Turn signal blinks rapidly- '09 Malibu LS - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 01-05-2011, 08:56 AM   #1
ibfly
2009 Malibu LS
Light Blue
Default Turn signal blinks rapidly- '09 Malibu LS
The front left turn signal blinks twice as fast as it should be and the left rear signal is not blinking at all. The right side turn signals are both good.
I clicked the emergency switch, it seems that both sides work fine. Is it a problem with the turn signal switch? Is there a recall for this?
How much will it cost to fix it?
Any comments will be greatly appreciated! Thank you very much!
ibfly is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 09:54 AM   #2
phantom1584
Default Re: turn signal blinks rapidly- 09' Malibu LS
Could your tail light be out? I wonder if its the cars way of telling you that you got a dead bulb on that side. Thats just a guess though.
phantom1584 is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 09:57 AM   #3
kencar10
CMF Senior Member
2010 Malibu 1LT
gold
Sounds like the rear bulb is out. Usually a fast blinking turn signial is letting you know the other bulb is burnt out.
kencar10 is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 11:12 AM   #4
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
Yes, the rear bulb is obviously out. Every car I've owned does the fast blinking to let you know a bulb is burnt out.
Gray 09 Malibu lS
2.4l 4-speed Auto
onecrazyfoo4u is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 11:25 AM   #5
ibfly
2009 Malibu LS
Light Blue
thank you very much! Would you please give me any information on how to replace the light bulb by myself? I think I found the bulk to buy on Advanced Auto Parts.
Old 01-05-2011, 11:50 AM   #6
scott37300
CMF Senior Member
2009 Malibu 2LT
Black
I had the same issue with dead bulb.
Don't remember 100% but I from inside the trunk you should see a couple bigger plastic nuts, if you don't see them you need to peel the carpet back to access them. Unscrew these and the light housing should pull out from the outside. Then you can just turn the bulb socket and pull it out and replace. I did this outside of advanceauto last year before we headed out for a ski trip so it wasn't that bad at all.
scott37300 is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 03:30 PM   #7
Starship
CMF Veteran Member
What he said. Also, we just went though this in another thread. See thread http://www.chevymalibuforum.com/foru...ead.php?t=6270. And, welcome to the forum.
Old 01-16-2011, 04:33 PM   #8
Metallicstar
2012 Malibu Ls
DK Grey
I just had to do this myself the other day. I pulled back the carpet and pulled off the 3 plastic nuts then pulled the whole light out. Then you can take out just the socket for the bulb. Then you can pull the light bulb out and put the new one in. It was easy once I found the directions.
Metallicstar is offline   Reply With Quote Quick reply to this message
Old 10-16-2011, 11:44 AM   #9
hattwagon
here is a video how to change the rear turn signal: http://carcarekiosk.com/video/2009_C...um_signal_rear
these guys show how to do everything on the 09 malibu - good videos, all free
hattwagon is offline   Reply With Quote Quick reply to this message
Old 03-19-2012, 04:34 AM   #10
manofice
CMF Junior Member
my 2009 malibu was doing the fast blinking on the right side, went outside and sure enough it wasn't blinking in the rear, only in the front. I was a little freaked out thinking it was something bigger but as this thread has shown, it must be the bulb, thanks!
Edit: Can anyone confirm that the replacement bulb is in deed the 3157 not the 3156?? I have a 2009 Malibu LS
manofice is offline   Reply With Quote Quick reply to this message
2005 Malibu Turn Signal problem 05lsv6malibu Problems/Service Issues/Troubleshooting (Generations 5 & 6) 12 04-09-2014 05:49 PM
right turn signal not working, left turn signal working fine flrdotcom Problems/Service Issues/Troubleshooting (Generation 7) 20 06-27-2013 08:21 AM
05 Malibu Turn Signal Lens Melting Brah Problems/Service Issues/Troubleshooting (Generations 5 & 6) 12 04-16-2012 04:37 AM
Turn Signal Volume on 2008 Malibu uncledewey Modifications (Generation 7) 11 08-13-2010 08:53 AM
Malibu 2005 Rear Turn signal polysciencegirl Do It Yourself Maintenance (Generation 7) 1 06-01-2009 03:27 PM
