Tail lights 2010 - Chevy Malibu Forum: Chevrolet Malibu Forums
 2Likes
  • 2 Post By campb292
post #1 of 9 (permalink) Old 03-27-2019, 10:18 AM Thread Starter
Angry Tail lights
I replaced a tail light bulb, now neither tail light works.
brotherrolf is offline
post #2 of 9 (permalink) Old 03-27-2019, 12:20 PM
campb292's Avatar
I had a sandwich for lunch and I'm still hungry... but I digress...
Hello and welcome! If you let us know what year and trim you have one of us can move your thread to the section best suited to help you. You might also include some basic background such as 1) was this just a single bulb burn out with no known cause 2) was the bulb that burned out the original stock bulb 3) was this the result of an accident, weather, flood etc?
Good luck!
DrivenDaily and cp-the-nerd like this.
2016 Malibu 1LT
1.5T, 6T40, 2 wipers, 4 wheels, 8 cupholders, 16 valves, 32 thingamabobbers
Born 1/20/2016 in Fairfax, KS, Purchased 3/6/2016
RIP Chevrolet Cruze
campb292 is offline
post #3 of 9 (permalink) Old 03-27-2019, 03:21 PM
LiNy's Avatar
Smh just a sandwich....nothing to drink.
Fuse would be my guess, but as stated without the rest of the info who knows!
LiNy is offline
post #4 of 9 (permalink) Old 03-27-2019, 03:25 PM
Re: Tail lights
All I had was soup, no drink.
I'm waiting for more info. I have an idea or two, but I would like this to be moved where it belongs and then I'll know if I actually have anything helpful to add.
post #5 of 9 (permalink) Old 03-28-2019, 04:22 PM
LiNy's Avatar
Agreed:arrow_up:
LiNy is offline
post #6 of 9 (permalink) Old 03-28-2019, 05:01 PM
Angry Tail lights 2010
I have a 2010 Malibu, L4, both tail lights are out, bulbs okay, fuse okay.
All connections tight. This is probably not the problem, but there was a black wire loosely attach to a bolt near the left tail light. The wire went under the trunk floor covering. I pulled on it to take up the slack and it came out and the other end had a clean cut off, I am sure I did not cut any wires, about 3 foot long, black wire, copper strands.
Anyone know what this wire was for, where the other end might have been connected?
Ralph Warth is offline
post #7 of 9 (permalink) Old 03-28-2019, 10:28 PM
Thumbs down Re: Tail lights 2010
Thread moved from section for help with the website, and then merged with your original thread under a different user name. Yours is a Gen7, so posting here will get you more traffic and more help from the members.
Please do not start multiple threads for the same issue, and especially don't do it under 2 different user names! Your original username has been deactivated.
The stock wiring does not use a wire like that, so it was probably some other aftermarket stuff that was abandoned or removed by the dealer and the wire was simply cut. Standard practice with non-stock stuff.
Turn on the hazard flashers and check if the rear brake/turns light up. If so, then the brake/turn circuit is good.
Turn on the parking lights and see if the taillights light up. If so, then the parking circuit is good.
Which are you saying is not working, the parking lights (aka taillights), the brake/turn lights, or both?
post #8 of 9 (permalink) Old 03-29-2019, 12:51 PM
The only lights that don't work are the tail lights and the from parking lights.
post #9 of 9 (permalink) Old 03-29-2019, 04:09 PM
Relay under the hood, fuse under the hood. If you pull either one, inspect the terminals for color and cleanliness.
Either one or both could be "plugged in and okay", but corrosion on the terminals could prevent it from allowing power to pass. For the relay, the contacts inside could be pitted or the relay could have failed.
Have someone operate the lights and listen for the relay to click. That will tell you that it's moving but not that it's turning the lights on.
The other thing could be that the BCM isn't sending the signal to the relay, or you could have experienced damaged wiring from some kind of critter getting up inside and chewing on stuff.
Good Mish Mash or Bad? Tail lights jojeeka Modifications (Generation 9) 4 03-01-2019 05:06 AM
Tail lights stopped working...... 2013 Malibu Mark L Problems/Service Issues/Troubleshooting (Generation 8) 4 02-25-2016 07:48 PM
switching LT tail lights with LTZ tail lights.. HELP bruce Problems/Service Issues/Troubleshooting (Generation 8) 7 06-02-2015 06:07 AM
Eye-catching Anzo Tail Lights for Chevy Malibu! CARiD CARiD.com 4 01-05-2015 06:00 AM
2009 Frankfurt Auto Show cars list trev0006 Other Rides 0 09-13-2009 11:46 PM
