Oil Light comes on and then turns off while driving. - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 08-23-2011, 03:43 PM   #1
sjkslk09
1998 Malibu LS
Beige
Default Oil Light comes on and then turns off while driving.
Could anyone tell me why my oil light comes on temporarily while driving. I just changed the oil about 700 miles ago and the oil level is still full & looks like new still. I replaced the oil sensor and the problem is still there. Any thoughts, cuz I'm
sjkslk09 is offline   Reply With Quote
Old 08-23-2011, 04:14 PM   #2
MalibuKen
Banned
2011 Malibu 1LT+
White
Default Re: Oil Light comes on and then turns off while driving.
Maybe.....just maybe.....while you had the pressure sensor out, you should have actually measured the pressure ???
It can be caused by a variety of things from a plugged filter to an oil pump going bad to worn out bearings.
Does it come on at idle and then go off when you speed the engine up ??
At any rate, you probably should NOT drive it until you find out exactly what is going on. If the pressure is down because of a failing pump or a blockage, you might be chewing up your engine.
MalibuKen is offline   Reply With Quote
Old 08-23-2011, 06:23 PM   #3
Rodents
ASE Certified Technician
2011 Malibu 2LT
Yeah really you need to check the oil pressure with an external gauge to know what's really there. Should be 60psi at 1850 rpm using 5W30 oil.
Rodents is offline   Reply With Quote
Old 08-24-2011, 01:21 PM   #4
sjkslk09
1998 Malibu LS
Beige
Thumbs up Re: Oil Light comes on and then turns off while driving.
Thanks for the advice.
To answer your question, the oil light only comes on when I'm driving. It comes on & then goes right back out about a second or two later.
Something else I didn't mention is that I just had this engine completely rebuilt due to bad crank bearings. The engine currently has about 1500 miles on it since I put it back in & about 1000 miles since I changed the oil. I also only use 5W30 conventional oil, too.
Old 08-24-2011, 02:07 PM   #5
MalibuKen
Banned
2011 Malibu 1LT+
White
No reason to mention that; surely it could NOT be a factor..........
<sarcasm off>
You need to get it back to whomever did the lower end rebuild. Something is screwed up with the oil flow......or (pray a bit) that the wires are not making good contact going to the pressure sensor.
If you continue to drive it, you are flirting with disaster.
You may not post new threads
You may not post replies
Security Dash Light Stays On While Driving JDouglee Problems/Service Issues/Troubleshooting (Generation 7) 6 09-22-2012 12:41 AM
A/C turns itself off Nightcaste Problems/Service Issues/Troubleshooting (Generations 5 & 6) 20 07-06-2011 01:17 PM
Car turns over but won't start gibvel Problems/Service Issues/Troubleshooting (Generations 5 & 6) 7 06-15-2011 08:38 PM
A/C Turns On and Off allenzachary Problems/Service Issues/Troubleshooting (Generations 5 & 6) 12 08-07-2010 09:32 PM
LED driving light installed ElantraMax Modifications (Generation 7) 16 06-15-2010 07:16 PM
