Is it easy to replace the brake pads on your own? - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 04-02-2012, 03:47 PM   #1
troykillman
CMF Junior Member
2009 Malibu 1LT
Imperial Blue
Post Is it easy to replace the brake pads on your own?
My rotors were replaced by the dealership under warranty less than a year ago, and I know I am looking at needing new brake pads pretty soon.... I don't want to have to pay to have them done if I don't need to.. Does anyone know how easy it is to replace the pads just at home? Is it worth doing to save the money?
troykillman is offline   Reply With Quote
Old 04-02-2012, 06:49 PM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: Is it easy to replace the brake pads on your own?
It's not hard at all. Probably a Haynes or Chilton manual would cover it well enough if you never did it before. Is it worth it? Sure. If you take the time to do it the way it's supposed to be done, you'll be better off anyway. Too many shops just slap the pads on and don't clean anything up. Average DIY'er could do better work.
Rodents is offline   Reply With Quote
Old 04-03-2012, 05:11 AM   #3
MalibuKen
Banned
2011 Malibu 1LT+
White
Maybe. IF you have any good mechanical experience......or apptitude.
For some people, disk brake pads are a good first repair experience.
For some, they shouldn't attempt ANY mechanical projects like that and only YOU know if you are competent or skilled enough to pull it off.
Gotta ask though: When they did the rotors, did they not put on new pads then too ?? How many miles on this set of pads ?
This is a quick and easy operation for an experienced mechanic. Before you decide, check the cost at a shop or two. It might be less than you think and you might decide it isn't worth getting your hands dirty.
MalibuKen is offline   Reply With Quote
Old 04-03-2012, 03:04 PM   #4
Mike7143
CMF Junior Member
2008 Malibu 2LT
Gld/Pwtr Metallic
Mike7143's Avatar
Don't mean to hijack, but along the same lines, real quick, is the rotor held on with a 37mm nut? Or is it floating and I just pop the calipers off, the bracket off, and off comes the rotor? Gotta replace my fronts and pads, shaking gets worse every day.
EDIT:
OP may want to check out this video too, it's for rotors, but shows you what you've gotta do for a brake change too basically.
Did they change the method from this?
2008 2LT Golden Pewter Metallic : 20% Tint : Fierce Instinct ZRs
Mike7143 is offline   Reply With Quote
Old 04-03-2012, 06:37 PM   #5
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
They "float" - that 37mm nut is to hold the HUB to the AXLE (or the knuckle on the non-driven wheels).
However, a) there may be retainer clips on the studs to hold the rotors on (put on during assembly - they don't want those rotors falling off before the calipers are put on!), and b) it's amazing how well rust will keep a rotor on.
So it may take a few grunts or some work on the retainer clip(s). But basically, yes, the caliper/pads hold it in place.
RwP
Old 04-30-2012, 07:30 AM   #6
dennisk
CMF Junior Member
If you decide to change your pads, while you have the caliper off, check your caliper pins. I clean mine and regrease them with caliper pin grease. Don't use the molykote, buy specific caliper pin grease. It'll withstand higher temperatures.
dennisk is offline   Reply With Quote
Old 05-01-2012, 12:23 PM   #7
malibu_2010
CMF Senior Member
That guy in video should have cleaned the hub with wire brush then apply silicone grease to the surface where back side of the rotor meets the hub to slow down rusting before he installed the rotor.
malibu_2010 is offline   Reply With Quote
Old 05-17-2012, 11:19 PM   #8
ric0h
anyone know the part number for the pads?
I can only find them in auto zone.
DG1160
DGC1364
Are these the original ones?
ric0h is offline   Reply With Quote
Old 05-21-2012, 05:10 PM   #9
hoahai
CMF Senior Member
DG1160
DGC1364
The OEM for my front brake pad is ACDelco 17D1160CH. It is the same kind quoted by my Dealership. It is also the same one in the Catalog of GM Parts Direct web site.
Check Amazon.com, it is only about $40 , including shipping.
Amazon Amazon
I ordered one yesterday. Don't know when I will need to replace them yet. My Bu is currenlty 41K miles and the brakes still feel like the first day.
08 2LT White/Titanium, 4cyl/4spd
Born 04/08 Lake Orion
MPGTune.com Mileage History
hoahai is offline   Reply With Quote
Old 05-25-2012, 05:21 AM   #10
vettenuts
CMF Junior Member
I finished installing Centric Street Performance pads and their e-coated high carbon rotors. The parts looked very good and fit well, but I wasn't fond of the rotors being built in China although my last GM rotors were also made there.
vettenuts is offline   Reply With Quote
You may not post new threads
You may not post replies
brake pads and rotors jeffsu350 Do It Yourself Maintenance (Generations 5 & 6) 37 07-24-2012 04:40 PM
What type of brake pads? onecrazyfoo4u Do It Yourself Maintenance (Generation 7) 33 10-22-2011 03:11 AM
Brake Pads nertil1 Do It Yourself Maintenance (Generation 7) 20 09-08-2011 06:45 AM
Brakes, time to replace those pads. elcompaLalo Do It Yourself Maintenance (Generation 7) 10 07-05-2011 09:48 AM
Questions on: Rear Brake Pads/Drums, Parking Brake Cable and PS. vtcarol50 Do It Yourself Maintenance (Generations 5 & 6) 5 10-28-2010 09:17 AM
