Oil change question: 5.5 quarts in the 3.6L V6 - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 05-28-2011, 08:20 PM   #1
Everglades
CMF Senior Member
2009 Malibu 2LT
SilverIce Metallic
Everglades's Avatar
Gallery: 2
Default Oil change question: 5.5 quarts in the 3.6L V6
What do you do when you go to the oil change places that typically put up to 5 quarts in. I don't want to be running 1/2 quart low. Do you pay extra for the last 1/2 quart or what? How much does that typically cost? Maybe bring along an extra quart of oil and put in the extra 1/2 quart in yourself?
Just curious....
2009 Mallibu 2LT
2000 Firebird 209,000 miles (and counting)
Everglades is offline   Reply With Quote Quick reply to this message
Old 05-28-2011, 08:26 PM   #2
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Default Re: Oil change question: 5.5 quarts in the 3.6L V6
Actually, if you're above the "ADD" point, being "low" isn't a problem, and may be beneficial - since you will reduce windage and drag inside the oil pan, helping the power and economy of the motor (a very, VERY minor bit, but still ... )
But if it bothers you that much, do your own oil and filter change, and save money / use better oil and filter / both!
RwP
Old 05-28-2011, 09:03 PM   #3
Malibu25
CMF Senior Member
2011 Malibu sold 1LT
Silver Ice
How many quarts does the 2.4 use
Malibu25 is offline   Reply With Quote Quick reply to this message
Old 05-29-2011, 03:08 AM   #4
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
The IOC (instant oil change) shops are supposed to put your car up on the computer and their database is supposed to tell them exactly how many quarts to fill. So if it's 5.5 they'll pump in 5.5 since they use a bulk barrel and a hose to dispense it, not bottles.
Once the oil has been changed, if you're concerned, pull out into their parking lot on a level place, turn off the engine and let it set several minutes, maybe even 10 or so. This will ensure the oil in the top has drained down. If the engine is warmed up it'll drain more completely.
Then pull the dipstick, wipe it, insert it, and pull it out again. Check for proper level.
Muffler mod on '09
Old 05-29-2011, 06:00 AM   #5
Everglades
CMF Senior Member
2009 Malibu 2LT
SilverIce Metallic
Everglades's Avatar
Gallery: 2
I never use the bulk oil from the barrel. I always get the full synthetic - which comes from bottles.
As far as changing it myself - I used to do that but long ago decided paying the extra to have someone do it for me was well worth the money.
2009 Mallibu 2LT
Old 05-30-2011, 08:19 AM   #6
slls
CMF Senior Member
5 quarts per owners manual
slls is offline   Reply With Quote Quick reply to this message
Old 05-30-2011, 08:35 AM   #7
TheMuskr
CMF Senior Member
2009 Malibu 2LT
Black
TheMuskr's Avatar
he's saying the shops use barrels. they do for synthetic too... just so they can buy it in bulk.
TheMuskr is offline   Reply With Quote Quick reply to this message
Old 08-23-2011, 04:13 PM   #8
Preston08
I work at an oil change place, like DD said, we enter each car by license plate into our computer, it pulls up the service history, last oil used and previous mileage. We offer our bulk oil from the tanks, which has 5-20, 5-30, 10-30, Multi ATF, Mobil-1 5-30, and Delo 15-40. If a guest prefers something else we have many others in bottles. And as far as our service goes, we fill the crankcase with the preferred oil, have the guest start the engine and we check the oil pressure gauge if it has one and then we turn it off, get on our knees and do what we call an excellence check with the downstairs lube tech, the excellence check is what we do to make sure the oil pan drain plug is on and tight, new seal if required. After that we show the guest the post service oil level before they leave.
Preston08 is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 02:40 AM   #9
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Garage
If I knew of an IOC shop that rose to that level of service I'd freqeunt them for every oil change. Thanks for the inside reveal, and with that level of service keep up the good job!
Muffler mod on '09
Old 08-24-2011, 06:06 AM   #10
MalibuKen
Banned
2011 Malibu 1LT+
White
I'll bet your insurance company would CRINGE (or worse) if they knew you were doing this.
Many places won't even allow the customer IN the car while it's in the building; they drive it in and they drive it out.
Last edited by DrivenDaily; 09-05-2011 at 10:42 AM. Reason: Removing public argument now that it's resolved
HTML code is On
2.4L Oil Change How too...? Jerkyking Do It Yourself Maintenance (Generation 7) 36 09-28-2010 08:58 AM
2010 2.4 Oil Change question quaf069 Do It Yourself Maintenance (Generation 7) 6 12-30-2009 06:13 PM
oil change on the 2.4 quaf069 Do It Yourself Maintenance (Generation 7) 0 12-19-2009 10:12 AM
oil change question zog1977 General Discussion (Generation 7) 3 03-24-2009 12:42 PM
First Oil Change Question Jcol General Discussion (Generation 7) 2 11-18-2008 02:28 PM
