ABS Brake Line Diagram - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 4 (permalink) Old 03-24-2019, 07:49 PM Thread Starter
Hello, I just purchased a 2002 Malibu that the previous owner removed all of the brake lines due to rust issue. I found enough of the old lines to make patterns but I don’t know what lines go where in the ABS unit. 6-ports in the block with 4 on top (one for each wheel) plus two in the side from the master cylinder. Does anybody have a diagram showing which lines goes into which ports?
Nova9313 is offline
post #2 of 4 (permalink) Old 03-25-2019, 03:56 AM
Re: ABS Brake Line Diagram
I hope someone here comes along with what you actually requested, but if not, another idea would be to check out a junkyard and take a few pictures.
post #3 of 4 (permalink) Old 03-25-2019, 10:48 AM
Darthz's Avatar
I went to gm for the odd diagram like that.... explain your issue at the parts counter... se if they can print something off for ya
Darthz is offline
post #4 of 4 (permalink) Old 03-26-2019, 08:54 PM
ma7amad's Avatar
i searched for this pic for almost two days finally i found it as shown the pipes tie in labeled with LF,RF,LR&RR at ABS module
ID:	62887   Click image for larger version
chevy malibu 98 3.1 l
range rover 98 autobiography
range rover 4.6 l 2001 HSE
ma7amad is offline
2010 with Service ESC, Traction Control, Reversed Brake Lamps & Cruise Control Issues UneasyGuy Problems/Service Issues/Troubleshooting (Generation 7) 12 09-05-2018 10:04 AM
Brake line question 2000 Malibu fcchief Problems/Service Issues/Troubleshooting (Generations 5 & 6) 7 04-22-2018 06:39 AM
2000 Malibu brake line diagram rdbhere2 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 07-05-2017 04:42 AM
Brake Line Routing. Please help! Scottch Do It Yourself Maintenance (Generations 5 & 6) 2 09-21-2014 12:58 PM
2004 Classic ABS Light NOT coming on ClassiX2 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 25 05-07-2012 12:43 PM
