How-To: Front License Plate Bracket Removal and Plugging - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 11-05-2011, 04:12 AM   #1
Mike7143
CMF Senior Member
2008 Malibu 2LT
Gld/Pwtr Metallic
Mike7143's Avatar
Post How-To: Front License Plate Bracket Removal and Plugging
Forgive me for not taking pictures of the removal process.
1. Examine how bracket is attached to your car. Mine was attached with rivets. I believe some may be attached with bolts?
2. Get yourself a drill and 2 drill bits. One should be slightly larger than the inner tube of the rivet and the other about 3/4 the diameter of the larger outer part of rivet head.
3. Drill with the smaller bit straight through the rivet shank. If the rivet spins (not likely at this point) then try and hold it down with a flat-head screwdriver.
4. Switch to your large drill bit. Now drill off the head of the rivet. This time you'll almost certainly have to use a flat-head screwdriver to keep the whole rivet from spinning.
5. At this point, you should be able to pull the bracket off completely.
6. Reach your arm under and up to try and retrieve the back end of the rivets. Or just push them in from the outside and don't collect them.
7. Plugging the holes. If your bracket was attached with rivets, the holes should be relatively small, about a 1/4" or less. Mine were fairly small. I know that members here have used bumper plugs but I thought they were too expensive so I went to Home Depot.
8. Measure how big the holes are in the front. I used a pencil point poked in and noted where it came to... (sorry, no calipers at home haha)
9. Go to the hardware section of Home Depot (or a hardware store). NOT the cabinet knobs and hinges "hardware" aisle, but the nuts, bolts, etc. hardware one.
10. I found my plugs in a drawer mixed in with the nuts and bolts. It was in a drawer labeled "Hole Plugs".
11. Select a plastic snap-in plug that is slightly larger than whatever your holes measured. There were also zinc plated steel covers but I went with the plastic as I figured they'd be easier to paint but you can pick whatever you want.
12. Once back at home (or in my case, the HD parking lot...) get yourself another drill bit that is about 1/16" smaller (possibly 1/32" smaller) than the size of plug you bought. Mine were 1/4" plugs. Drill your holes in the bumper with the bit.
13. Pop in your plugs! At this point, you can paint them to match or I guess paint them prior to pushing them in. Walla! No plate holder with plugs!
Below are some pictures of how big my 1/4" plugs look. Sorry I haven't painted them yet, but that'll come soon. They appear to look a lot smaller than some of the others used based on posted pictures from other users.
Here's the bag that mine were in if you need help finding these things:
Picture of the cap. It's got a lot smaller head from what I can tell vs. other caps.
Measuring tape, I mean... Pencil eraser for size.
Pics of the front, sorry they aren't painted yet:
So yeah, I hope that helps some of you that are in the boat I was... aka couldn't find these "plugs" in the hardware stores. Now you've got an SKU and hopefully decent description of the location of them!
2008 2LT Golden Pewter Metallic : 20% Tint : Nitto Motivo 225/50-R17
Mike7143 is offline   Reply With Quote Quick reply to this message
Old 11-05-2011, 05:54 AM   #2
DrivenDaily
2011 3.6/ A6 LTZ
DrivenDaily's Avatar
Gallery: 6
Default Re: How-To: Front License Plate Bracket Removal and Plugging
Good job, and thanks for taking the time share.
Muffler mod on '09
Old 02-22-2012, 02:37 PM   #3
boro
CMF Senior Member
2008 Malibu LTZ V6
Silverstone Met.
boro's Avatar
Great write up! I just did this today.
Everything was exactly as stated. I found the plugs in my Home Depot. My holes ended up being 3/16", so I used plugs of the same size and they fit very snugly in place.
I noted you said that you didn't take pics of the removal process, honestly it's so simple it may not be required, but I thought I'd throw mine up in case they help someone in the future.
There's the three rivets you need to remove...
One after drilling, and one partway through...
They just pop right off very easily.
Then, pull your front plate frame. The rivets should push out easily, if not you may need to drill the remainder out. I did on the right side hole. Then clean and polish your surrounding paint if necessary...
And then pop your plugs in!
In this picture they are painted with a couple of coats. They might need another two or so, but the paint should darken to match when dry.
Total cost: $1 for four 3/16" hole plugs (I already had the correct color touch up paint). That's a huge savings over actual painted bumper plugs which go for $25-$50. I'll spend the savings on beer instead.
Hope that helps. Great write up again!
2008 Chevrolet Malibu LTZ Silverstone Metallic Ebony/Brick 3.6L V6
boro is offline   Reply With Quote Quick reply to this message
Old 02-22-2012, 08:23 PM   #4
EnvoyBu
2014 ATS4 Premium
Black Diamond
EnvoyBu's Avatar
Can you paint them with touch up paint if you chose to do so?
Present:
2014 Cadillac ATS4 3.6L Premium Collection
2006 GMC Envoy SLT
Past:
2011 Chevrolet Malibu LTZ V6 (29,520 miles)
Black Granite on Cocoa Cashmere with 3.6L V6, Sunroof, and... Cargo Nets!
EnvoyBu is offline   Reply With Quote Quick reply to this message
Old 02-22-2012, 08:44 PM   #5
boro
CMF Senior Member
2008 Malibu LTZ V6
Silverstone Met.
boro's Avatar
That's exactly what I used, actually. Dries very well to match the rest of the paint.
Old 02-22-2012, 08:57 PM   #6
EnvoyBu
2014 ATS4 Premium
Black Diamond
EnvoyBu's Avatar
Indeed, I missed that part. Sorry about that.
Anyhow, great job on the car!
Present:
2006 GMC Envoy SLT
Past:
Old 02-22-2012, 11:09 PM   #7
MrRichRod
CMF Veteran Member
2012 1LT w/ All-Star
Black Granite
MrRichRod's Avatar
This is a perfect write up. Easy, cheap, and leaves left over money for beer.
2012 1LT 2.4L/A6 (LE5) in Black Granite w/ All-Star Pkg.
2009 2LT 3.6L/A6 (LY7) in Black Granite
1995 MX-5 1.8L/M5 Miata
MrRichRod is offline   Reply With Quote Quick reply to this message
Old 02-23-2012, 11:47 AM   #8
EnvoyBu
2014 ATS4 Premium
Black Diamond
EnvoyBu's Avatar
Or in the circumstance that the individual is under 21 (-_-), Coca Cola.
Present:
2006 GMC Envoy SLT
Past:
Old 02-23-2012, 04:22 PM   #9
DrivenDaily
2011 3.6/ A6 LTZ
Gallery: 6
Or in my case, Peach Schnapps or a wine cooler. (Can't stand the taste of beer, but it sure smells good!)
Muffler mod on '09
Old 02-23-2012, 09:40 PM   #10
MrRichRod
CMF Veteran Member
Black Granite
MrRichRod's Avatar
Yes, yes, very true. Equal opportunity forum.
Or Peach Schnapps, or a wine cooler.
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Removal of front license plate bracket justind Modifications (Generation 7) 10 01-13-2012 12:03 PM
Front license plate bracket? skylarjessen Modifications (Generation 7) 2 10-16-2010 04:12 AM
Front license plate bracket for '08-'09? tabeytabe General Discussion (Generation 7) 16 03-29-2010 05:29 PM
LTB: Front license plate bracket dreamer02 Trading Post (See rules before posting an item for sale!) 3 08-25-2009 10:47 PM
Help take off front license plate bracket 2wlhyp Modifications (Generation 7) 4 07-03-2008 01:27 PM
