replacment of heatercore - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 09-02-2008, 02:05 PM   #1
rcookr5
Default replacment of heatercore
any detailed info on replacing the heatercore for a 2000 malibu do it yourselfer?
rcookr5 is offline   Reply With Quote Quick reply to this message
Old 09-03-2008, 02:56 PM   #2
ElantraMax
CMF Veteran Member
Default Re: replacment of heatercore
Haynes Manual would show how to.
Formerly EscapeMax
2013 Hyundai Elantra Coupe GS
2010 Yamaha Majesty (YP400)
Old 09-05-2008, 12:17 PM   #3
jfb423
CMF Junior Member
Here you go
xTooltipElement
Service Information
2000 Chevrolet Malibu | Malibu (VIN N) Service Manual | HVAC | Heating, Ventilation and Air Conditioning | Repair Instructions | Document ID: 579310
Heater Core Replacement
Removal Procedure
Remove the HVAC module. Refer to HVAC Module Assembly Replacement .
Turn the HVAC module over.
Remove the heater core case cover.
Remove the heater core bracket and screw.
Remove the heater core.
Installation Procedure
Install the heater core to the module.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the heater core bracket and screw.
Tighten
Tighten the bracket screw to 1 Nm (9 lb in).
Install the heater core case cover.
Install the heater core case cover screws.
Tighten
Tighten the cover screws to 1 Nm (9 lb in).
Install the HVAC module. Refer to HVAC Module Assembly Replacement .
2008 General Motors Corporation. All rights reserved.
08 1LT 2.4L Silver/Ebony/chrome b-pillars/20% tints/6000k hids/Painted Caliper/Rotors/Brackets(black,silver)/debaged/OEM Fog's installed w/yellow H11's/Tuned By CoW
WIFEY'S
Other cars:
06 TBSS AWD White/Ebony/Red SS inserts/R-1 slotted-drilled rotors/Addco sways/C-6 Fan/Magnaflow catback/Painted calipers/brackets(red/black)/Vararam Tri-power Intake w/1" TB spacer/front tints/Tuned by CoW
MINE
jfb423 is offline   Reply With Quote Quick reply to this message
Old 09-05-2008, 05:55 PM   #4
lcurle
Banned
If you need any more help I have access to all motor data, and can pull up diagrams and picturs and all that jazz for you.
[update]: nevermind on the allmotordata, looks like I lost my account.
lcurle is offline   Reply With Quote Quick reply to this message
Old 09-18-2014, 04:47 PM   #5
DieselDon359
Post Re: replacment of heatercore
OK so what happened with the cruise control? The suspense is killing me!!! Could be a wire came loose in one of the connectors? Sometimes the little metal connector will slide back out of the plastic thus no longer making connection. Is the speedometer working? Cruise won't work if speedometer doesn't work. Still a great job even if the cruise doesn't work! You can live just fine without cruise!! Gotta have heat/defrosters in winter! Here the car will NOT pass state inspection without operable defroster! You did GREAT! A real bear of a job! I would rather pull the heads replace headgaskets and, timing chain than replace the heater core! But, that's just me!
DieselDon359 is offline   Reply With Quote Quick reply to this message
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
