Heater Core replacement tips? - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 09-01-2011, 02:31 PM   #1
ClassiX2
Default Heater Core replacement tips?
I need to replace the heater core (catastrophic failure, stop-leak won't work) in my 2004 Classic. Chilton's describes the process--basically involves removing the entire dash from the car.
I can follow instructions, but was wondering if anyone had some special tricks or tips to cut down on the amount of disassembly required?
Thanks,
Rick
ClassiX2 is offline   Reply With Quote
Old 09-01-2011, 07:01 PM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: Heater Core replacement tips?
You do realize that you're going to need to recover and recharge the A/C system correct? I can't say off the top of my head if there's any real short cuts, can't say I've done more than one or two of these myself and none recently. Quite a bit of removal here, sure you're up to it? If you get it apart and then decide you don't want to finish it, best of luck to you, some shops don't take that very well. If you need some more detail than Chilton gives, I'll try to help from GM service information.
Rodents is offline   Reply With Quote
Old 09-02-2011, 03:38 AM   #3
ClassiX2
Yes, Chilton's was pretty clear about the A/C issue, which is a bummer as that system is working just fine. I've got a few days cleared to put into it and will be taking notes as I go. This is definitely more complex than the last two cores I did--'49 Ford F-1 and a '56 Buick Century.
How long does the GM manual think this should take? I'll probably need triple that! Thanks for the assistance.
Rick
Old 09-02-2011, 10:06 AM   #4
ClassiX2
Well, I'm 3 hrs in. Chilton's isn't as clear or as applicable for this year and model as I thought it would be. I thought I was removing the dash COVER, which I did--mostly, until the steering wheel got in the way, a little detail not mentioned by Chiltons.
What it looks like the manufacturer intended is the removal of the ENTIRE DASH ASSEMBLY including sub-structures. That means there is nothing left between the seats and the firewall. Not sure if I'm ready to do that. I think I'll spend a few hours under the dash looking for other options.
Old 09-02-2011, 10:31 AM   #5
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
If I can make a suggestion - Since you'll be recovering the freon ANYWAY, I'd swap the evaporator while you were in there. My plans are when I swap the dash (which is cracked!) on the Cougar, I'll be swapping both cores while it's apart. Just because Ford apparently hung both in mid air and built the car around them ...
RwP
Old 09-02-2011, 10:33 AM   #6
Rodents
2011 Malibu 2LT
Now you've seen the light. I think Alldata showed 6.6 hrs to do the evap core not including recovery and recharge of the A/C system. Once you've done a couple yeah maybe down and back in a day, first one is not a money maker though. That's the bad part about the Haynes and Chilton type books anymore, they can't cover the material thoroughly enough for doing every job. Alldata is the same thing, just enough info to get you into trouble, then you're on your own.
If you still want to do this, let me know and I'll see if I can print out some of the stuff you need so I can email it to you. It's not the good old days anymore. I think you're going to find there's a couple screws and a panel or two in your way, not much but just enough to keep it from being done.
Old 09-02-2011, 11:40 AM   #7
ClassiX2
Good news! The heater core case is a 2 part unit--a few screws and the lower cover came off, a couple of nuts on the engine side of the firewall to make the core slide out easier, and it's out. Evap core not affected at all--it's farther up in the case--so there was no need to recover and recharge the A/C system at all--too bad I already paid for that...
Will do a detailed write-up when I've got the thing back together, paying careful attention to what DID NOT have to be done. BTW--it was Hayes, not Chilton's that led me astray.
Old 09-02-2011, 07:35 PM   #8
Rodents
2011 Malibu 2LT
Good! By the picture in GM service information it wasn't real clear if there were screws hidden along the way. Usually just a couple screws or a panel somewhere cause a lot of additional labor but you got it. Great. Books are only guides.
You may not post new threads
You may not post replies
Heater Core Flush Wozlo84 Do It Yourself Maintenance (Generations 5 & 6) 1 12-17-2010 09:59 AM
A/C Evap core swap? tx_northstar Do It Yourself Maintenance (Generations 5 & 6) 5 11-24-2010 02:11 PM
Appearance Tips Malo83 Washing, Waxing and Detailing 21 02-18-2009 07:18 AM
Pal Tips? sbebs General Discussion (Generation 7) 0 09-09-2008 11:13 AM
