01 chevy malibu cooling fan issue - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 09-29-2011, 06:53 PM   #1
mainman1
2001 Malibu
green
Default 01 chevy malibu cooling fan issue
Hope there is some help out there.
My 2001 chev malibu is overheating, due to the cooling fans not turning on. "This car has been sitting for 2 years"
So, Ive replaced the thermostat, coolant temp sensor, tested all 3 relays and fuses which are all working correctly, pulled the pig connector off the coolant temp sensor and the fans turn on, bought a OBD2 reader and have no fault coming up, Ive had the intake gaskets done, ive performed the A/C test where you turn on the A/C and one of the cooling fans should turn on and neither are, searching the net for people with the same problem to see what fixed there problem. Hope to hear from some of you in regards to this issue.
Thanks Malibu owners and techs
mainman1 is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 10:16 PM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: 01 chevy malibu cooling fan issue
This overheating occurs real soon after startup? If the gauge just shoots up real quick, it could be head gaskets/cracked head or cracked block. If it warms up normal and just sitting in traffic it overheats, it would be nice to see what the PCM thinks coolant temp is. Odd that the fans came on when you disconnected the coolant temp sensor but not at any other time. Both fans came on or just one? Fuses COOL FAN 1 and COOL FAN 2 have 12 volts if you check them with a meter? If you have a way to jump past the relay without spreading the terminals in the fuse block, pull the fan relays out and jump pins 30 to 87 in the fuse block, the fans should work. The relays have pin numbers on them if you look closely at the bottom of the relay.
Old 09-30-2011, 04:02 AM   #3
mainman1
2001 Malibu
green
The overheating doesnt occur right away. It warms up normally and the slowly keeps rising. (vehicle is idle in the driveway) I havent let it quiet get to 3/4 of the way on the gauge. Both fans came on when i disconnected the coolant temp sensor. Which also makes the car rev up. After i did this I turned the car off and plugged the OBM2 back in and got a P0118 code. Which is engine coolant temp sensor high current i believe. Plugged the coolant temp sensor back in fans go off and turn the car off plug in the OBD2 and no codes. I will check for 12volts on cool fan 1 and 2 fuses. In regards to jumping past the relays. If im understanding you correctly, you would like me to put a jumper wire between 30 and 87 female terminals in fuse block. (meaning installing a wire between where the relay pins 30 and 87 would go in the fuse block)?
Old 09-30-2011, 04:28 AM   #4
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Garage
Wrong section, moving...
Muffler mod on '09
Old 09-30-2011, 08:27 AM   #5
99'Bu
1999 Malibu LS
Green
Not that it solves your problem... but the fans turn on when the temp sensor is unplugged because they're programmed to do that as a fail safe.
So at least you know that there is some communication going on there.
99'Bu is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 11:30 AM   #6
Rodents
2011 Malibu 2LT
Why do you think you have an overheating problem?
The temp gauge will go about 3/4 of the way until the fans turn on at somewhere close to 228 degrees. Does the A/C work? If the A/C doesn't work, turning it on won't turn the fans on. Yes, you understand correctly about jumping past the relays. What happened when you unplugged the coolant temp sensor sounds right without me looking it up to verify it. I'm beginning to question if you really have an issue at all.
Old 09-30-2011, 04:53 PM   #7
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
The OP may not have a problem.
I was that way back in 2002 with my 2000 Malibu - but the mechanic I was using at the time was kind enough to let me watch him monitor the ECM's ECT sensor reading.
The fan WOULD come on at about 228F - which was right below the red mark on my temp gauge!
Now, if the fan isn't turning on when the compressor for the A/C is engaged, that's a problem.
RwP
Old 09-30-2011, 05:30 PM   #8
Rodents
2011 Malibu 2LT
RwP
That's why I asked if the A/C worked. The ECM may see A/C request but it may not turn the fans ON if the A/C permission is NO. I'd suspect low refrigerant charge first if the A/C didn't work.
Last edited by DrivenDaily; 01-30-2012 at 10:51 PM. Reason: As requested by member
Old 10-02-2011, 01:03 PM   #9
mainman1
2001 Malibu
green
I will try running the temp gauge as high as i can to see if the coolant fans kick in. If no success is found i will take my car into a GM dealer and have my A/C unit checked out unless there is something i can do.
Thanks for all the help my wife and I really appreciate.
Old 10-02-2011, 01:07 PM   #10
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Before you do that yourself, get yourself a scanner that can monitor the ECT numbers - I'd hate for you to blow your motor because both the fan and the temp gauge were broken.
Monitor that, and see if the fan kicks on at about 220 to 230F. That'll also give you a ballpark for what that temp gauge actually means at various settings.
If you don't have one - I've posted links to a Bluetooth unit that can be paired with an Android or Windows Mobile phone to run software to monitor (I *HEART* Torque on my Android ... but eh.) There's also WiFi capable ones for iDevices. And of course the USB units for laptops.
RwP
2005 Malibu electric cooling fans dallam1 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 9 08-24-2011 05:03 AM
99 Chevy Cooling fans wont come Yosemite Problems/Service Issues/Troubleshooting (Generations 5 & 6) 9 02-09-2011 09:46 AM
99-J cooling issue muskratt Problems/Service Issues/Troubleshooting (Generations 5 & 6) 14 02-06-2011 06:08 PM
02 malibu cooling fan ayersrsa Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 04-26-2010 09:11 AM
2010 Chevy Malibu Dash issue dyeater123 Problems/Service Issues/Troubleshooting (Generation 7) 2 03-13-2010 01:00 PM
