9-speed transmission Issue again - Chevy Malibu Forum: Chevrolet Malibu Forums
 2Likes
post #1 of 21 (permalink) Old 05-20-2019, 06:19 AM Thread Starter
amir_gh22's Avatar
Hi everyone,
I am experiencing the same issue again. It doesn't accelerate when in uphill. It kicks really hard. This time there is no check engine light. They replaced valve body and control solenoid body last year. It doesn't change gears smoothly. It's like there is a lag to it. I am sure something is breaking again.
My post from last year
amir_gh22 is offline
post #2 of 21 (permalink) Old 05-20-2019, 01:08 PM
Francis Ordiales's Avatar
Re: Transmission Issue again
Originally Posted by amir_gh22 View Post
Hi everyone,
When was your Bu built? I know you have a 2017 Premier but I was wondering maybe 1st batch of 2017s?
Also, at what mileage did this happen again? Just making a precaution since I have a 2017 Premier built May 2017.
Built: May 2017; Bought: Oct 2017
Mosaic Black Metallic Exterior-Jet Black Interior
Husky Liners (Front/Back/Cargo)
VXMOTOR Smoke Tinted Window Visor
Limo Tint Panoramic Roof
LTG Turbo Heat Shield
PTP T3 Lava Turbo Blanket
OPTI-COAT PRO+
All LED lights
Hood QuickLIFT ELITE
Custom Magnaflow Cat-back w/ Burnt Quad Tips
Plum Crazy Pearl Deck Lid Spoiler
Konig Ampliform 18x9 +15 offset 255/45r18
Francis Ordiales is online now
post #3 of 21 (permalink) Old 05-21-2019, 09:05 AM
Hi everyone,
Oh fabulous. I remember your issues from last time vividly and it's always in the back of my mind when I feel even the slightest rough shift in my car (infrequently but it occasionally does happen).
Is it happening only uphill? As I remember last time you had it happen only when taking off from a start, it wasn't during uphill climbs. Slipping transmission? I know this is a sickening development.
This time write a letter to GM about it as this is the SECOND time the tranny is acting up. Fuss, I sure did with the trials I'm having with my HVAC auto control that was never right from day one. I got GM to offer an additional 6 yr. warranty on the *entire* HVAC system starting last month, so basically 8 yrs. from purchase on the system (including compressor/evaporator/condenser and that's not even remotely what I had problems with). I've had GM do this before with items that break but aren't resolved properly. Hopefully they'll do the same for you.
Keep us posted, I for one will be following VERY closely as to what happens.
tnmats is offline
post #4 of 21 (permalink) Old 05-21-2019, 09:27 AM Thread Starter
amir_gh22's Avatar
Thanks. Check engine light came on and it wouldn't change to 3rd gear. It's in dealer now. They gave me a loaner. I also got the notification from OnStar
An issue with the Engine and Transmission System in your 2017 Chevrolet Malibu has been detected. Please service your vehicle within 7 days.
post #5 of 21 (permalink) Old 05-21-2019, 09:30 AM
So it did fail hard finally. That's good, it makes diagnosis easier. With my HVAC they never could get a hard fail making diagnosis difficult. GM's Tech Assistance Center wasn't of much help either as they've never seen this before (temp blend roor actuators toggling like crazy after the heater ran for a while plus the HVAC not remembering the fan settings if turned OFF and the car was cut off for a few hours).
Will be curious if it is the same thing again. Out of curiosity did you get an On-Star warning last time? And how did you get it, in the center display or an email?
tnmats is offline
post #6 of 21 (permalink) Old 05-21-2019, 09:35 AM Thread Starter
amir_gh22's Avatar
Correct. I got it via email. About 15 minutes after check engine light came on.
It looks like this
Sent from my SM-G975U using Tapatalk
post #7 of 21 (permalink) Old 05-21-2019, 11:27 AM
My 9speed had some solenoid kit and valve body replaced also. When mine failed the 2nd time I took it in and they did a software update. Apparently the transmission has two "overdrive" gears and gets hot and overheats some solenoid. It disables the larger until it cools back down. They did this months ago and no problem since.
JBolster is offline
post #8 of 21 (permalink) Old 05-21-2019, 02:58 PM
I am having the same issue with my 2018 Malibu. It will not accelerate and feels as if your starting from 3rd gear and it’s becoming dangerous when you are driving on a busy highway. My buddy has one too and it’s doing the same thing. Any suggestions
post #9 of 21 (permalink) Old 05-21-2019, 03:11 PM
campb292's Avatar
Re: 9-speed transmission Issue again
Before this thread goes all me-too and gets confusing, can you clarify what engine or trim you have? The issue amir_gh22 has had or may have is very specific to the 9-speed. There is another ball of ewww on the 2018 LS/LT 1.5T/6-speed if you happen to have one of those with a different fix. I can help direct you on that if that is the case or... if you also have a 2018 Premier I'll shut the heck up!
2016 Malibu 1LT 1.5T
2016 Crosstrek Premium 2.0L
2018 F-150 XLT 5.0L
campb292 is offline
post #10 of 21 (permalink) Old 05-22-2019, 05:38 AM Thread Starter
amir_gh22's Avatar
Interesting. Thanks so much. I wonder if they replace them again. hahahaha
'08 Malibu LTZ transmission issue? rhorns Problems/Service Issues/Troubleshooting (Generation 7) 3 12-04-2017 03:49 PM
Low Speed Transmission Problem Blackhawk36 Problems/Service Issues/Troubleshooting (Generation 7) 13 05-11-2015 06:46 AM
leak through output speed sensor on transmission jester09146 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 5 07-20-2011 12:06 PM
1998 Transmission Issue??? daboz32 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 01-31-2011 02:32 PM
08 Malibu engine speed control problem mizzouman_2000 Problems/Service Issues/Troubleshooting (Generation 7) 15 08-07-2008 05:19 PM
