oil change malibu 2005 2.2 engine - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 03-19-2012, 08:00 PM   #1
dvjorge
2005 Malibu ls
green
Default oil change malibu 2005 2.2 engine
Hi guys,
I own a 2005 Malibu with a 2.2 engine. I do the oil change myself but have noticed that using 5 quarts the dipstick only reach the lower mark. I have to put an extra quart, I mean 6 quarts to get the top mark in the dipstick.
I don't know why this happens or what is wrong ?? The dipstick is the original.
Do someone else who own a 2.2 engine experience it ??
Thanks.
dvjorge is offline   Reply With Quote Quick reply to this message
Old 03-19-2012, 09:03 PM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: oil change malibu 2005 2.2 engine
Spec is 5 quarts. I've seen a few where it doesn't get right at the top with 5 quarts but can't say I've done one that needed 6 full quarts. You bought the car new or used? Reason I ask is, how are you sure dipstick is the original?
Old 03-19-2012, 10:06 PM   #3
Drunken Elvis
CMF Veteran Member
2006 Malibu LS 2.2
Silver
Drunken Elvis's Avatar
I have a 2006 with a 2.2. I bought it used in January. When I drained the oil, about 5.7 quarts came out. I added 5 quarts and it was not full, added another .3 quarts to get it to the full mark. This is a little more than the book says the engine is supposed to take. I don't think I'd run with 6 quarts and I would just consider the middle of the stick the full mark. I wonder if any one else has this problem?
Drunken Elvis is offline   Reply With Quote Quick reply to this message
Old 03-20-2012, 10:06 AM   #4
Rodents
2011 Malibu 2LT
The dipsticks aren't always right on either. Maybe 10 years ago, give or take a couple, Corvette capacity was 6.5 quarts and even with 7 quarts in them, the level wasn't at the top of the range. GM actually issued a bulletin stating the capacity was 6.5 quarts and as long as you were withing the crosshatched area to not add more as to do so may induce oil consumption due to an overfilled crankcase. The level at 6.5 quarts was to be considered the full mark. Think that wasn't fun to explain to a 'vette customer? Had to print that one out for quite a few customers to get them to believe us.
Old 03-20-2012, 11:17 AM   #5
Chevrolet Customer Svc
I have read through this thread and I find the information very interesting; especially when the owner's manual reads different.
You guys and gals know that I am not a technician and I don't pretend to be, but on page 5-93, it reads that the 2.2 liter, L4 engine take 4.0 quarts of oil or 3.8 liters of engine oil.
You have my curiosity up as to why there is such a huge difference in information. I guess I am going to have to do some research on this one.
Available Monday-Sunday
Chevrolet Customer Svc is offline   Reply With Quote Quick reply to this message
Old 03-20-2012, 12:00 PM   #6
I think that you are making a wise decision not over fill the oil. In the owner's manual it reads that over filling the engine oil can case issue and damage with the engine.
Old 03-20-2012, 03:19 PM   #7
dvjorge
2005 Malibu ls
green
This is going to be a problem for me. If I put only 5 quarts, the dipstick only reach the low mark, so I don't know if the engine is low in oil. I don't know if the real indicator is the dipstick or it is enough knowing I put 5 quarts.
I think Chevrolet has some problem with it.
Thanks.
Old 03-20-2012, 03:28 PM   #8
dvjorge
2005 Malibu ls
green
I re-checked the car oil 3 more times. Yes, 6 quarts is the top mark on the lipstick. I am not sure if it is smart to drain some oil or if need time I try 5 and 1/2 quarts. For sure 5 quarts is the lower mark.
Thanks.
Old 03-20-2012, 03:36 PM   #9
Drunken Elvis
CMF Veteran Member
2006 Malibu LS 2.2
Silver
This thread got me thinking so I checked the oil today when my wife got home with the Malibu. I haven't checked it since I changed the oil in late January and I was surprised to find it was slightly over filled. Two other things might be notable.
When I filled the engine with oil, it was difficult to pour the oil into the engine quickly as a baffle or some other item seems to partially block the entrance of oil. Perhaps the oil is slow to find it's way to the crankcase and this makes it difficult to accurately measure the oil level while performing an oil change. Secondly, the oil dipstick is not made of a long flat stamped steel ribbon like other vehicles I have owned, instead, it appears to be made of a relatively stiff cable. The "dipstick" tube also enters the engine at a shallow angle. Perhaps this type of "dipstick" is simply inherently inaccurate.
This is page 5-107 of my Canadian Malibu owners manual. Page 5-93 does not contain any oil related information. Note the quantities listed.
Old 03-20-2012, 05:48 PM   #10
chevyguy8893
2009 Malibu LTZ
Silver Ice
chevyguy8893's Avatar
Garage
Are you checking the oil when the car is hot or cold? If I check mine on level ground cold it will read at the bottom mark or just a little above. Then, if I check it hot on level ground after it sits for about 15 minutes, it is at the full mark with 5 quarts. I have encountered on some cars where the dipstick reads two different levels on either side. Personally I would stick with what level it calls for, but that is just me.
4 cyl w/6 speed auto
Silver Ice Metallic paint
-20% tint
After my oil change my engine seems a bit louder!! ishrios Problems/Service Issues/Troubleshooting (Generation 7) 5 04-14-2011 06:58 AM
Going to do my first oil change in my 03 Malibu and I need help please kpointer25 Do It Yourself Maintenance (Generations 5 & 6) 14 03-10-2011 01:03 AM
Oil and Filter Change 2.4L Malibu LT1 LT1Malibu New Member Introduction 4 03-06-2010 08:42 AM
Change engine? Darkcircle169 Modifications (Generation 7) 0 05-15-2009 05:13 PM
2008 Malibu LT2 2.4L first oil change MalibuCanuk General Discussion (Generation 7) 39 11-15-2008 06:35 PM
