02 Malibu tranny doesn't shift to OD until warmed up - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 8 (permalink) Old 03-22-2019, 07:32 AM Thread Starter
Hey guys...and girls..I have an 02 Malibu and the tranny doesn't like to shift into OD until it gets warmed up. So I decided to do a fluid/filter change. When did GM i their infinite wisdom decide we no longer needed a dipstick in the transmission???? How are you supposed to check the fluid level or add fluid for that matter??? Any and all answers are greatly appreciated.
Peace
geno4952 is offline
post #2 of 8 (permalink) Old 03-29-2019, 08:28 AM Thread Starter
re: 02 Malibu tranny doesn't shift to OD until warmed up
come on....are you kidding??? 64 people have read this post and not 1 has any info? Tried searching and can't find any there either so I guess it's see if I can find a Chilton's and look it up...thanks anyway
geno4952 is offline
post #3 of 8 (permalink) Old 03-29-2019, 03:28 PM
While I tend to agree that you should have had some kind of response, you should be aware that some of those who've "read" the post are actually web crawlers. They are part of the matrix and don't currently pose a threat to Neo.
I changed the title of the thread from "Dipstick??". The words above are taken from your original post.
post #4 of 8 (permalink) Old 03-30-2019, 02:48 AM
ma7amad's Avatar
Re: 02 Malibu tranny doesn't shift to OD until warmed up
dipstick is not big important if you know the required fluid quantity and fill the transmission properly. mine i have changed the fluid for almost 4 times most of them because of leaks from the gasket as a result of using the available aftermarket bad and poorly manufactured gaskets. all you need 6 liters very enough start slowly filling first 4 liters at p let the air find its way out. start the engine and change the gears in all positions while braking if somebody helping you by adding fluid at different gear positions otherwise complete the filling procedure at parking position. don't follow those who said fill it until the fluid overflow out from the top those are car killers.
really this transmission is well built with good maintenance it could survive forever.
another suggestion you can add the same quantity that you have drained if this transmission as factory condition never been touched or leaked.
chevy malibu 98 3.1 l
range rover 98 autobiography
range rover 4.6 l 2001 HSE
ma7amad is offline
post #5 of 8 (permalink) Old 03-30-2019, 11:28 AM
Darthz's Avatar
I think they just wanted to check the level to see if its correct ....not sure. But I have not checked mine ever.....so I never posted anything...had nothing to add to the sollution..... so yes I read it....and didnt post lol
Darthz is offline
post #6 of 8 (permalink) Old 03-30-2019, 12:40 PM
ma7amad's Avatar
may be the dipstick doesn't reflect the true level of fluid inside the transmission housing as the fluid itself doesn't leveled at equal level because the gears arrangements and solynoids...etc i am not sure just assumption.
ma7amad is offline
post #7 of 8 (permalink) Old 03-30-2019, 05:08 PM
Certified Technician
JLDickmon's Avatar
As I said on the other thread..
They know how much fluid they put in these at time of assembly. And unless there's an external leak, it should never change. If you need to check fluid level, there is a plug in the side cover. You pull the plug, and add fluid through the filler hole until it dribbles out the side cover, and that's it.
In your case, it could be low fluid, it could be something more sinister.
If the fluid level is OK, you are headed to AAMCO.
2011 LS, 2.4L, six-speed ATX
JLDickmon is offline
post #8 of 8 (permalink) Old 03-31-2019, 06:00 AM Thread Starter
Thanks for the info I will check and see if I can find the plug in the side cover and check fluid level. Apparently not using my brain cells .... I could check You Tube for a video... I'll try that too....... thanks again
Peace
geno4952 is offline
2013 Malibu taking hits in mag reviews... PX15 General Discussion (Generation 8) 19 04-01-2013 09:37 AM
GM Idles Malibu Production, needs to clear inventory GolfTango General Discussion (Generation 8) 9 01-13-2013 10:49 AM
04 Malibu Maxx sudden hard shift? mcav Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 03-01-2010 08:48 PM
My 2010 Malibu LTZ Vs My 08 Impala LT Duckybill General Discussion (Generation 7) 20 02-20-2010 02:12 AM
Driving Impressions: 2008 Chevrolet Malibu LTZ dascrow Auto Industry/General Motors News 0 11-10-2007 11:41 AM
