TPMS Progamming without Fob - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 04-06-2012, 05:45 AM   #1
Norton
2008 Malibu LS
Techno Grey
Default TPMS Programming without fob
Hi,
I have a 2008 LS which has an aftermarket remote start installed on it. My question is, is there an alternate method to get the DIC into the TPMS learning mode when you don't have the OEM fob?
I tried the process (listed in this forum) that uses the OEM fob using my aftermarket fob instead, but it will not go into learning mode.
Thanks.
Norton is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 07:16 AM   #2
chevyguy8893
2009 Malibu LTZ
Silver Ice
chevyguy8893's Avatar
Default Re: TPMS Progamming without Fob
If I remember correctly it can be activated in the secondary menu on the DIC. Press the back button and the info button on the steering wheel at the same time to access the other menu. Then, use the info button to cycle through that menu. I may be wrong and mixing it up with the process on other GM cars.
4 cyl w/6 speed auto
Silver Ice Metallic paint
-20% tint
Old 04-06-2012, 09:00 AM   #3
Norton
2008 Malibu LS
Techno Grey
Thanks chevyguy,
I did try this a while back but as I recall on the secondaty menu you can only access changes like lauguage, auto door locks, chimes, etc . I didn't see any menu option to get into TPMS learn mode.
My wife is out of town with the car at the moment but I'll try it again when she's back tomorrow just to make sure I didn't miss anything.
thanks,
Old 04-06-2012, 11:23 AM   #4
chevyguy8893
2009 Malibu LTZ
Silver Ice
I just double checked, and I was wrong. The secondary menu doesn't have it, I mixed it up with other cars. The only method, other than the remote, that I know of is using the tech II scan tool to put the TPMS into learn mode.
-20% tint
Old 04-06-2012, 12:35 PM   #5
GeeEssFore
2008 Malibu Ls
GeeEssFore's Avatar
Most tire shops can reprogram through OBD2 port. We use a scanner called Bartech and it can do it without key FOB.
GeeEssFore is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 03:19 PM   #6
Norton
2008 Malibu LS
Techno Grey
Ok thanks guys. But in that case, I think I might just go buy an OEM fob then. I don't want to have to go to dealer or a tire shop for programming twice a year since I also use snow tires with TPMS sensors in them in the winter.
As long as I can have both the OEM and aftermarket fobs programmed to work on the vehicle at the same time, not sure if that will be an issue as the might interfere with each other(??)...I hope not.
Cheers.
Old 04-06-2012, 06:10 PM   #7
09LT2
CMF Senior Member
2009 Malibu 2LT
White
09LT2's Avatar
No they will not interfere... Aftermarket doesn't use the factory remote computer. It has it's own brain.
Mine:
2009 Summit White LT2 3.6L V6
Factory Fog Lights Added
Hers:
2009 Performance Red Metallic Pontiac G6 2.4L 6Spd
Factory Fogs added
Black SPO Upper and Lower Grilles
09LT2 is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 06:46 PM   #8
MrRichRod
CMF Veteran Member
2012 1LT w/ All-Star
Black Granite
MrRichRod's Avatar
You can purchase the Kent Moore EL-50448 GM TPMS tool for $63 if you'd rather. This is the consumer tool that's required for '12 Malibu's but will work with previous years models.
http://gmspecialservicetools.spx.com...s.aspx?id=5677
More info on the subject can be found here.
2012 1LT 2.4L/A6 (LE5) in Black Granite w/ All-Star Pkg.
2009 2LT 3.6L/A6 (LY7) in Black Granite
1995 MX-5 1.8L/M5 Miata
MrRichRod is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 07:27 PM   #9
GeeEssFore
2008 Malibu Ls
GeeEssFore's Avatar
The car can only store 4 diff tpms at a time.
Old 04-06-2012, 07:30 PM   #10
GeeEssFore
2008 Malibu Ls
GeeEssFore's Avatar
That tool only activates the sensor but will not turn car into learning mode with a fob
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Tpms jjsanicky23 Wheels, Tires & Suspension (Generation 7) 12 02-02-2011 06:52 PM
TPMS set-up point roco Wheels, Tires & Suspension (Generation 7) 1 08-09-2010 10:01 AM
TPMS question twiztedtrav Wheels, Tires & Suspension (Generation 7) 8 08-02-2010 08:26 AM
TPMS or no TPMS? Keller Wheels, Tires & Suspension (Generation 7) 7 07-08-2010 05:55 PM
Tpms ? Bud General Discussion (Generation 7) 7 11-22-2008 05:21 PM
