2011 Malibu Exhaust Manifold Replacement HELP please - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 6 (permalink) Old 03-26-2019, 02:10 PM Thread Starter
Hi. Please Help. I am about to order and replace the exhaust manifold on a 2011 Malibu as it is cracked and Loud and I do not need a ticket.
I have removed the heat cover but there is this bar, box and large metal pipe that goes to the bottom of the motor. The issue is I have watched dozens of youtube videos and this piece is not on any other vehicles some of which are the identical model even in image searches I am not seeing this so I do not dare to move it yet as I do not know what it is and I cannot move the metal pipe on either end because it has Metal bands on it. Please someone tell me what this part is and how I move it to replace the manifold because it is directly over top of the manifold bolts and I cannot reach them or see them. Thanks in advance.
inside the yellow circle is the top of the metal pipe, the bar and the plastic box with wiring clip.
the green arrows point to the two Long bolts i see mounting the bar.
DaveC is offline
post #2 of 6 (permalink) Old 03-26-2019, 02:32 PM
Re: 2011 Malibu Exhaust Manifold Replacement HELP please
That looks like an air distribution manifold of some sort. If that's a CA Emissions car then that would explain it.
To be sure, follow that pipe down to the other end and see if it's an air pump. If it is, then at least you have a bit more info on what to do.
post #3 of 6 (permalink) Old 03-26-2019, 04:21 PM Thread Starter
DrivenDaily - could you message me please when you can.
DaveC is offline
post #4 of 6 (permalink) Old 03-26-2019, 06:23 PM
Cool Re: 2011 Malibu Exhaust Manifold Replacement HELP please
You'll find a PM waiting from me. Your screen name was modified per your request. The PM includes your new temporary password.
post #5 of 6 (permalink) Old 03-27-2019, 06:38 PM
Cali emissions car like mine. Remove the valve (it has the electrical connector) and you can move the tubes out of the way. It makes swapping the manifold more of a PIA
Paul - 2010 Malibu
TheSilverOne is offline
post #6 of 6 (permalink) Old 03-28-2019, 03:38 AM Thread Starter
thanks. do you know more about removing the black valve? or another post that might have details on removal to get to the manifold. thank you. curious of the pdf format service manual would have this.
DaveC is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Exhaust manifold replacement 2.2 ecotec Firemansam General Discussion (Generations 5 & 6) 2 01-20-2017 06:46 AM
Cracked Exhaust Manifold. What part do I need jhanson08 Problems/Service Issues/Troubleshooting (Generation 7) 3 08-14-2015 07:33 AM
3.6 L Oil in Air Intake 96MN12 Problems/Service Issues/Troubleshooting (Generation 7) 71 08-10-2014 04:15 AM
Just bought a 2011, First Chevy, First Malibu, First post tstone New Member Introduction 3 06-07-2012 04:20 AM
2011 Malibu Can Now Accept OnStar MyLink EnvoyBu General Discussion (Generation 7) 14 06-24-2011 02:05 PM
