INTAKE Camshaft Sensor - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 10-10-2011, 06:49 AM   #1
Kels
2009 Malibu LS
Silver
Cool INTAKE Camshaft Sensor
I would like to see if u guys can help me out with an issue I have with me car. I have an 09' chevy malibu 2.4L the check engine light is on, I ran it throught autozone to see the reason for the check engine light to be on. That stated, in was due to intake camshaft sensor, code is P0010. There are two camshaft sensors, one in front of the cylinder block and in the back as well. My question is, which one is for the intake sensor? I checked both connectors n they are fine, both are conneted as they should be and not damaged. Any help would do. Thx! -Kels
Kels is offline   Reply With Quote Quick reply to this message
Old 10-10-2011, 06:50 AM   #2
Silver LTZ
CMF Honorary Member
Silver LTZ's Avatar
Gallery: 3
Default Re: INTAKE Camshaft Sensor
Moving to correct section.
Silver LTZ is offline   Reply With Quote Quick reply to this message
Old 10-10-2011, 07:49 AM   #3
Kels
2009 Malibu LS
Silver
U mean as in rotating the sensor?!
Old 10-10-2011, 11:05 AM   #4
Silver LTZ
CMF Honorary Member
Silver LTZ's Avatar
Gallery: 3
Um, no meaning as you posted this in the wrong section and I moved it.
Old 10-10-2011, 12:31 PM   #5
MalibuKen
Banned
2011 Malibu 1LT+
White
Sometimes just LOOKING at them and tugging on the wires is not enough.
Often you need to unplug the connectors and look at the contacts for signs of corrosion, then plug them back in. If it was an intermittant connection, sometimes just doing that will fix it.
Old 10-10-2011, 12:54 PM   #6
greenman
ASE Certified Technician
DTC P0010: Intake Camshaft Position Actuator Solenoid Valve Control Circuit
That code typically means the cmp actuator solenoid valve (or it's wire harness) has a problem. You need to take any info you get from an autozone clerk with a grain of salt. Always verify it for yourself.
Most of your questions will be answered by reading this recent thread:
http://www.chevymalibuforum.com/foru...ighlight=P0010
Measure the resistance of the intake cmp actuator solenoid valve across the pins. Should be 5-9 ohms on that MY 2.4 engine. Then check resistance bet each pin & the housing. Should not be infinite (shorted).
Old 10-10-2011, 04:12 PM   #7
MalibuKen
Banned
2011 Malibu 1LT+
White
Make that should not be ZERO (shorted).
Infinite is good.
Old 10-10-2011, 05:56 PM   #8
greenman
Infinite is good.
Whoops.....talk about a brain fart. Thanks for catching that.
Old 01-06-2012, 08:28 AM   #9
2001FZ1
CMF Senior Member
2001FZ1's Avatar
spreading the word. P0010 fault will probably be covered under the 5yr, 100k warranty
http://www.chevymalibuforum.com/foru...?t=8987&page=2
Joe
2005 Suzuki GSXR 1000 - Akrapovic, PC3, Schnitz Racing tune - 166hp
93 Z/28, 04 Buick Rainier AWD, '08 Chevy Malibu
2001FZ1 is offline   Reply With Quote Quick reply to this message
2009 Mailibu - 2.4L - Check Engine - Intake Camshaft Position Sensor coopdog Problems/Service Issues/Troubleshooting (Generation 7) 8 08-12-2014 04:43 PM
Camshaft problem Chevymechanic Problems/Service Issues/Troubleshooting (Generations 5 & 6) 9 03-26-2014 10:03 AM
Where is the camshaft postion sensor on a 2009 Malibu rmp243 Do It Yourself Maintenance (Generation 7) 4 08-17-2011 07:39 PM
intake ?'s GTPMALIBU Modifications (Generation 7) 1 06-05-2008 12:02 PM
