How-To: Install Switch and/or Lights in Overhead Console - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 05-28-2011, 03:32 PM   #1
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
Lightbulb How-To: Install Switch and/or Lights in Overhead Console
This will take multiple posts due to the 4-image limit:
1. I decided where the new switch would go, paying attention to the bezel on the switch and interference from items already installed, including front and back of console cover and items inside the cavity when reinstalling.
Notice the wire that was trimmed and used to detect the wall around the lights. Turning it over I decided that the switch needed to move away just a little in order to install without issue.
The tape on the switch shows that its length is almost exactly the width of two pieces. So I used small pieces of tape on the measuring wire to mark the placement of the switch to transfer to the front.
2. I used the opening of the sunroof switch to determine that the new switch fit into it snugly, then taped the console to mark the sides. Using the measuring wire I made 4 marks next to the tape for the corners.
3. I drilled 4 small holes in the corners.
4. I used a circuit board as a straight-edge to scribe the proposed edges of the cut-out for the switch. (Had to tape the blasted craft knife to keep it from rolling off before I could snap the pic!)
Muffler mod on '09
Old 05-28-2011, 03:36 PM   #2
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
5. I then used a very rigid, industrial-grade razor to more deeply scribe the edges.
6. Then I drilled along the edge to remove a large amount of material.
7. I used the Irwin blade to remove the bulk by joining the holes.
8. Then I trimmed some more.
Muffler mod on '09
Old 05-28-2011, 03:50 PM   #3
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
9. After trimming, fitting, and trimming (and more trimming, and even more...) I was able to get the switch to insert. I tested the operation. It's a center-off momentary in both directions. It was just tight enough that it wouldn't return to center. More trimming...
Finally it fit and worked right!
10. Then I marked the center of the console (by eye) and determined where the 3 LED indicators would be mounted. I decided to mount them closely together so I could install 2 more switches in the future if I want to without any issues regarding placement.
The LED housing is narrower than a piece of tape so I conveniently used it to determine how far it was to the other 2 centers and marked them with another piece of wire bent to the right length. The little pieces of tape at the outer edges mark where there are pieces of white plastic inside the opening of the overhead cavity. Prevented me from mounting something there and having interference issues!
11. I drilled 3 small holes so the bit wouldn't "walk", then enlarged them to the final size with a larger bit. Installed and tightened them. I'm just OCD enough that I also made sure the red wires were all aligned toward the outer edge and the black ones were toward the center. Hey, neatness counts! ;>)
12. After wiring and final installation. (Dude, there's a gnarly scratch! Yeah, while cleaning up the LED holes I slipped. Damn!)
Operation:
Currently the driver's window is not part of this system, but someday I intend to modify the motor so I can add it in.
The switch is wired to my express up/down modules. With one press Open I can vent the "other" three. If I hold it 'til after they vent and start moving again they all go down all the way. When I press the Close position they all express up. The Open and Close positions match the sunroof's so it's operation is consistent, plus the new switch is contoured with a dip and a rise so I installed it in the same orientation as the sunroof's.
The LEDs are:
Left - Parking lights On
Center - CHMSL operation (Not hooked up yet but wire has been run to the lower console in preparation)
Right - Fog lights On (I know there's a yellow light on the switch, but it's hidden by the steering wheel spoke unless I either move my head or turn the wheel. Also not hooked up yet, but also wire has been run.)
Muffler mod on '09
Old 06-09-2011, 07:30 PM   #4
Oncewasarental
CMF Junior Member
2010 Malibu 1LT
Gold Mist Metallic
Send a message via Yahoo to Oncewasarental
Default Re: How-To: Install Switch and/or Lights in Overhead Console
Pretty cool man, keep em coming.
2010 Malibu 1LT
2.4l / A6
No Bluetooth or Onstar
15% tint
Interior LED's on the way
Debadged trunk
Oncewasarental is offline   Reply With Quote Quick reply to this message
Old 12-01-2014, 08:38 AM   #5
11bubu
CMF Senior Member
2011 Malibu LS
11bubu's Avatar
Very nice switch, looks clean.
This car should have came with a switchable light, duh!
11bubu is offline   Reply With Quote Quick reply to this message
Old 12-05-2014, 04:46 PM   #6
11bubu
CMF Senior Member
2011 Malibu LS
11bubu's Avatar
I asked at the dealer today about why these cars do not have switches on the overhead lights. He replied that trucks still do as more people leave there doors open in trucks to load/unload/work on them than car owners. He said there is a 15 minute timer on cars. He understood my concern about the batt wearing down if this behavior is done too frequently. He agreed that car owners can do what they want with their own cars but went into a lengthy explanation about some cars wiring of overhead lights should not be tampered with.
Old 12-05-2014, 05:54 PM   #7
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
For those who have no business wiring things up I agree with him. For those like me who know how to do it I feel like his comments are condescending. If he said that to me and looked at me like he meant that I should not have done it, I'd tell him to take a flyin' leap! It's all in how it's delivered I guess.
Muffler mod on '09
Old 12-06-2014, 01:43 PM   #8
jnells
CMF Senior Member
2005 Malibu Custom :)
Silver
jnells's Avatar
Nice work and write up
2005 Malibu - Ongoing Build
jnells is offline   Reply With Quote Quick reply to this message
How-To: Install LED Lights In Switches/Handles/Overhead Lights chevyguy8893 How-To/Write-Ups (Generation 7) 21 05-27-2013 03:28 PM
Water leak in overhead lights. Metallicstar Problems/Service Issues/Troubleshooting (Generation 7) 4 09-03-2011 05:17 AM
Dome, map, overhead lights BJL Modifications (Generation 7) 3 02-28-2011 06:37 PM
OverHead Lights nkappes Modifications (Generation 7) 4 04-21-2009 08:07 AM
Interior Lights DIMMER Switch JRB Problems/Service Issues/Troubleshooting (Generation 7) 7 01-20-2009 06:35 PM
