2016 Limited LTZ transmission fluid change - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
 7Likes
post #11 of 14 (permalink) Old 03-31-2019, 12:46 PM Thread Starter
kramerpage's Avatar
Found Valvoline full synthetic DeX vi on sale for 5 bucks a quart plus a 10 dollar off reward credit so I did 2 more exchanges. Fluid nice and clean now.
Life comes at you FAST! Enjoy just today!
kramerpage is offline
post #12 of 14 (permalink) Old 04-16-2019, 08:05 AM
Crazy Eric's Avatar
Re: 2016 Limited LTZ transmission fluid change
I've often wondered about fluid color also. Could, just could it be due to an interaction between the basically aluminum casting of the transmission and the moisture that has built up and boiled off after the many miles of use? Yeah I know that it'll probably be shot down by some system administrator but having years of experience in metallurgy and knowledge of oxidation with aluminum it is suspect.
Strategic Air Command, 380th Avionics Maintenance Squadron, Electronic Countermeasure Shop
Crazy Eric is offline
post #13 of 14 (permalink) Old 04-17-2019, 08:29 AM
That's a pretty interesting idea about how it might get some of its color. I guess I never thought about it that much.
post #14 of 14 (permalink) Old 04-17-2019, 10:55 AM
Black fluid, as long as it does NOT smell burnt, does not necessarily imply anything. Calling the fluid color black is also, to a certain extent, a judgment call. Dark brown is usually a more accurate description and that is normal. If you see any metallic appearance however I would be concerned. The fluid will not retain it's red color for long. IMO, there is no such thing as lifetime fluid. Now with that said, the fluid doesn't wear out, but the additive package will be consumed at some point and at that time the fluid needs to be changed.
Fluid level is critical, too much would probably be the one I'd be more concerned with, however, too little is more common in my experience. If you do your own service and you measure what you remove and then add in the same amount, you're back to where you started with fluid level but you still don't know whether that level is correct. In regards to the 6T40, as an example, the temperature you're supposed to check level at is around 190 degrees, ATF temperature that is, not coolant temperature. Also keep in mind, some of the late model transmission cooler lines have thermostats in them which blocks off cooler flow until trans temp is high enough. That is important as if the cooler circuit is not full of fluid when you set the level, when the thermostat does open the air will be purged from the cooler and your fluid level will drop, most likely not a lot but a drop none the less. Yes, it's a PITA to go through all the steps to set proper fluid level but these transmissions aren't the turbo 350's of 40 years ago either. Just my 2 cents.
DrivenDaily and SilverSport like this.
Transmission fluid Johnsosmooth Do It Yourself Maintenance (Generation 8) 10 02-23-2019 09:14 AM
Transmission fluid level 4T45-E akettring Do It Yourself Maintenance (Generation 7) 0 11-24-2018 09:19 AM
6 speed transmission fluid change, When? Red Ryder Do It Yourself Maintenance (Generation 7) 154 05-21-2018 07:26 AM
2008 Malibu Transmission fluid change sunshineman68 Do It Yourself Maintenance (Generation 7) 6 10-09-2017 02:38 PM
2009 Malibu-why is it so complicated to change transmission fluid? sbrach Problems/Service Issues/Troubleshooting (Generation 7) 1 09-18-2016 03:13 PM
