Question about changing brake pads - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 06-06-2011, 10:48 AM   #1
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
Default Question about changing brake pads
I heard somewhere that on ABS systems you can't just push the brake caliper piston back in. In the past, I would just use a c-clamp to push the caliper piston back in, then put the new pads in and bolt it back up, done.
I heard that you have to pinch off the brake fluid line, unscrew the bleed screw, and then push the piston back in (while pushing out some brake fluid, resulting in a little brake fluid loss). Do you have to do it this way? Or can I just push it back in without doing anything else? Thanks.
Gray 09 Malibu lS
2.4l 4-speed Auto
onecrazyfoo4u is offline   Reply With Quote Quick reply to this message
Old 06-06-2011, 01:16 PM   #2
chevyguy8893
2009 Malibu LTZ
Silver Ice
chevyguy8893's Avatar
Garage
Default Re: Question about changing brake pads
Pinching the brake line on these cars could cause some damage to the inside of the line, and I would not recommend doing that. Plus, that is a good way to get air trapped in the system. Just compress the caliper piston as normal without opening the bleeder or pinching lines. I have done a lot of malibu's and GM cars this way, including mine, with no problems.
4 cyl w/6 speed auto
Silver Ice Metallic paint
-20% tint
Old 06-06-2011, 02:47 PM   #3
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
Sweet, exactly what I wanted to hear. Thank you, definitely will NOT pinch the lines!
Gray 09 Malibu lS
2.4l 4-speed Auto
Old 06-06-2011, 05:36 PM   #4
BillD64
CMF Senior Member
BillD64's Avatar
I agree. What you heard is a new old wive's tale. Don't have to do that on any car.
BillD64 is offline   Reply With Quote Quick reply to this message
Old 06-06-2011, 10:07 PM   #5
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
One last question, I put new Wagner Thermoquiets on the fronts tonight. They didn't come with new backing shims, so I reused the ones off of the old pads (and the worthless little clip). Is that okay to do, or should I not have done that? I drove it to bed them in, and they worked great...were mighty stinky though.
Those stupid squeeky oem pads had over half left on them!
Gray 09 Malibu lS
2.4l 4-speed Auto
Old 06-07-2011, 08:22 AM   #6
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
I'm just worried that I wasn't suppsed to put backing shims on the new pads. The box said something about don't put anti-squeek on them, like I do other pads. So I wasn't sure if the shims should be used or not?
Gray 09 Malibu lS
2.4l 4-speed Auto
Old 06-07-2011, 03:41 PM   #7
chevyguy8893
2009 Malibu LTZ
Silver Ice
Garage
You should be fine reusing the shims as long as they hold tight. If they come loose they will make noise, generally rattling. It is weird that they didn't come with new hardware. I have never used anti-squeak on anything for the simple fact that if it is done right the first time there shouldn't be any noise, but that is just me.
My OEM front pads made it to 60K with no squeaks, but they were almost gone. I am still on the factory rear pads at half left. I am happy with my ceramic pads, no noise or dust, and they stop great.
-20% tint
Old 06-07-2011, 03:48 PM   #8
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
Okay, I was just wondering what other guys had done. I know some other people have installed Wagner Thermoquiet pads on there bu. What did you guys do? Re-use shims, or no shims?
Hopefully they'll chime in here...
Gray 09 Malibu lS
2.4l 4-speed Auto
New rotors and brake pads!!! JramsLTZ Wheels, Tires & Suspension (Generation 7) 16 12-08-2012 05:10 AM
brake pads and rotors jeffsu350 Do It Yourself Maintenance (Generations 5 & 6) 37 07-24-2012 04:40 PM
What type of brake pads? onecrazyfoo4u Do It Yourself Maintenance (Generation 7) 33 10-22-2011 03:11 AM
Questions on: Rear Brake Pads/Drums, Parking Brake Cable and PS. vtcarol50 Do It Yourself Maintenance (Generations 5 & 6) 5 10-28-2010 09:17 AM
Aftermarket Brake Pads Pyro Wheels, Tires & Suspension (Generation 7) 1 04-20-2010 04:55 PM
