Oil filter adapter leak. - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 09-23-2011, 06:02 AM   #1
jb94
Default Oil filter adapter leak.
2006 3.5 liter Malibu LTZ. I have an oil leak between the oil filter adapter and the block. Endless searching has not turned up anything on what type of seal is between the two. Is it an O ring or a gasket ? Any ideas on where I can find a replacement? Thanks in advance for the help.
jb94 is offline   Reply With Quote Quick reply to this message
Old 09-23-2011, 12:28 PM   #2
Chevrolet Customer Svc
Default Re: Oil filter adapter leak.
@jb94, have you visited such sites as Advance Auto or Autozone? These websites or even a phone call to them might prove to be helpful to your situation.
Please, keep in mind that the above websites that I have mentioned are not maintained by General Motors and we do not endorse the content that is in them.
Chevrolet Customer Svc is offline   Reply With Quote Quick reply to this message
Old 09-23-2011, 05:01 PM   #3
Rodents
ASE Certified Technician
2011 Malibu 2LT
Should be a metal plate type gasket with a sealing ring in the plate. Not sure if the aftermarket has them yet but your local dealer should.
Old 09-24-2011, 04:25 AM   #4
jb94
Thanks. Yes I have been to the websites. Didn't turn up much . I'll give them a call and see. I have a feeling I'll have to see a dealer for this one.
Old 09-26-2011, 09:19 AM   #5
@jb94, no problem. I apologize that you didn't find what you were looking for on the sites that I suggested. Did you call the dealership's parts department to see if you can get the part number from them?
Old 10-05-2011, 02:25 AM   #6
jb94
Here is the fix........about 10 bucks from your local GM parts counter. That's the old one in the photo.
Old 12-02-2011, 07:53 PM   #7
tjamscad
I have a 2005 LT 3.5 what made you go to the adapter gasket in the first place.
tjamscad is offline   Reply With Quote Quick reply to this message
Old 12-03-2012, 07:56 AM   #8
benfranklin
That's the baby. It's an easy fix. Remove the air cleaner tube and housing. Release the tension on the belt. Remove the two nuts on the front of the air compressor. The studs will come out too which is fine. Under the car loosen the third air compressor bolt. Only needs to be loosened to let the compressor move a little. Now you can get to the oil filter adapter bolt that was hidden. Loosen it. Remove the other two bolts and remove the adapter. Replace the gasket and install.
That gasket leaking is a common problem.
benfranklin is offline   Reply With Quote Quick reply to this message
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
which adapter should i get for new h.u.? gust_1980 Modifications (Generation 7) 1 03-08-2011 07:03 PM
Ipod adapter doubled50 Modifications (Generations 5 & 6) 26 03-04-2011 11:14 AM
Fuel leak... Lupa Do It Yourself Maintenance (Generations 5 & 6) 3 09-16-2010 06:15 PM
Fm Auxiliary Input Adapter connects to your factory radio though the antenna line ??! ectar Modifications (Generation 7) 1 11-14-2009 11:28 AM
ONstar Adapter? TintedOut09 Modifications (Generation 7) 0 11-12-2009 07:40 PM
