Oil Change Question - Chevy Malibu Forum: Chevrolet Malibu Forums
 3Likes
  • 2 Post By Colt Hero
  • 1 Post By GarBec
post #1 of 6 (permalink) Old 02-17-2019, 02:36 PM Thread Starter
Oil Change Question
Has anyone tried changing the oil by extraction? In the past I have used a vacuum oil extractor with good results on my other cars. I was able to feed the extractor tube into the dipstick port of the MH and with a little jockeying it came to a hard stop, which I assume to be the bottom of the oil pan. Assuming the bottom of the pan is flat, and it appears to be, one should be able to reasonably empty the oil pan by this technique.
I did try changing the oil the conventional way but I was unable to break the oil nut free with a 15mm socket. I typically find when the dealership does the oil change, as they did at my last visit, they over torque the oil nut. Because the MH has very little clearance under the car I am not able to get a good enough grip on the socket handle to really crank down on it to break it free.
I am aware that extraction methods do leave a little oil behind.
forteatwo is offline
post #2 of 6 (permalink) Old 02-17-2019, 02:50 PM
Re: Oil Change Question
I wouldn’t - unless you’re physically unable to get underneath the vehicle.
Just tap the ratchet handle with a hammer. It doesn’t take much at all. Not need to struggle, and it only takes a single tap. But when you tighten it back, do *that* by hand - don’t use the hammer there!
Oh - and use a SIX POINT SOCKET! Throw those 12-point sockets away before you strip your next bolt head...
DrivenDaily and Chevyman4life like this.
Colt Hero is offline
post #3 of 6 (permalink) Old 02-17-2019, 03:11 PM
GarBec's Avatar
I'm not a believer in the extraction method, as not only do you never know if the pick up is in the bottom of the pan; you lose the ability to flush the pan by the force of the rapidly draining oil carrying away the suspended contaminants.
I like to let mine drain for about a half hour, until it no longer drips. This assures there is nothing left in the pan prior to refilling.
To remove a drain plug that has been over tightened; use a six point socket with a longer breaker bar. If necessary go to a bigger drive size tool such as a 1/2 drive vs a 3/8 drive tool. If you don't have a longer handled ratchet or breaker bar, a length of pipe placed over the handle to increase leverage may work.
The six point socket will prevent rounding the hex head of the drain plug.
A pair of ramps make access quite easy.
DrivenDaily likes this.
2019 Equinox 2.0 LT Redline- Silver - FWD
2017 Malibu 1.5 LT - Pepperdust - Leather - Convenience
2016 Equinox 3.6 LTZ - AWD
2009 Silverado 5.3 LT 4x4 ext. cab
GarBec is offline
post #4 of 6 (permalink) Old 02-18-2019, 06:18 AM
I too was planning to use my extraction pump to remove the oil on the 1.5L motor in my 2017 Malibu, but had already heard that there was not enough clearance to get the suction tube inside the dip stick tube. I tried it myself last week so I would know first hand whether or not it would work. My results were pretty much like yours. I was able to get the suction tube inserted quite a ways when I felt a firm stop and was unable to go further. At that point I didn't know if I hit the bottom of the pan or not, so I pulled the suction tube out, and there was no oil on it, so I must have hit a baffle or something and could not get to the bottom of the oil pan. So my plan now is to just drain the oil the conventional way.
By the way, If I was able to get down into the oil, I wouldn't have any reluctance with draining the oil by evacuation, because I discharge the oil into an old oil container, and would know that if I got 4.2 quarts out, I would have gotten all of it. I've used the evacuation method many times in the past and actually prefer it.
ClothSeats is offline
post #5 of 6 (permalink) Old 02-19-2019, 07:08 AM Thread Starter
When I inserted the extraction tube in the dipstick port I had to jockey it around by rotating it and then it would go in further. In the end there was about 1 3/4 inches of oil on the tip of the tube. So it probably made it to the bottom. My thought was to do the same thing, measure the amount of oil extracted. In the end I just took it downtown and let the local service station do it being that it is cold here I would still have to crawl under the car to get at the oil filter.
I do feel the extraction method is quick and efficient if you do it right by extracting the oil when it is hot and impurities are not settled out.
post #6 of 6 (permalink) Old 04-19-2019, 03:39 PM
It didn't work for me. I could only extract about two quarts. I was using a Pella Oil Extractor, BTW.
zbrad is offline
2010 2.4 Oil Change question quaf069 Do It Yourself Maintenance (Generation 7) 11 07-10-2016 03:49 PM
Oil changes MarcZSport Do It Yourself Maintenance (Generation 8) 164 04-12-2015 03:31 AM
Oil Life Indicator ? statjunk Do It Yourself Maintenance (Generation 7) 46 05-25-2010 08:23 PM
oil change question zog1977 General Discussion (Generation 7) 3 03-24-2009 12:42 PM
First Oil Change Question Jcol General Discussion (Generation 7) 2 11-18-2008 02:28 PM
