see what happens.
Old 11-03-2010, 06:42 AM   #4
dc2009
CMF Senior Member
2009 Malibu LS
Imperial Blue
While I don't have the remote start feature, I was having a similar problem with the remote lock function that cleared up when I replaced the battery. The other remote functions worked fine.
I don't know if replacing the battery will solve your problem, but it is a relatively inexpensive thing to try.
Old 11-03-2010, 07:00 AM   #5
imrf
CMF Junior Member
Ok. Thanks for the suggestion. You're right, it's a very cheap and easy option to do first.
Old 11-03-2010, 08:32 AM   #6
LTZ Chev's
2010 Malibu LTZ
White Diamond Tri
I have a 2010 Malibu ltz v6 with the remote start and hasn't glitched yet. However..... I have a 2007 Tahoe LTZ and I have the same problem. It does not work maybe every 10 tries. I noticed that if I start the truck with the key in the ignition like normal, the remote start will work for a while. My lights will light up like it is going to start, but the engine never turns over. Replaced the car battery and the keyfob battery. Did not help. It is prob something like a bad relay in the electronics. Loose fuse? Loose wire? Usually ends up being something simple. I have procrastinated on this issue, so I cant offer a solution, only possible causes. Good luck!
Luvin' my LTZ's!
2010 Chevy Malibu LTZ V6, White Diamond Tri Coat
2007 Chevy Tahoe LTZ, Black
2013 Chevy Malibu????? We will see what Chevy does........Dont mess too much!
LTZ Chev's is offline   Reply With Quote Quick reply to this message
Old 11-03-2010, 10:05 AM   #7
Starship
CMF Veteran Member
It may be an intermittent short in one of the door ajar sense circuits. Moisture (about that time of the year)? In order to test that theory, try unlocking all the doors and then relock them (with the key fob, of course). If it senses an open door, it'll pause a few second before locking (read the owner's manual on delayed locking). Or, it may shake it loose so the remote start will then work.
Also, if the warranty just ran out, you may want to call the GM customer service and ask if they could do anything for you.
Old 11-03-2010, 10:11 AM   #8
imrf
CMF Junior Member
Thanks for the suggestion. I'll try that next time it has issues starting. Just got back from lunch and it remotely started.
Yeah, the warranty ran out 2000 miles ago, so if it keeps acting up I'll give them a call and see what can be done. Has anyone tried that? If so, whats the process? Do they require you to pay the bill, then they reimburse you?
Old 11-03-2010, 10:23 AM   #9
Starship
CMF Veteran Member
I suggest calling first to establish the timeline. Explain the seasonal nature of the problem and be nice about it. Hopefully they'll open a case for you.
Old 11-03-2010, 10:32 AM   #10
imrf
CMF Junior Member
Ok thanks for the suggestion. I'll give them a call later on and see what they say and go from there.
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Remote Start cavalier2000 General Discussion (Generation 7) 6 03-20-2015 05:40 PM
Remote start fix.. 87tpita Do It Yourself Maintenance (Generation 7) 1 02-27-2010 04:39 PM
Remote Start? SliverMossMan General Discussion (Generation 7) 7 06-10-2009 02:04 PM
installed remote start, engine dies after start tonynikki0181 Modifications (Generation 7) 0 03-12-2009 10:40 AM
is the 2 way remote start available yet? jmz768 General Discussion (Generation 7) 4 10-28-2008 04:05 AM
