Infotainment Sys Crash - Chevy Malibu Forum: Chevrolet Malibu Forums
 2Likes
post #1 of 15 (permalink) Old 02-02-2018, 09:51 AM Thread Starter
Everything was ok until I killed the engine. Went to an appointment and came out to car and I noticed the greeting screen didn't display.
The stereo wouldn't power on; just a black screen
I figured maybe a warm boot woukd fix it so I killed the engine and open/closed tne door.
It still wouldn't boot up and eventually came up to a Linux boot screen.
Made an appointment for next Friday.
Anyone else had this issue?
See attached image.
Shstrang98 is offline
post #2 of 15 (permalink) Old 02-02-2018, 09:20 PM
Re: Infotainment Sys Crash
I had this same screen maybe 2 months ago.
Screen would not go away so I let the car sit over night and it was back to normal.
Sent from my iPhone using Tapatalk
Shstrang98 likes this.
RMJr is offline
post #3 of 15 (permalink) Old 02-04-2018, 07:54 PM
I have had issues where the touchscreen and volume control are not responsive, ive let the car sit all day at work cam out and its fine.
always wanted to try and pull the battery cable off, just to see if that would help reset it quicker but havent had the chance yet
knightp25 is offline
post #4 of 15 (permalink) Old 02-04-2018, 11:37 PM Thread Starter
It looks like the stereo is trying to recover from a crash or wants an update.
Mine is under warranty still so the dealer will have enjoy fixing it.
For fun I looked in the manual and noticed that it shows f42 for the fuse. I opened the panel and the fuse block is totally different than the manual and the diagram on the panel cover.
post #5 of 15 (permalink) Old 02-05-2018, 05:04 AM
There are several fuse blocks in the car, in many different places. I’d say most likely you’re looking at the wrong one.
miweber929 is offline
post #6 of 15 (permalink) Old 02-05-2018, 07:30 AM
That is not an update going on, it look like an operating system kernel crash. All of the fuse blocks in the manual look just like they do in the car, as Miweber929 said you're looking at the wrong fuse box.
Another thing to try is holding the power button on the audio system down for about 5 seconds to force it to shut down completely (the screen will go completely black except the clock and temperature). Then try to power it back up.
Still, it looks like a hard crash though so the power down/up might not work, maybe its a botched over-the-air update or you had some IC in the audio system go kaput. I've had a few updates pushed on my car and all I saw in the display, while the USB music was playing, was "updating" occasionally showing at the bottom of the screen.
rebeccazfh likes this.
tnmats is online now
post #7 of 15 (permalink) Old 02-05-2018, 07:55 AM
campb292's Avatar
This is an issue affecting 8" MyLink systems. There is an update for it. See bulletin here: https://www.dropbox.com/s/tb2wau05ts...adPdf.pdf?dl=0
2016 Malibu 1LT 1.5T
2016 Crosstrek Premium 2.0L
2018 F-150 XLT 5.0L
campb292 is offline
post #8 of 15 (permalink) Old 02-05-2018, 12:12 PM Thread Starter
...it look like an operating system kernel crash
I figured thats what it was. It says 'linux" at the top of the screen so I figured it must be Linux based.
Tried that since my wifes buick encore sometimes takes a dump and warm booting seems to work.
The malibu screen is all black with no time/'temp until the linux screen comes up.
WE bought a 2016 tahoe at the same time as the malibu. According to that pdf bulletin update, it's affected as well.
Don't want to lose the GPS while out of town in the middle of nowhere.
The malibu has 4500 miles on it and the Tahoe has 4900.
Both warranties will run out by years rather than miles.
post #9 of 15 (permalink) Old 02-05-2018, 12:24 PM Thread Starter
.....maybe its a botched over-the-air update....
Do they send those out even though I don't subscribe to onstar?
post #10 of 15 (permalink) Old 02-05-2018, 12:50 PM
Campb nailed it, look at the TSB linked. It describes your situation exactly, the image of the screen in the TSB is identical to what you're experiencing.
As for over-the-air updates, GM can push those via the 4G network and you don't need an active OnStar subscription. I'm no data for my car and I had some new apps pushed on my car a few weeks ago. You can turn the feature on or off for OTA updates via the Settings icon in your dash screen.
Infotainment center Goes Black joemagjr Problems/Service Issues/Troubleshooting (Generation 9) 1 05-20-2016 10:57 AM
The Beloved MyLink, from GM Infotainment chevyorange Problems/Service Issues/Troubleshooting (Generation 8) 1 02-02-2016 01:34 AM
GM Infotainment Crockery chevyorange Problems/Service Issues/Troubleshooting (Generation 8) 8 11-26-2015 05:00 AM
Aftermarket Infotainment bizness Problems/Service Issues/Troubleshooting (Generation 8) 2 11-23-2014 04:43 AM
Apartment Fire Alarm Sys. Anyone here licensed to work on them? Drunken Elvis Off-Topic Discussion 4 03-29-2012 08:24 PM
