Changing the Transmission filter on my 4T45 this weekend.... - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 06-11-2011, 05:33 PM   #11
rluck9277
CMF Senior Member
2013 Malibu LS
Summit White
rluck9277's Avatar
Default Re: Changing the Transmission filter on my 4T45 this weekend....
Well I orginally wanted to go with Mobil Synthetic Dexron VI ATF, but I couldn't find it anywhere. They show it on their website, but it apparently is a new product that isnt available yet. So I ended up using Castrol Dexron VI, which is a synthetic blend. Not sure if it is the Castrol or just the fact that I have new fluid in there, but we took it to dinner and shiftes SOOO good. Never realised new fluid could make such a difference. And like I said above, it did have that clunk that every GM car with a 4T45 in it that I have been in has when you shift from reverse to drive, but it went away after the fluid good circulated and warm.
It ended up taking exactly 7 quarts to refill it. Here are a few pics....
The trans with the pan off
The pan after I got it, and the magnet cleaned, and the gasket on
Where the filter goes into the bottom of the transmission
Life begins at 140MPH...just wish I could get there!
rluck9277 is offline   Reply With Quote Quick reply to this message
Old 06-11-2011, 05:49 PM   #12
rluck9277
CMF Senior Member
2013 Malibu LS
Summit White
rluck9277's Avatar
Here is one more pic of the bottom of trans with the old filter off
I was kinda surprised at how little was under the pan. I remember on the 700R4 for my 88 camaro there was the valve body and all sorts of other valves and solenoids. I guess on a front wheel drive car the valve body is on the side.
If anybody else decides to do this themselves, it is very easy to drop the pan without spilling alot of fluid. Just make sure you have a big catch pan to catch the fluid, and start taking the bolts out in the middle of the pan that face the back of the car. Start in the center and work your way out, and after you get the back row out, the fluid starts coming out. I loosened the outer edge bolts a bit and it was coming out pretty well, so I just let it drain for awhile and when no more fluid was coming out, I just took the rest of the bolts out and dropped the pan. When you get the last three bolts or so, support the pan so that you dont bend the lip.
Then everythings else is pretty easy, there is no bolt holding the old filter in, just pull it down and out with a twisting motion, just make sure you have a drain pan underneath it cause there is about half a quart of fluid in it. Then use a screw driver and hammer to carefully tap in a side of the fitting that the filter goes into. Instal the new fitting, install the new filter, bolt the pan back up, and add 7 quarts of fluid.
Start the car, let it run a few minutes and then put it in reverse and drive and run it up through the gears acouple of times(Do this while on a hoist or jack stands, just be carefull). Then get underneath and pull out the fill/vent bolt. In my case no fluid was coming out, so added a half a quart and it almost instanly started coming out of the hole. So let it go a while till no more fluid was coming out and put the bolt back in. (This is all done while it is running). Then just take it down and go drive. Pretty simple.
Old 06-12-2011, 02:16 PM   #13
bullitt4204
CMF Senior Member
2010 Malibu LS 2.4 E85/4-sp
Summit White
bullitt4204's Avatar
Gallery: 1
Garage
Nice write up and pictures. I also have the same trans. I have 32K miles right now, so I not ready yet. While my car is under the 5yr/100K warrantee, I'll take it to the dealer so there is an official receipt should something crap out and they point the finger at me.
I usually do my own oil changes, but I just had the 1st one done since I bought mine in Jan '11, at the deal, so there would be a record of it. I did have them put in my Mobil 1 full synthetic oil in though. It only cost $18 with my oil, and they even washed it for me!
BUY AMERICAN, your job depends on it!
71k miles
2010 Malibu LS
Summit White ext, gray cloth int.
Factory installed rear lip spoiler
Optional spare tire
2.4 E85 capable
4 spd automatic
DIC AVG MPG = 30.5 MPG!
I love this car!
2012 Chevrolet Sonic LS
1.8 litre, 6 speed automatic (Wife's car)
2001 Mustang Bullitt #4204
Original owner 22K miles
2000 Mustang GT Convertible
Rare Sunburst Gold 100K miles
Over 50 years old. Still plays with cars!
bullitt4204 is offline   Reply With Quote Quick reply to this message
Old 06-12-2011, 05:08 PM   #14
MalibuKen
Banned
2011 Malibu 1LT+
White
Something is wrong with this picture.
32,000 miles in 6 months......and you are just now doing the first oil change ??
Is there a small detail missing here.....like you bought it used 6 months ago with ~ 25K miles already ON it ??
Old 06-13-2011, 05:50 AM   #15
bullitt4204
CMF Senior Member
Summit White
Gallery: 1
Garage
I bought it used in Jan 2011, with 27K miles on it. It's a 2010 Malibu.
71k miles
2010 Malibu LS
Optional spare tire
2.4 E85 capable
4 spd automatic
I love this car!
Old 07-15-2011, 04:51 AM   #16
nertil1
CMF Senior Member
2009 Malibu 1LT
Midnight Blue
For the procedure on the first page, what do they mean by "remove the air"
nertil1 is offline   Reply With Quote Quick reply to this message
Old 07-29-2011, 06:22 PM   #17
ElantraMax
CMF Veteran Member
I did my 4T45E at 25K Miles. Used a Purolator Filter kit and Castrol Dex VI. Used all 7 Qts. Had to reuse the factory Trans Pan Seal. When I hit 50k I am replacing it. Along with a new Purolator filter and Castrol fluid.
Formerly EscapeMax
2013 Hyundai Elantra Coupe GS
2010 Yamaha Majesty (YP400)
Old 08-10-2011, 05:50 PM   #18
knightblaze
CMF Junior Member
2011 Malibu LS
Silver
I do everything myself minus a tire rotation+balancing and trans fluid. I usually spend the $120 bucks and get it flushed/cycled out on a car for the fear that something like what was posted by several others occurring to me.. My Xterra was parked and chocked so easy to do, plenty of vehicle clearance without any jacking/ramps.
Heck, I don't even like being under the car with my Rhino Ramps. I don't trust anything short of a lift, but i don't have that luxury as much as I'd like.
knightblaze is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 11:37 AM   #19
onecrazyfoo4u
CMF Senior Member
2009 Malibu LS
Gray
Dang, I'm at 70k miles and still haven't changed the fluid. I NEED to do this! Thanks for the writeup!
Gray 09 Malibu lS
2.4l 4-speed Auto
onecrazyfoo4u is offline   Reply With Quote Quick reply to this message
Old 10-02-2011, 12:52 PM   #20
nertil1
CMF Senior Member
2009 Malibu 1LT
Midnight Blue
The manual also states to remove the oil level control valve and replace the O-Ring? It can be seen in the picture in post #12. Is this necessary or no?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Changing Air Filter 2010 malibu quaf069 Do It Yourself Maintenance (Generation 7) 13 01-12-2011 10:33 PM
Weekend GermWar Off-Topic Discussion 19 10-16-2010 10:58 AM
Getting LTZ Exhaust this weekend on my LT I4 :-) snowleopard Modifications (Generation 7) 5 09-25-2010 05:49 AM
First mod completed on the malibu this weekend. Fishhunter911 Modifications (Generation 7) 11 06-16-2010 09:31 PM
changing rims, changing speedometer Ktrace35 Wheels, Tires & Suspension (Generation 7) 4 05-15-2010 06:54 PM
