Best oil for your car - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
 5Likes
post #11 of 16 (permalink) Old 03-12-2019, 04:23 AM
repairman54's Avatar
Re: Best oil for your car
My 'bu has been running on WM SuperTech full synth. since I've gotten it at 75k, now at 185k, with zero engine component issues so far. Oil changes have been by the OLM also. Trans has been serviced with full synth. Dex VI several times. I found Amalie full synth. Dex VI online cheap by the case and that's what I've been using in my fleet.
John
09 Malibu LS
11 Tahoe LTZ
16 Equinox LTZ 3.6
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
07 Mustang GT 3 pedals sold
repairman54 is offline
post #12 of 16 (permalink) Old 03-12-2019, 07:24 AM
Originally Posted by Gman15Ida View Post
Alright new question about the Dexron VI. All I can get my hands on is O'Reilleys Brand. Do you think that would be a suitable replacement?
I use full-synthetic Valvoline VI transaxle fluid. Works great. Meets all the GM specs too.
Chevyman4life is offline
post #13 of 16 (permalink) Old 03-27-2019, 04:53 PM Thread Starter
Gman15Ida's Avatar
what about the valvoline max life multi-vehicle Dex/Merc; Merxon LV stuff? Is it any good?
Gman15Ida is offline
post #14 of 16 (permalink) Old 03-27-2019, 09:27 PM
Meow's Avatar
For engine oil, I've been using quaker state 5W20 full synthetic ever since I bought the car new. After the first 500 miles, I changed from the synth blend it originally came with. I also moved on to the Fram Ultra oil filter which is reinforced by a metal mesh that prevents the filter media from getting any holes in it. Since the car is one of those stop/start cars, I assumed there would be more pressure pulses in the oil from the start/stop cycling of the engine. The engine uses VVT (variable valve timing) so I certainly won't be changing the oil from anything other than the 5W20 (owner manual says 0W20 also acceptable).
I normally use Mobile1 full synth, but decided to use quaker state 5W20 after reading some of the oil test results at the 540RATBLOG oil database site. It's a bunch of data on oil tests performed by the maintainer of the site. Just google "540ratblog" for the site.
DrivenDaily likes this.
Meow is offline
post #15 of 16 (permalink) Old 03-28-2019, 04:05 AM
Cool Re: Best oil for your car
I started reading that 540 RAT blog and wow!, what an eye-opener! In just 15-20 minutes I learned some really interesting things. I'm glad that I'm using the oil I am as it is rated #3 on his list of over 200.
What I found interesting as well was that what ranked as #1 on his list based on data. He suggests not using it because it depends on using a specific motor oil with a specific amount of additive per quart. He is more inclined to use oil "right out of the bottle" instead of having to mix up a recipe. This effectively raises my choice from #3 to #2, and it just so happens that the oil that surpassed the oil I use is from the same company! I feel reassured that I've chosen the best oil, but I'll continue to read.
Thank you very much!
Here's an excerpt from his blog that I think is good to know, especially based on certain comments made on CMF about the base oil and whether it's Group III, IV, or V:
• Group I and II – are conventional mineral oils derived from crude oil.
• Group III – is a highly refined conventional mineral oil made through a process called hydrocracking. This group of oil is allowed to be called a synthetic oil in North America.
• Group IV – are true synthetic oils, known as PAO (Polyalphaolefin).
• Group V – are synthetic base stocks other than PAO’s, which include esters and other compounds.
People on Internet discussions argue endlessly over the merits or lack thereof, of these oil Groups, to try and determine which oil type is best to use. But, they don’t even understand that the base oil does NOT determine an oil’s wear protection capability. An oil’s wear protection capability is determined by its proprietary additive package, which is what contains the extreme pressure anti-wear components. So, with my Engineering tests, you can bypass all that debate, and go directly to the results of how oils you find on Auto Parts Store shelves, actually perform when put to the test. My testing is a dynamic friction test under load, similar to how an engine dyno test is a dynamic HP/Torque test under load. Both tests show how their subjects truly perform in the real world, no matter what Brand names are involved, no matter what outrageous claims may have been made, and no matter what their spec sheets say.
post #16 of 16 (permalink) Old 03-30-2019, 06:06 AM
Bob is the oil guy is the most intense oil blog. It will make your head hurt after reading it awhile.... Filters also.
John
09 Malibu LS
11 Tahoe LTZ
16 Equinox LTZ 3.6
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
