16-pin 5-wire OnStar Rearview Mirror Harness - Chevy Malibu Forum: Chevrolet Malibu Forums
 3Likes
  • 1 Post By OwenS
  • 2 Post By OwenS
post #1 of 8 (permalink) Old 05-29-2018, 08:37 PM Thread Starter
Hi,
I'm replacing the factory OnStar rearview mirror with a Gentex auto-dimming+compass mirror. Instead of wiring the new mirror into the dashboard, I am trying to wire it to the existing OnStar harness. The 16-pin harness has only 5 pins in use: 8 (black, gound), 11 (blue), 12 (black/white), 14 (grey), 15 (brown/white). The black/white wire controls the OnStar button illumination (green LED light), so I think I could use it as the source of the new mirror.
However, the wire's voltage is strangely 10V. So I got a voltage converter to make it a 12V. The strangest thing is then followed: although the voltage of the wire is 12V according to the multimeter, it can never power on the new mirror. The new mirror is also functional: it works when wired directly to the battery. Hard to understand why it's 10V and why the new mirror fails given a suitable voltage.
Any thoughts on the OnStar harness and other physically nearby wiring options?
OwenS is offline
post #2 of 8 (permalink) Old 05-30-2018, 03:55 AM
Re: 16-pin 5-wire OnStar Rearview Mirror Harness
A voltage that is present without a load can change when a load appears. 10V at "idle", so to speak, may not be 10V when it is being put to use. Boosting 10V to 12V puts a greater load on the 10V source and may overload it, too. Measure the new 12V when the mirror tries to turn on and you may find that it cannot provide the amperage required to do the job.
post #3 of 8 (permalink) Old 05-30-2018, 07:55 AM Thread Starter
Thanks for the reminder DrivenDaily. So the OnStar harness cannot be used anyway... Do you think it is possible to use the source from map location?
OwenS is offline
post #4 of 8 (permalink) Old 05-30-2018, 10:07 AM
!Tommy's Avatar
I did a write-up on this. https://www.chevymalibuforum.com/foru...d-compass.html
I'd recommend getting an add-a-circuit and branch off your wipers in the center console and running the power wire up through your A-pillar to pin 13 in the harness. It's ACC/ON power so when the car is shut off, it'll shut off too.
Current Vehicles
2011 Chevy Malibu 1LT (LTZ) Silver Ice Metallic / Cocoa-Cashmere 2.4L
2003 Chevy Impala Base Bronzemist Metallic 3.4L - Second Daily Driver
1986 Chevy S-10 Light Blue Metallic 2.8L w/Western Isarmatic Mark III Plow - Damaged from engine fire, under repair.
Traded
2005 Chevy Impala Comfort Plus Base Light Driftwood Metallic 3.4L - Primary Driver
1994 Oldsmobile Cutlass Ciera S Light Adriatic Metallic 3.1L - Primary
!Tommy is offline
post #5 of 8 (permalink) Old 05-30-2018, 12:22 PM Thread Starter
Hey Tommy I was and am reading your post. Nice work! Well, I guess I will do it in a similar way to yours: it is too risky to find the right ignition controlled 12V around map light area without reference. Grabbing my toolbox and will get it done soon!
!Tommy likes this.
OwenS is offline
post #6 of 8 (permalink) Old 05-30-2018, 02:44 PM
!Tommy's Avatar
Good luck! You'll love the results! It seems a bit more intimidating than what it really is, but really, it's not that bad at all. And those add a circuits are great because you don't have to ruin your wiring from the factory.
Current Vehicles
Traded
!Tommy is offline
post #7 of 8 (permalink) Old 05-30-2018, 06:45 PM Thread Starter
Got the new mirror installed successfully. I utilized the ground wire from the onstar harness, and route the power supply to the top edge of the windshield -> inside A-pillar -> the compartment below the dashboard -> the media center (where the factory radio was installed). The power supply is finally connected to the ACC of the media center. All routings are absolutely invisible. Can't be happier with the result!
Special thanks to DrivenDaily and Tommy for the helpful advice and suggestion!
ID:	60609   Click image for larger version
ID:	60617   Click image for larger version
DrivenDaily and !Tommy like this.
OwenS is offline
post #8 of 8 (permalink) Old 05-30-2018, 07:12 PM
!Tommy's Avatar
Cool Re: 16-pin 5-wire OnStar Rearview Mirror Harness
Yay!! Congrats! Glad you got it installed and working properly! Wait until you experience the autodimming and you won't have to constantly fiddle with it when you have bright lights behind you. If you look at the next post of my guide, I also installed the autodimming driver's mirror as well and you can do that as well if you so choose with just a bit extra wiring. But of course this is obviously great as it is.
Current Vehicles
Traded
!Tommy is offline
Loose rearview mirror imrf General Discussion (Generation 7) 0 09-22-2015 08:00 AM
Rearview mirror = funhouse distortion? Charade63 General Discussion (Generation 8) 12 12-30-2014 05:07 AM
Outside Rearview Chrome Mirror Covers? Greggnize Modifications (Generation 8) 3 09-22-2014 06:53 AM
Rearview mirror map lights 99malibu Modifications (Generations 5 & 6) 1 06-05-2014 05:20 PM
ONSTAR - Rearview mirror lights cylcing on and off db46062 Problems/Service Issues/Troubleshooting (Generation 7) 5 11-15-2010 07:53 PM
