Replacing outer tie rod on 2000 Malibu - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 01-24-2012, 10:48 AM   #1
LDollar
Default Replacing outer tie rod on 2000 Malibu
What is a ball park estimate of the cost to have the outer tie rods replaced ?
I can't seem to get our local repair shops to provide an estimate without taking the car to them, which is difficult right now ?
LDollar is offline   Reply With Quote Quick reply to this message
Old 01-24-2012, 07:56 PM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: Replacing outer tie rod on 2000 Malibu
Rough guesstimate, 200 to 300 bucks. Figure an hour at least of labor, maybe 1.2 but no more than 1.5 hrs. Need to at least set toe but a full alignment wouldn't hurt either. Don't go OE tie rods. Moog, TRW, pretty much anything except OE rods.
Old 01-24-2012, 09:38 PM   #3
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Do you mean "OE brand" or "ACDelco" by "OE"?
IF the former, ayep.
If the latter - well, MINE lasted almost 300,000 miles factory ... silly me put two more back in with a track record like that!
On the rack bellows - on the Cougar, when I did the inners on it, I replaced the bellows with DuraLast brand bellows, which lasted about a year. Replaced those with Moogs when I did the outers on the Cougar - those lasted two months(!!!) Now have ACDelco on them, but the car's currently sitting (injectors for it just came in), so I only have about 10,000 miles on those.
I'll add that if you're doing the OUTERS, I'd look hard at doing the INNERS at the same time. Would have made my life easier on the Cougar.
RwP
Old 01-26-2012, 02:48 PM   #4
LDollar
Got it done for $301, from a local tire store here in Oklahoma City. Two outer tie rods at $60 each, $75 labor, and $70 for an alignment.
thanks for the replies
Now I need to figure out how to replace the PCV valve assembly myself.
Old 01-26-2012, 06:11 PM   #5
Rodents
2011 Malibu 2LT
I mean the OE, with the long GM number, which ACDelco does sometimes offer under a short ACD number. However, most ACD parts are repackaged non OE parts so they could be sourced any number of places. If you have good success with factory stuff, go for it. I can do as good or most times much better in my opinion going to Moog. Take the 45A0705 tie rod for your generation Malibu. That is not an OE part, it's supplied from the outside and repackaged in an ACD box. Your results are not typical but a few good ones slip through from time to time.
PCV valve is in the front valve cover, might have a bracket over it which you're supposed to replace the valve cover to replace the valve. Should be able to remove the bracket and the valve. CV892C should be the PCV valve you need.
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Replacing the interior lighting of the malibu aliitp Modifications (Generation 7) 60 09-01-2011 08:13 PM
FS : Fog lights and lower outer grilles Brossard Trading Post (See rules before posting an item for sale!) 11 05-13-2011 09:29 AM
2000 malibu logan1 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 03-25-2011 05:19 PM
2001 Malibu Overheating even after replacing everything. Please help crushmark80 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 9 12-21-2010 05:58 PM
Replacing thermostat on 2005 Malibu Classic MILK6969 Do It Yourself Maintenance (Generation 7) 0 08-09-2009 09:20 AM
