2005 Malibu Classic rolls over, but won't start - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 03-03-2011, 07:04 AM   #1
jthomasson
2005 Malibu Classic
Silver
Default 2005 Malibu Classic rolls over, but won't start
I have a 2005 Malibu Classic, 4-cyl. Several months ago, my car decided it didn't want to start for me. When I turned the key, the motor rolled over like it wanted to start, but it wouldn't fire. The first time it did it, I just left it in the parking lot for almost two days, tried it again and it started just fine. About a week later, it did the same thing. That time, the only mechanic within an hour of where I live came to get it for me. He kept it for four months only to tell me he found a bare injector wire that was grounding to the motor and he 'fixed' it. When I got the car back, I was pretty leary since I've never used him before - so I traced the injector wires and nothing. I think he just let it sit up long enough it reset itself again like it did in the parking lot the time before. I got in my car this morning and it started doing the same thing again. I really don't want to have to tow the car an hour to get to a reputable mechanic, so any advice would be greatly appreciated!
Fuel is getting to the motor. I checked by pressing the pressure relief valve, priming the engine, and pressing again. When I try to start the car, it rolls over just fine - and the battery doesn't sound weak at all. I've replaced the spark plugs & wires, fuel filter, and the oil & filter. Still no luck.
jthomasson is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 09:20 AM   #2
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Default Re: 2005 Malibu Classic rolls over, but won't start
I'll repeat with more detail what I said in another forum, and which has been backed up by several mechanics in town.
Last time my 2000 Malibu pulled this act, I had pressure at the fuel rail. I had about 25 to 30 PSI of pressure. Injectors won't spray properly until something like 40 PSI ...
Get a fuel pressure gauge, and when it's acting up, see what pressure you REALLY have.
I ended up with a $600 fuel pump replacement because I didn't want to buy a $30 gauge. Not that I'd have replaced the fuel pump myself - I don't have a lift and really, REALLY don't want to have to lift and drop the fuel tank while on jack stands. But it's definately something to check.
RwP
Old 03-07-2011, 03:25 PM   #3
sendmetotj
2005 Malibu maxx LS
GREY
I have a 2005 MAXX with the same issue. It first started with the gas tank near low, and also well driving at a high rate of speed (highway). My car would chug then stall well in gear.
I would also have the problem posted before by jthomasson.
My car will turn over but just wont fire. My pressure in the fuel lines are at 55psi well primed. After letting the car sit for 20 mins and checking again the pressure had already dropped to 30psi. I believe the pressure should stay up for a fair bit, but my is dropping.
I got to quotes for pumps 690 and 580
I am a student can barely even afford my gas!
Does anyone know
A) If my fuel pressure is to stay up even long after turning the pump on
B) what could be another reason why we are not able to get the car to fire
(leak/kink in fuel line? filter ? pump? spiders? WHATTTTTT)
sendmetotj is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 06:28 PM   #4
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
There are 3 sides to every fire triangle: fuel, air, spark.
If you believe you're getting the correct amount of air and you're fairly certain you're getting a hot enough spark, then fuel is the last piece of the puzzle.
The injectors need a certain amount of pressure to work well. If the pressure drops with the key off that's no real concern. Once you turn it on it primes the whole fuel system with pressure. Next you need to know if you've got enough flow. Without it it can't fill the void left after injecting the fuel.
The first place to look is the filter. Was it ever replaced that you know of? If not, it's not an expensive thing to do, but take the proper precautions and bleed the pressure off the system before disconnecting the filter! Also have a pail or something to catch the drips beneath the car. If it spills on blacktop it'll eat it alive.
Either that or you have a gnome...
Muffler mod on '09
Old 05-23-2013, 11:11 AM   #5
MMeek
I know that this is a very old thread, but I had experienced this same problem yesterday and wanted to let anyone else that may have a problem like this what my fix was. The Anti-Thief system had the fuel system locked and the car would not start……The owner’s manual said to turn the ignition key to the on position leave it on for 10 minutes, then turn it off for 5 seconds and then it started right up for me !!!!! I hope this is helpful for someone else in the future…..MMeek
MMeek is offline   Reply With Quote Quick reply to this message
Old 05-23-2013, 02:50 PM   #6
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Your first post and you're already sharing good stuff! Thanks!
Muffler mod on '09
Old 05-24-2013, 05:58 AM   #7
MMeek
Post Re: 2005 Malibu Classic rolls over, but won't start
Thanks, I read RalphP and jthomasson post before I went to check on the wife broke down and a flood of bad thoughts went through my mind on the drive their …..All of them costing me a ton of $$.....So if this post can help anyone else, I’m happy to help ……MMeek
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
2005 Classic 239bmxican Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 01-04-2011 04:10 PM
2005 Classic Tranny fluid- Samantha Do It Yourself Maintenance (Generations 5 & 6) 2 12-27-2010 07:19 AM
Rebuild 2005 Classic dvirr0845 General Discussion (Generation 7) 1 10-26-2009 08:32 PM
Replacing thermostat on 2005 Malibu Classic MILK6969 Do It Yourself Maintenance (Generation 7) 0 08-09-2009 09:20 AM
2nd-gear start 04 Classic faramir99 General Discussion (Generation 7) 4 11-08-2008 02:27 AM
